57 messages2009-03-02 20:06 UTCthrough 2009-03-06 15:32 UTC
boom vang recommendations for older Cal 25?
Whirled Peas2009-03-02 20:06 UTC
Does anyone have great recommendation on a boom vang (brand/setup/whatever) for an older Cal 25? First I’m wondering how to determine the cross section of the boom and the mounting strap I need to install. Or maybe someone already knows what size and brand works or has a supplier for such. Second, I want something pretty hefty… I like to sail heavy weather. Any recommendations?
RE: [Cal_Boats] boom vang recommendations for older Cal 25? - Garhauer
ti… [at] ch2m.com2009-03-02 20:18 UTC
I always recommend people to consider Garhauer, they will make the entire piece as a rigid vang. including the mounts. You need to contact them, and then supply templates of your spars. Their pricing, quality and strengths are very good, sometimes they need a bit of lead time. My last pricing Garhauer was at least 1/3 the price of other units. They sell factory direct, and custom make for your boat.
dEmO
My Cal 9.2 Garhauer.
[cid:079520720@02032009-194E]
California Girl Garhauer:
[cid:079520720@02032009-1955]
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Whirled Peas
Sent: Monday, March 02, 2009 12:06 PM
Subject: [Cal_Boats] boom vang recommendations for older Cal 25?
Does anyone have great recommendation on a boom vang (brand/setup/whatever) for an older Cal 25? First I'm wondering how to determine the cross section of the boom and the mounting strap I need to install. Or maybe someone already knows what size and brand works or has a supplier for such. Second, I want something pretty hefty... I like to sail heavy weather. Any recommendations?
Husar, Charlie [USA]2009-03-02 21:26 UTC
Hi, Peas. I would need to go measure some things, but I the first
decision is solid vang that supports the mast. I have heard Garhauer
mentioned highly for this. I use a line vang at 4:1 with the cleat at
the top so it can be reached more easily. I use a u-shaped bail to a
through-bolt in the boom. The strap type attachments tend not to stay
in or stay in place. If you screw something into the mast with multiple
screws, make sure they are not vertically aligned. This creates a weak
spot. Once snapped a boom in a storm due to this. Kind of exciting.
CAL 25 460
CAL 25 1657
Annapolis
Sent: Monday, March 02, 2009 3:06 PM
Re: [Cal_Boats] boom vang recommendations for older Cal 25?
Chris Campbell2009-03-02 21:42 UTC
> multiple screws, make sure they are not vertically aligned. This
> creates a weak spot. Once snapped a boom in a storm due to this.
> Kind of exciting.
I've always been a bit nervous about mid-boom loads because of that
problem. Both of my boats have boom-end sheeting, which makes me feel
secure. I think it was a recent article in /Good Old Boat/ that
cautioned against using a line vang running to the toe rail as a
preventer for the same reason.
But my Cal 20 has a line vang running to a stainless plate screwed on
the bottom of her boom with steel (not stainless) screws. Some of the
tension on the plate is in shear (forward) but a good part of it is down
, in tension (or else the vang wouldn't do anything except keep the boom
from disappearing aft, would it?). I usually manage to suppress my
morbid curiosity about the combined effect of aluminum + stainless +
regular steel, consoling myself with the thought that my boat is in
fresh water, after all. But think about it, even ignoring the battery
effect: sheet-metal screws running into aluminum are in tension. Not
really a good plan.
Even worse, I haven't managed to get Steve Seal to sell me a bail for
the bottom of the mast for the vang to run to. Another supplier said
"Steve Seal has beter ones than we have" but he professes not to
understand.
in fresh water, after all
Husar, Charlie [USA]2009-03-02 21:48 UTC
I meant to say the decision is solid vang or line vang. I do line vang,
but a solid one might be handy. As Chris says, the preventer mode can
be dangerous in heavier air. A lot of force when the main backwinds.
Behalf Of Chris Campbell
Sent: Monday, March 02, 2009 4:43 PM
Subject: Re: [Cal_Boats] boom vang recommendations for older Cal 25?
first decision is solid vang that supports the mast. I have heard
Garhauer mentioned highly for this. I use a line vang at 4:1 with the
cleat at the top so it can be reached more easily. I use a u-shaped
bail to a through-bolt in the boom. The strap type attachments tend not
to stay in or stay in place. If you screw something into the mast with
creates a weak spot. Once snapped a boom in a storm due to this. Kind
of exciting.
secure. I think it was a recent article in Good Old Boat that cautioned
against using a line vang running to the toe rail as a preventer for
the same reason.
really a good plan.
understand.
