Cal 29 prop size
Cal 29 prop size
7 messages2009-02-26 03:27 through 2009-02-26 17:55 UTC
Cal 29 prop size
jjmcclosk2009-02-26 03:27
I have a 1972 Cal 29-2 with a Bukh 10hp diesel. It currently has a 12" X 12" solid prop. Does this sound correct? I don't have a problem when underway, the boat will do hull speed in calm water, but backing down and acceleration are pathetic. Joe
Re: [Cal_Boats] Cal 29 prop size
Joe DeMers2009-02-26 13:10 UTC
What is the boat's waterline length, the reduction gear ratio, and at what rpm does the engine make it's maximum horsepower? Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com From: "jjmcclosk" <jj… [at] yahoo.com> To: <Ca… [at] yahoogroups.com> Sent: Wednesday, February 25, 2009 10:27 PM Subject: [Cal_Boats] Cal 29 prop size >I have a 1972 Cal 29-2 with a Bukh 10hp diesel. It currently has a 12" > X 12" solid prop. Does this sound correct? I don't have a problem when > underway, the boat will do hull speed in calm water, but backing down > and acceleration are pathetic. > Joe > > > > ------------------------------------ > > Yahoo! Groups Links > > > > > > -- > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 > 6:43 AM > >
Joseph McCloskey2009-02-26 16:48 UTC
Waterline 24', engine RPM @10hp= 3000, reduction gear 2.5: 1 --- On Thu, 2/26/09, Joe DeMers <je… [at] mindspring.com> wrote: From: Joe DeMers <je… [at] mindspring.com> Subject: Re: [Cal_Boats] Cal 29 prop size To: Ca… [at] yahoogroups.com Date: Thursday, February 26, 2009, 8:10 AM What is the boat's waterline length, the reduction gear ratio, and at what rpm does the engine make it's maximum horsepower? Joe DeMers Sound Marine Diesel LLC www.soundmarinedies el.com From: "jjmcclosk" <jjmcclosk@yahoo. com> To: <Cal_Boats@yahoogrou ps.com> Sent: Wednesday, February 25, 2009 10:27 PM Subject: [Cal_Boats] Cal 29 prop size >I have a 1972 Cal 29-2 with a Bukh 10hp diesel. It currently has a 12" > X 12" solid prop. Does this sound correct? I don't have a problem when > underway, the boat will do hull speed in calm water, but backing down > and acceleration are pathetic. > Joe > > > > ------------ --------- --------- ------ > > Yahoo! Groups Links > > > > > > -- > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 > 6:43 AM > >
Joe DeMers2009-02-26 17:45 UTC
12 x 15, 2 blade [ this prop has a large blade area, making it an excellent compromise between a 3 blade and a 2 blade prop ] 12 x 14, 3 blade Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: Joseph McCloskey To: Ca… [at] yahoogroups.com Sent: Thursday, February 26, 2009 11:48 AM Subject: Re: [Cal_Boats] Cal 29 prop size Waterline 24', engine RPM @10hp= 3000, reduction gear 2.5: 1 --- On Thu, 2/26/09, Joe DeMers <je… [at] mindspring.com> wrote: From: Joe DeMers <je… [at] mindspring.com> Subject: Re: [Cal_Boats] Cal 29 prop size To: Ca… [at] yahoogroups.com Date: Thursday, February 26, 2009, 8:10 AM What is the boat's waterline length, the reduction gear ratio, and at what rpm does the engine make it's maximum horsepower? Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: "jjmcclosk" <jjmcclosk@yahoo. com> To: <Cal_Boats@yahoogrou ps.com> Sent: Wednesday, February 25, 2009 10:27 PM Subject: [Cal_Boats] Cal 29 prop size >I have a 1972 Cal 29-2 with a Bukh 10hp diesel. It currently has a 12" > X 12" solid prop. Does this sound correct? I don't have a problem when > underway, the boat will do hull speed in calm water, but backing down > and acceleration are pathetic. > Joe > > > > ------------ --------- --------- ------ > > Yahoo! Groups Links > > > > > > -- > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 > 6:43 AM > > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 6:43 AM
Joe DeMers2009-02-26 17:50 UTC
My prop guy did comment that a 2:1 gear would be preferred, so a 12 x 9, 3 blade prop could be used. That shallower pitch is preferable for a sailboat. Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: Joe DeMers To: Ca… [at] yahoogroups.com Sent: Thursday, February 26, 2009 12:45 PM Subject: Re: [Cal_Boats] Cal 29 prop size 12 x 15, 2 blade [ this prop has a large blade area, making it an excellent compromise between a 3 blade and a 2 blade prop ] 12 x 14, 3 blade Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: Joseph McCloskey To: Ca… [at] yahoogroups.com Sent: Thursday, February 26, 2009 11:48 AM Subject: Re: [Cal_Boats] Cal 29 prop size Waterline 24', engine RPM @10hp= 3000, reduction gear 2.5: 1 --- On Thu, 2/26/09, Joe DeMers <je… [at] mindspring.com> wrote: From: Joe DeMers <je… [at] mindspring.com> Subject: Re: [Cal_Boats] Cal 29 prop size To: Ca… [at] yahoogroups.com Date: Thursday, February 26, 2009, 8:10 AM What is the boat's waterline length, the reduction gear ratio, and at what rpm does the engine make it's maximum horsepower? Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: "jjmcclosk" <jjmcclosk@yahoo. com> To: <Cal_Boats@yahoogrou ps.com> Sent: Wednesday, February 25, 2009 10:27 PM Subject: [Cal_Boats] Cal 29 prop size >I have a 1972 Cal 29-2 with a Bukh 10hp diesel. It currently has a 12" > X 12" solid prop. Does this sound correct? I don't have a problem when > underway, the boat will do hull speed in calm water, but backing down > and acceleration are pathetic. > Joe > > > > ------------ --------- --------- ------ > > Yahoo! Groups Links > > > > > > -- > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 > 6:43 AM > > ---------------------------------------------------------------------------- No virus found in this incoming message. Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 6:43 AM ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 6:43 AM
