7 messages2009-02-20 19:15 through 2009-02-23 18:45 UTC
Cal-31 Bimini
Kevin2009-02-20 19:15
To all the Cal-31 owners and others who know more than me. (everyone?)
I am looking to replace the bimini with a larger unit
Right now it is approximately 8'W X 6'L.
Is there any way to cover more of the cockpit?
I don't know how many other Cals have the main sheet in front of the
companion way like the 31 does.
Right now my Bimini stops just behind the boom. I can't go under the
boom more than 6" because of the main sheet and 0" over the boom
because of the topping lift.
I would even entertain the idea of expanding the bimini when the sail
is down if that would be possible by moving the boom to one side.
Yes, my GF does not like that she is in the hot Las Vegas sun because
the Bimini only covers the one behind the wheel.
Thanks!
Kevin O.
Cal-31
"Kona"
Las Vegas
Re: [Cal_Boats] Cal-31 Bimini
Bob Connell2009-02-21 20:59 UTC
On my Cal 31 (hull 59) the mainsheet and traveler are in the cockpit which gets in the way but is also pretty convenient for handling sheets during gusts. No chance for a bimini. For winter or inclement weather when at anchor I can put a tarp on the boom that covers the companionway as far back as the topping lift which at the boom end is not quite as far back as the wheel.
--- On Fri, 2/20/09, Kevin <fi… [at] yahoo.com> wrote:
Subject: [Cal_Boats] Cal-31 Bimini
Date: Friday, February 20, 2009, 11:15 AM
Thanks!
Kevin O.
Cal-31
"Kona"
Las Vegas
Greg Branch2009-02-22 01:28 UTC
A neighbors Cal 31 has the mainsheet moved to infront of the cabin hatch. He used the stock boom. He then had a complete enclosure for the cockpit built combining bimini, dodger and side currents into one large enclosure...
Sent: Saturday, February 21, 2009 12:59 PM
Subject: Re: [Cal_Boats] Cal-31 Bimini
Thanks!
Kevin O.
Cal-31
"Kona"
Las Vegas
RE: [Cal_Boats] Cal-31 Bimini
Harleigh Ewell2009-02-22 03:47 UTC
My 31 has a bimini that the PO had custom made. It extends from ½ aft of
the mainsheet, which is in the cockpit within easy reach for singlehanding,
to about a foot aft of the split backstay (due to a slot and zipper). I
cant believe that I put up with previous boats without a bimini, its such
a blessing to be able to get out of the sun. Kevin, I dont know how you
could have a bimini above the boom due to clearance issues with the
mainsail, but a topping lift can be replaced by a rigid boom vang. In fact,
I have a Garhauer vang that I have never installed because it would
interfere with installing my portable air conditioning unit, which can save
your life in a marina during hot Chesapeake Bay summers. If anyone would
like to buy the vang, make an offer, or I can check on how much it cost and
set a price.
Harleigh Ewell
Of Bob Connell
Sent: Saturday, February 21, 2009 4:00 PM
wheel.
Thanks!
Kevin O.
Cal-31
"Kona"
Las Vegas
Fred Haas2009-02-22 18:53 UTC
Greg,I had a very similar enclosure built for Nemesis, although the
traveler is at the back of the bridgedeck. There is the dodger itself,
with it's zip in windshield and side curtains. To the back of this zips
the sun/rain shade, with it's side curtains and a cutout sleeved area
for the mainsheet. Finally there is a wrap around back panel that zips
to it. This panel has a large U-shaped zipper which allows he back to
be rolled up for ventilation. I can go from fully enclosed to
completely open in about 20 minutes, 10 or less if I leave the dodger
and aft support frames in place. Currently the boat is in the water at
TYC with the dodger, it's side curtains and rain shade in place. This
afternoon I'll roll the rain shade up on its support and enjoy a
midwinter sail. The enclosure was expensive, but after 11 years in
place, I think it was some of the best money I have put into the boat.
Fred Haas
3-30 Nemesis
acoma
> large enclosure...
>> From: Bob Connell
Re: Cal-31 Bimini
egiajack2009-02-22 19:45
With the aft mainsheet your options are really limited. The best setup
for a bimini and/or dodger is to have the mainsheet go to a traveler
beam forward of the companion hatch, but that conversion would be a
major hassle and big $$$$$$. When cruising we love our bimini, so I
can understand your GF's preferences.
Jack
Cal 31
Melantho
Re: [Cal_Boats] Re: Cal-31 Bimini
Fred Haas2009-02-23 18:45 UTC
Greg,
Short of moving the traveler, you have an option. Nemesis' bimini zips
to the back od the dodger with a sleeved slot for the mainsheet. This
works for mooring and motoring. If I wish to sail with the bimini in
place, I have a series of "stretchers" which allow the bimini to be
folded back about a foot while being held in place by the nylon straps
from the dodger. These clip onto the bottom side of the bimini and hold
the canvas in place. OF course you have to disconnect and reconnect the
straps when tacking, but in a cruising situation the extra time
required in usually not much of an issue.
Let me know if you want pictures.
Fred Haas
3-30 Nemesis
Tacoma
> Jack
> Cal 31
> Melantho