Whirled Peas2009-03-02 22:04 UTC
All good advice. Forgot to mention my budget is $200 tops... hopefully less.. So that may rule out a solid vang. Unless I can fabricate it myself but I'm not familiar with their design.
I was thinking of having a stainless steel strap (not sure if that the correct term... the V shaped wishbone ones) that goes diagonally onto the boom. I was going to use aluminum pop rivets to help avoid corrosion. No need to mount anything on the mast... the mast end of the vang already has an eye mounted on the deck.
Preventer mode... I don't mess with preventers unless the wind is very light.
Was mostly wondering is anyone had a source on the stainless wishbone boom strap... or is that just an item I'm going to have to draw up my own crosssection for and go shopping? Or does anyone know the proper term I should be using for it? A bail? Even if it goes diagonal? Thanks
Cris
Sent: Monday, March 2, 2009 1:48:15 PM
Subject: RE: [Cal_Boats] boom vang recommendations for older Cal 25?
I meant to say the decision is solid vang or line vang. I do line vang, but a solid one might be handy. As Chris says, the preventer mode can be dangerous in heavier air. A lot of force when the main backwinds.
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Chris Campbell
Hi, Peas.. I would need to go measure some things, but I the first decision is solid vang that supports the mast. I have heard Garhauer mentioned highly for this. I use a line vang at 4:1 with the cleat at the top so it can be reached more easily. I use a u-shaped bail to a through-bolt in the boom. The strap type attachments tend not to stay in or stay in place. If you screw something into the mast with multiple screws, make sure they are not vertically aligned. This creates a weak spot. Once snapped a boom in a storm due to this. Kind of exciting.
I've always been a bit nervous about mid-boom loads because of that problem. Both of my boats have boom-end sheeting, which makes me feel secure. I think it was a recent article in Good Old Boat that cautioned against using a line vang running to the toe rail as a preventer for the same reason.
But my Cal 20 has a line vang running to a stainless plate screwed on the bottom of her boom with steel (not stainless) screws. Some of the tension on the plate is in shear (forward) but a good part of it is down , in tension (or else the vang wouldn't do anything except keep the boom from disappearing aft, would it?). I usually manage to suppress my morbid curiosity about the combined effect of aluminum + stainless + regular steel, consoling myself with the thought that my boat is in fresh water, after all. But think about it, even ignoring the battery effect: sheet-metal screws running into aluminum are in tension. Not really a good plan.
Even worse, I haven't managed to get Steve Seal to sell me a bail for the bottom of the mast for the vang to run to. Another supplier said "Steve Seal has beter ones than we have" but he professes not to understand.
ti… [at] ch2m.com2009-03-02 22:19 UTC
$100 (plus shipping) answer is:
Search the Garhauer site for boom vang and bails.
for @ $95 this:
[http://garhauermarine.com/images/product/25%20UAB4-1.jpg]
$5.00 more will get you this bail
[http://garhauermarine.com/images/product/BB-2.jpg]
http://garhauermarine.com/catalog.cfm
Sent: Monday, March 02, 2009 2:05 PM
All good advice. Forgot to mention my budget is $200 tops... hopefully less. So that may rule out a solid vang. Unless I can fabricate it myself but I'm not familiar with their design.
Cris
From: Cal_Boats@yahoogrou ps.com<http://ps.com/> [mailto:Cal_ Boats@yahoogroup s.com<http://s.com/>] On Behalf Of Chris Campbell
Hi, Peas. I would need to go measure some things, but I the first decision is solid vang that supports the mast. I have heard Garhauer mentioned highly for this. I use a line vang at 4:1 with the cleat at the top so it can be reached more easily. I use a u-shaped bail to a through-bolt in the boom. The strap type attachments tend not to stay in or stay in place. If you screw something into the mast with multiple screws, make sure they are not vertically aligned. This creates a weak spot. Once snapped a boom in a storm due to this. Kind of exciting.
Chris Campbell2009-03-02 22:20 UTC
> light.