Joseph McCloskey2009-02-26 17:51 UTC
Joe Thanks for the info. Sounds like this would give me more thrust. Do you know if this size would apply to the Martec folding prop? --- On Thu, 2/26/09, Joe DeMers <je… [at] mindspring.com> wrote: From: Joe DeMers <je… [at] mindspring.com> Subject: Re: [Cal_Boats] Cal 29 prop size To: Ca… [at] yahoogroups.com Date: Thursday, February 26, 2009, 12:45 PM 12 x 15, 2 blade [ this prop has a large blade area, making it an excellent compromise between a 3 blade and a 2 blade prop ] 12 x 14, 3 blade Joe DeMers Sound Marine Diesel LLC www.soundmarinedies el.com ----- Original Message ----- From: Joseph McCloskey To: Cal_Boats@yahoogrou ps.com Sent: Thursday, February 26, 2009 11:48 AM Subject: Re: [Cal_Boats] Cal 29 prop size Waterline 24', engine RPM @10hp= 3000, reduction gear 2.5: 1 --- On Thu, 2/26/09, Joe DeMers <jedsail@mindspring. com> wrote: From: Joe DeMers <jedsail@mindspring. com> Subject: Re: [Cal_Boats] Cal 29 prop size To: Cal_Boats@yahoogrou ps.com Date: Thursday, February 26, 2009, 8:10 AM What is the boat's waterline length, the reduction gear ratio, and at what rpm does the engine make it's maximum horsepower? Joe DeMers Sound Marine Diesel LLC www.soundmarinedies el.com From: "jjmcclosk" <jjmcclosk@yahoo. com> To: <Cal_Boats@yahoogrou ps.com> Sent: Wednesday, February 25, 2009 10:27 PM Subject: [Cal_Boats] Cal 29 prop size >I have a 1972 Cal 29-2 with a Bukh 10hp diesel. It currently has a 12" > X 12" solid prop. Does this sound correct? I don't have a problem when > underway, the boat will do hull speed in calm water, but backing down > and acceleration are pathetic. > Joe > > > > ------------ --------- --------- ------ > > Yahoo! Groups Links > > > > > > -- > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 > 6:43 AM > > No virus found in this incoming message. Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 6:43 AM
Joe DeMers2009-02-26 17:55 UTC
All bets are off when using a Martec folding prop. These props are designed for racing, and have little in common with a fixed blade prop. Contact Martec for their suggestions. Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: Joseph McCloskey To: Ca… [at] yahoogroups.com Sent: Thursday, February 26, 2009 12:51 PM Subject: Re: [Cal_Boats] Cal 29 prop size Joe Thanks for the info. Sounds like this would give me more thrust. Do you know if this size would apply to the Martec folding prop? --- On Thu, 2/26/09, Joe DeMers <je… [at] mindspring.com> wrote: From: Joe DeMers <je… [at] mindspring.com> Subject: Re: [Cal_Boats] Cal 29 prop size To: Ca… [at] yahoogroups.com Date: Thursday, February 26, 2009, 12:45 PM 12 x 15, 2 blade [ this prop has a large blade area, making it an excellent compromise between a 3 blade and a 2 blade prop ] 12 x 14, 3 blade Joe DeMers Sound Marine Diesel LLC www.soundmarinedies el.com ----- Original Message ----- From: Joseph McCloskey To: Cal_Boats@yahoogrou ps.com Sent: Thursday, February 26, 2009 11:48 AM Subject: Re: [Cal_Boats] Cal 29 prop size Waterline 24', engine RPM @10hp= 3000, reduction gear 2.5: 1 --- On Thu, 2/26/09, Joe DeMers <jedsail@mindspring. com> wrote: From: Joe DeMers <jedsail@mindspring. com> Subject: Re: [Cal_Boats] Cal 29 prop size To: Cal_Boats@yahoogrou ps.com Date: Thursday, February 26, 2009, 8:10 AM What is the boat's waterline length, the reduction gear ratio, and at what rpm does the engine make it's maximum horsepower? Joe DeMers Sound Marine Diesel LLC www.soundmarinedies el.com ----- Original Message ----- From: "jjmcclosk" <jjmcclosk@yahoo. com> To: <Cal_Boats@yahoogrou ps.com> Sent: Wednesday, February 25, 2009 10:27 PM Subject: [Cal_Boats] Cal 29 prop size >I have a 1972 Cal 29-2 with a Bukh 10hp diesel. It currently has a 12" > X 12" solid prop. Does this sound correct? I don't have a problem when > underway, the boat will do hull speed in calm water, but backing down > and acceleration are pathetic. > Joe > > > > ------------ --------- --------- ------ > > Yahoo! Groups Links > > > > > > -- > No virus found in this incoming message. > Checked by AVG. > Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 > 6:43 AM > > -------------------------------------------------------------------- No virus found in this incoming message. Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 6:43 AM ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG. Version: 7.5.557 / Virus Database: 270.11.3/1969 - Release Date: 2/24/2009 6:43 AM