Gee, I've never messed with a preventer unless it was blowing hard
enough to wreak havoc if the main backwinded. But it should run from
the boom end, way forward. Tie it to the boom with a very long loop so
you can reach the loop from the cockpit with the boom way out.
RE: [Cal_Boats] boom vang recommendations for older Cal 25? - outgrabber
ti… [at] ch2m.com2009-03-02 22:30 UTC
If and when we decide to use a preventer, we first tie a gasket (sail tie) or a piece of light line around the boom and attach the preventer to this.
If there is a ghastly jibe, then the line breaks letting the stuff fly without breaking the boom.
Before the break, the sails flap, (warning 1)
then the boom makes a flutter noise (warning 2),
then the line makes a snapping noise (warning 3)
then the deck is cleared, with sailors heads flying about - on those who never listen to warnings.
[http://garhauermarine.com/images/product/BT-1.jpg] another $4.50 "wishbone" from Garhauer.
Two other ideas,
1. we picked a very light preventer cam cleat lock on our preventer, when stressed it slips the line instead of the boom breaking...
2. when going downwind with the spinnaker up, we use an Outgrabber, a line from the end of the boom, to the spinnaker sheet, if the boom tries to swing, it has to pull the spinnaker sheet first, collapsing the spinnaker, and slowing the boom down considerably.
[http://www.spinnakershop.com/images/SpinShop/Outgrab/outgrabber%20ai.jpg]
dEmO
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Husar, Charlie [USA]
Sent: Monday, March 02, 2009 1:48 PM
ti… [at] ch2m.com2009-03-02 22:32 UTC
In light air we use a preventer, if necessary to calm the boom.
Out grabber in use on Stan and Sally Honey's Cal 40, crossing the finish line at Diamond head.
[http://www.spinnakershop.com/images/SpinShop/ConserTPFinishCroppedBright.jpg]
Sent: Monday, March 02, 2009 2:21 PM
Gee, I've never messed with a preventer unless it was blowing hard enough to wreak havoc if the main backwinded. But it should run from the boom end, way forward. Tie it to the boom with a very long loop so you can reach the loop from the cockpit with the boom way out.
Whirled Peas2009-03-02 22:33 UTC
Thanks timmothy! That's what I was looking for. The $100 solution is a great option. And the Garhauer solid vangs aren't all that pricey... $330? Maybe.. maybe...
Sent: Monday, March 2, 2009 2:19:55 PM
for @ $95 this:
http://garhauermari ne.com/catalog. cfm
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s..com] On Behalf Of Whirled Peas
Cris
From: "Husar, Charlie [USA]" <husar_charlie@ bah.com>
ti… [at] ch2m.com2009-03-02 22:35 UTC
You might talk Garhauer into honoring the Solid Vang sale price that ended Feb 28th... 20% off?
Sent: Monday, March 02, 2009 2:33 PM
for @ $95 this:
http://garhauermari ne.com/catalog. cfm<http://garhauermarine.com/catalog.cfm>
From: Cal_Boats@yahoogrou ps.com<http://ps.com/> [mailto:Cal_ Boats@yahoogroup s.com<http://s.com/>] On Behalf Of Whirled Peas
Cris
From: "Husar, Charlie [USA]" <husar_charlie@ bah.com<http://bah.com/>>
Whirled Peas2009-03-02 22:38 UTC
So what's the advantage of the solid vang? I'm unfamiliar and just trying to guess here by looking at product pictures.
Sent: Monday, March 2, 2009 2:35:35 PM
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Whirled Peas
From: "timmothy.lessley@ ch2m.com" <timmothy.lessley@ ch2m.com>
for @ $95 this:
Cris
ti… [at] ch2m.com2009-03-02 22:47 UTC
Solid vangs are made with two tubes, one inside the other, like a shock absorber. An internal spring keeps the tubes pushed out. The spring is sized by Garhauer when you give them dimensions of your rig.
So the springed unit can hold the weight of your boom, so when you drop the main, such as when you are reefing, the boom stays supported, instead of dropping to the deck. A rope vang, will drop the boom to the deck, unless you have a clasp on the backstay, or a boom topper from the mast head. Using the clasp while sailing is NOT good.
dEmO
Sent: Monday, March 02, 2009 2:38 PM
From: Cal_Boats@yahoogrou ps.com<http://ps..com/> [mailto:Cal_ Boats@yahoogroup s.com<http://s.com/>] On Behalf Of Whirled Peas
From: "timmothy.lessley@ ch2m.com<http://ch2m.com/>" <timmothy.lessley@ ch2m.com>
for @ $95 this:
Cris
Whirled Peas2009-03-03 00:15 UTC
hmmm, good stuff. The sale on vangs is still going on until April 30th
http://garhauermarine.com/index.cfm
Solid vang is probably out of my budget currently (seeing the number of projects I need to get done).
Now, should I go with a stainless steel 25-US 4-1 vang 1000lb working load....
or should I step up to a 30 UAB 4-1 vang anodized aluminum with 2000lb working load?
Decisions decisions... not much to do at work today :)
Sent: Monday, March 2, 2009 2:47:17 PM
dEmO
From: "timmothy.lessley@ ch2m.com" <timmothy.lessley@ ch2m..com>
for @ $95 this:
Cris
r good2009-03-03 00:27 UTC
I second that recommendation
Date: Mon, 2 Mar 2009 13:18:15 -0700
Subject: RE: [Cal_Boats] boom vang recommendations for older Cal 25? - Garhauer
dEmO
r good2009-03-03 00:30 UTC
strap type works fine if a stop screw is installed. still need topping lift however.
Date: Mon, 2 Mar 2009 16:26:07 -0500
CAL 25 460
CAL 25 1657
Annapolis
r good2009-03-03 00:41 UTC
you'll regret not doing the rigid vang. be sure you are pricing the right one. call Garhauer
Date: Mon, 2 Mar 2009 16:15:16 -0800
dEmO
for @ $95 this:
Cris
Whirled Peas2009-03-03 00:46 UTC
Ok, I've been taking my sail up and down for years with no rigid vang. But I do see the potential benefit... in very strong conditions like 25knot winds I sorta wish I had a rigid vang. Will a rigid vang hold up to a strongly luffing sail in heavy conditions? Will it hold up to an accidental partial tack while bring the sail down or reefing?
Cris
To: ca… [at] yahoogroups.com
Sent: Monday, March 2, 2009 4:41:43 PM
http://garhauermari ne.com/index. cfm
dEmO
for @ $95 this:
I was thinking of having a stainless steel strap (not sure if that the correct term... the V shaped wishbone ones) that goes diagonally onto the boom. I was going to use aluminum pop rivets to help avoid corrosion. No need to mount anything on the mast... the mast end of the vang already has an eye mounted on the deck..
Cris
ti… [at] ch2m.com2009-03-03 00:59 UTC
The solid boom is spring loaded, like your (my) toiler paper holder rod, it will compress to a point, then it bottoms out, so it will support until something breaks, once the spring totally compresses.
The Cal 40 solid vang can support my weight, 275lbs before the spring compresses completely. After that huge load, the weaker of components becomes the concern...
Still, if you need room in a budget, if you have the line from the top of the mast to the back of the boom, a boom topping lift, you will not need the solid vang...
dEmO, the big load!
[cid:032524700@03032009-195C]
Sent: Monday, March 02, 2009 4:47 PM
Cris
To: Cal_Boats@yahoogrou ps.com<http://ps.com/>
http://garhauermari ne.com/index. cfm<http://garhauermarine.com/index.cfm>
dEmO
for @ $95 this:
Cris
But my Cal 20 has a line vang running to a stainless plate screwed on the bottom of her boom with steel (not stainless) screws. Some of the tension on the plate is in shear (forward) but a good part of it is down , in tension (or else the vang wouldn't do anything except keep the boom from disappearing aft, would it?). I usually manage to suppress my morbid curiosity about the combined effect of aluminum + stainless + regular steel, consoling myself with the thought that my boat is in fresh water, after all.. But think about it, even ignoring the battery effect: sheet-metal screws running into aluminum are in tension. Not really a good plan.
Re: [Cal_Boats] Good Prices for hardware(Whirley)
david dobbs2009-03-03 05:55 UTC
WP,
I once worked for an E-8 named Whirley, not my fave, but that's another story. Take a look at Sail Care's catalog. I bought a block from them recently and by all appearance it's as good or better than Harken, etc. They import them from Italy and the price is reasonable.
Regards,
David Dobbs Cal29 411
--- On Mon, 3/2/09, Whirled Peas <wh… [at] yahoo.com> wrote:
> From: Whirled Peas <wh… [at] yahoo.com>
> Date: Monday, March 2, 2009, 4:04 PM
> design.
> Cris
> <hu… [at] bah.com>
> older Cal 25?
> Cheers
> Charlie
> older Cal 25?
> same reason.
> Chris Campbell
T-Track question
Jeffrey owen2009-03-03 14:10 UTC
Good morning, it has been a while. I am doing a complete refit of a 72 Cal 33. One of the previous owners replaced the original t-tracks for the jib and spinaker, but placed them between the toe rail and the cabin. If anyone has documentation of the original layout of the tracks, I would certainly appreciate it. I believe they were originally installed along the toe rails. Any feedback as to why the change? Any advantage/disadvantage?
BTW, I did a complete core replacement, the deck was not sealed properly before the track installs.
Thanks to all for all the valuable info!
Regards
Jeff
Chris Campbell2009-03-03 14:29 UTC
The original owner of my Cal 20 had installed a clever topping lift. It
runs from the masthead down to the aft end of the boom, through a block,
and then forward along the boom, terminating past the block in a stopper
knot. When you hoist the main, it lifts the boom up and slacks the
topping lift; when you drop the sail, the boom is held up by it. The
stopper knot stops at the block at the end of the boom, and when the
topping lift slacks as the mainsail is raised, a piece of shock cord
pulls the topping lift down and forward, through the block, so it
doesn't flop around annoyingly while you sail. It's a good arrangement
and it meets the budget needs of this guy, a two-boat owner who earns
less than half in a year what the former prez of Citigroup earned in a
day. (I came across that little statistic last night). I think I manage
my boats better than the Citigroup prez managed his company, judging by
its present disarray.
Chris h2009-03-03 14:52 UTC
That's a cool trick. Was wondering how to accomplish that while reading the
manual and learning the rigging configuration. All I can do for now is
read..:(
Re: [Cal_Boats] T-Track question - Core
svadas2009-03-03 15:07 UTC
Jeff,
How did you do the core replacement and what material did you use. I did a core replacement on my boat cutting from the top and used nidacore instead of balsa.
Greg
Sent: Tuesday, March 03, 2009 9:10 AM
Subject: [Cal_Boats] T-Track question
Regards
Jeff
Checked by AVG.
Version: 7.5.557 / Virus Database: 270.11.6/1980 - Release Date: 3/2/2009 11:02 PM
Chris Campbell2009-03-03 15:58 UTC
> reading the
> read..:(
This system uses a little lightweight block shackled to the aluminum
casting end-cap on the boom, or one of the two tangs secured to it. I
have to fiddle with the length of the shock cord running forward so it's
not to badly stretched in the down position and still has enough oomph
to keep the topping lift under control in the up position. The longer
the better.
boom vang fun involving Cal 20s too
Lord Nougat2009-03-03 17:43 UTC
Agh! This stainless plate you mention... it ripped out of my boom two 4th of Julys ago sailing to Long Beach.
I've got a really horrible temporary solution that keeps me worried whenever we're on a reach or run, but I have some big stainless bolts and a replacement plate/pad eye thing. I intend to drill [horizontally aligned] 2 holes all the way through the boom and run the bolts all the way through for maximum strength, but galvanic corrosion is still worrying me. Somebody someplace said to just use teflon tape stuff like the plumbers use but I imagine there is most likely something considerably better suited to this purpose.
Also, I was seriously thinking about getting one of those 'solid' boom vangs [from Garmin is it?] but Jib Kelly said Cal 20 booms are just not made for that and it would be looking for trouble on top of being expensive.
Yeah, so what do you guys use to stave off galvanic corrosion betwixt stainless and aluminium?
Sent: Monday, March 2, 2009 1:42:44 PM
Hi, Peas. I
understand.
Lord Nougat2009-03-03 17:48 UTC
I see those things all the time for cheap at Kelly Marine, which is located conveniently right across the street! So if you end up not finding any near you, I'll go nab one for you and mail it.
Sent: Monday, March 2, 2009 2:04:57 PM
Cris
Nougat and the Galvanics
Husar, Charlie [USA]2009-03-03 18:09 UTC
Dunno, just sounded like a good name for a Doo-Wop group.
Not sure you can stop the corrosion, but dipping the screws into
Lanocote can help.
Behalf Of Lord Nougat
Sent: Tuesday, March 03, 2009 12:43 PM
Subject: [Cal_Boats] boom vang fun involving Cal 20s too
expensive.
of exciting.
the same reason.
really a good plan.
understand.
RE: [Cal_Boats] boom vang fun involving Cal 20s too
jo… [at] peco-energy.com2009-03-03 18:42 UTC
Check out Tef Gel at: http://tinyurl.com/bwwhpd
If the tiny url doesn't work, just google it or bring up the Hall Spars,
Jamestown Distributors, etc. site to check on it.
Jon Myers
Cal 29 Bay Breeze
Ballast @ GOBR
expensive.
of exciting.
the same reason.
really a good plan.
understand.
This e-mail and any of its attachments may contain Exelon
Corporation proprietary information, which is privileged,
confidential, or subject to copyright belonging to the Exelon
Corporation family of Companies.
This e-mail is intended solely for the use of the individual or
entity to which it is addressed. If you are not the intended
recipient of this e-mail, you are hereby notified that any
dissemination, distribution, copying, or action taken in relation
to the contents of and attachments to this e-mail is strictly
prohibited and may be unlawful. If you have received this e-mail
in error, please notify the sender immediately and permanently
delete the original and any copy of this e-mail and any printout.
Thank You.
Re: [Cal_Boats] boom vang fun involving Cal 20s too
Chris Campbell2009-03-03 19:05 UTC
Remember that our spreader brackets are fastened through the mast with a
stainless bolt, but that it has an aluminum tube to prevent crushing the
mast as you secure the nut on the bolt. You'll need something like
that, won't you?
When I replaced my spreader brackets, I either used anhydrous lanolin
from the drug store or whatever grease I had at hand to keep the
aluminum tube and stainless bolt from going to war. The old tube/bolt
were cookin' away, even though I'm, in fresh water (but of course they
had a 40 year head start on hostilities).
Husar, Charlie [USA]2009-03-03 19:12 UTC
The way to use the wishbone (U-strap) is to double nut or nylock nut one
end, so we have a tight bolt without tightening to compress the boom.
The u-bracket should be free to rotate some. All CAL 25s have a
through-bolt on the spreader brackets with compression tube. If one is
doing the v-bracket as described below, through bolting is not advised.
Unfortunately it comes out to be either tapped threads or self tapping
screws on each side.
Sent: Tuesday, March 03, 2009 2:05 PM
Subject: Re: [Cal_Boats] boom vang fun involving Cal 20s too
that, won't you?
r good2009-03-03 19:59 UTC
my Garhauer will and does on my T/2
Date: Mon, 2 Mar 2009 16:46:38 -0800
Cris
dEmO
for @ $95 this:
Cris
Chris h2009-03-03 21:30 UTC
On Tuesday 03 March 2009 14:12:38 Husar, Charlie [USA] wrote:
You can of course try one of these with adjustable slide.
http://www.boomkicker.com/
A guy in here town picked one up for his small starter beneteau at the annual
yacht club flee market (great place to find stuff) for 80 bucks. Loves it.
Chris h2009-03-03 21:34 UTC
On Tuesday 03 March 2009 16:30:35 Chris h wrote:
These guys also have the boom bail that someone was requesting in this thread.
Sorry I cant find it right now so its a bit out of sequence. Looks
interesting.
http://www.seoladair.com/rollingbails/index.html
Whirled Peas2009-03-03 22:15 UTC
Ok, so the U-strap with double nuts/locking nuts on the bolt sounds like the prefered solution. This is the strongest vang mounting design overall, right?
And it sounds like the V-strap is not the strongest arraingement. I was thinking I could pop rivet a V strap. Guess I'll abandone that idea.
Thanks for all the advice.
Cris Capp
Sent: Tuesday, March 3, 2009 11:12:38 AM
Subject: RE: [Cal_Boats] boom vang fun involving Cal 20s too
The way to use the wishbone (U-strap) is to double nut or nylock nut one end, so we have a tight bolt without tightening to compress the boom. The u-bracket should be free to rotate some. All CAL 25s have a through-bolt on the spreader brackets with compression tube. If one is doing the v-bracket as described below, through bolting is not advised. Unfortunately it comes out to be either tapped threads or self tapping screws on each side.
Remember that our spreader brackets are fastened through the mast with a stainless bolt, but that it has an aluminum tube to prevent crushing the mast as you secure the nut on the bolt. You'll need something like that, won't you?
When I replaced my spreader brackets, I either used anhydrous lanolin from the drug store or whatever grease I had at hand to keep the aluminum tube and stainless bolt from going to war. The old tube/bolt were cookin' away, even though I'm, in fresh water (but of course they had a 40 year head start on hostilities) .
Whirled Peas2009-03-03 22:16 UTC
This looks impressive... I think one of these has a destiny with my boom :)
Sent: Tuesday, March 3, 2009 1:34:14 PM
interesting.
http://www.seoladai r.com/rollingbai ls/index. html
Jeffrey owen2009-03-04 14:00 UTC
Greg:
In general areas, I used balsa, and whenever posible, I cut from the bottom, just to avoid all the work involved with finishing the deck. Once installed and glassed, I used a 1" hole saw to remove bottom layer of glass and core where deck hardware screws will be installed, leaving the top glass layer. I filled the holes w/ a mix of epoxy w/ microfibers. By doing it this way, I hope to keep moisture from wetting core again. It is a lot of work, but I think it is well worth it.
Regards
Jeff
Sent: Tuesday, March 3, 2009 11:07:33 AM
Subject: Re: [Cal_Boats] T-Track question - Core
Jeff,
Greg
Good morning, it has been a while. I am doing a complete refit of a 72 Cal 33. One of the previous owners replaced the original t-tracks for the jib and spinaker, but placed them between the toe rail and the cabin. If anyone has documentation of the original layout of the tracks, I would certainly appreciate it. I believe they were originally installed along the toe rails. Any feedback as to why the change? Any advantage/disadvant age?
Regards
Jeff
Checked by AVG.
Re: [Cal_Boats] core, non-skid
Jeffrey owen2009-03-04 15:11 UTC
Greg:
BTW, I never heard of nidacore, could you tell me a little more about it? I am new to all of this, and as a matter of fact, this is my first boat refit, so I am learning a lot along the way, certainly a lot from everything that is discussed here, so any feedback is appreciated.
As far as my "little" boat project, I have begun priming the deck. I sanded down what little original non skid there was. At this time, I am filling pits with fairing compound, to do a final primer coat (hopefully). For non-skid, I am loking at a couple of options. One is Vetus non skid overlay, the other is just a sand non-skid. I thing the first will look better, but I believe the second is just as functional, for a lot less $$$$.
Any thoughts on this or other approaches would be helpfull.
Jeff
Jeff,
Greg
Regards
Jeff
Checked by AVG.
svadas2009-03-04 17:07 UTC
Jeff
Nidacore is a core material used for several different applications including boat decks. It is plastic formed into small honey comb shapes and comes in 4 X 8 sheets. Cut to shape and epoxy into the deck and then glass over. Never again will I have to worry about rotten wood.
I cut the entire deck off the boat and pulled all the balsa out....was extremely wet in several areas and I figured I would do it all with the exception of the foredeck which is nice and dry.
For a non-skid, I looked into several different materials / techniques and ended up buying the original pattern of the non skid, did a reverse mold using gell coat and then epoxied that onto the deck. Finished by spray painting the deck with a quality epoxy paint. A few things I would have done differently in retrospect, but overall happy with the outcome. I have never heard of Vetus non skid....wil have to look it up tonight. The sand was a bit rough on the skin if you had to put a knee down so I stayed away from it.
Greg
Sent: Wednesday, March 04, 2009 10:11 AM
Subject: Re: [Cal_Boats] core, non-skid
Greg:
Jeff
Jeff,
Greg
Regards
Jeff
Checked by AVG.
Checked by AVG.
Version: 7.5.557 / Virus Database: 270.11.7/1982 - Release Date: 3/3/2009 4:09 PM
RE: [Cal_Boats] core, non-skid
r good2009-03-04 17:30 UTC
some boats are now masking out areas and them applying a thin coat of one of the spray or roll on bed liners for nonskid
Date: Wed, 4 Mar 2009 12:07:56 -0500
Jeff
Greg
Greg:
Jeff
Jeff,
Greg
Regards
Jeff
Checked by AVG.
Checked by AVG.
DavidOwen2009-03-04 18:06 UTC
I used sand on a previous iteration and my crew did a lot of
bleeding. I used a water-catalyzed epoxy deck coating and it is very
aggressive without as much bleeding. It can be adjusted with a few
hours and a sander (requires a recoat of paint) but I like my crew
staying on the boat and will live with it.
Wilkie
> Reggie
> From: Sv… [at] optonline.net
> Jeff
> rotten wood.
> Greg
> From: Jeffrey owen
> Greg:
> appreciated.
> Jeff
> From: svadas <Sv… [at] optonline.net>
> Jeff,
> Greg
> From: Jeffrey owen
> Regards
> Jeff
> Checked by AVG.
> 3/2/2009 11:02 PM
> Checked by AVG.
> 3/3/2009 4:09 PM
Re: boom vang recommendations for older Cal 25?
mtkennedy12009-03-04 21:16
--- In Ca… [at] yahoogroups.com, "Husar, Charlie [USA]" <husar_charlie@...> wrote:
> Cheers
> Charlie
I learned that the hard way when we laid the Yankee 38 down in a jibe/broach with the preventer cleated down to the rail. I had to climb the cockpit with the boat on its side to reach the cam cleat and release the preventer. That allowed the boat to come up. We had the masthead (or at least the spreader) in the water at the time.
If you do that, it should be a light line that will break but then you risk a headache from the boom.
We were off Magdalena Bay at the time about 50 miles offshore on the way to Manzanillo.
Those old IOR boats really rolled in a breeze down wind.
Mike Kennedy
Conquest Cal 40 # 96
RE: [Cal_Boats] Re: boom vang recommendations for older Cal 25? (Mike K)
ti… [at] ch2m.com2009-03-04 21:20 UTC
like this?
[cid:349351721@04032009-0EFA]
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of mtkennedy1
Sent: Wednesday, March 04, 2009 1:16 PM
Subject: [Cal_Boats] Re: boom vang recommendations for older Cal 25?
--- In Ca… [at] yahoogroups.com<mailto:Cal_Boats%40yahoogroups.com>, "Husar, Charlie [USA]" <husar_charlie@...> wrote:
> Cheers
> Charlie
Mike Kennedy
RE: [Cal_Boats] Nida-core
ti… [at] ch2m.com2009-03-04 21:32 UTC
So Greg, where did you source the Nida Core material? from the factory or another source?
I have interest in some in the Pacific Northwest, USA. and was looking to avoid shipping a 4x8 sheet from Florida.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of svadas
Sent: Wednesday, March 04, 2009 9:08 AM
Jeff
Greg
Greg:
Jeff
Jeff,
Greg
To: Cal_Boats@yahoogrou ps.com<mailto:Ca… [at] yahoogroups.com>
Regards
Jeff
Checked by AVG.
Checked by AVG.
Re: [Cal_Boats] Re: boom vang recommendations for older Cal 25?
Chris Campbell2009-03-04 21:33 UTC
This, says Chris with a great big grin, is what separates sailing from golf.
Death Rolling IOR Boat (Mike)
Husar, Charlie [USA]2009-03-04 21:40 UTC
Mike, on my 25, when we are in heavy air/water almost by the lee, I try
to twing down the chute to reduce the shoulders. In our Frostbite races
(no chutes allowed) a few weeks ago, we were getting a lot of roll with
wing-on-wing in heavy air. What might you (or others on the list) do to
get out of the rolling (other than jibe and come up). I try to drive
with the rolls (don't fight it), but am always concerned that we will
pull the old accidental jibe and splatter stuff and people all over the
place.
My release trick on a "preventer" is to wrap the vang line around the
shrouds near the base, and have someone hold it. If things go to hell,
the holder just lets go. We have the vang block at the top (at the boom
end).
Cheers, I Guess
Sent: Wednesday, March 04, 2009 4:16 PM
backwinds.
> Cheers
> Charlie
to Manzanillo.
Mike Kennedy
Yahoo! Groups Links
Broach (Timm)
Husar, Charlie [USA]2009-03-04 21:43 UTC
Well almost, Timm. I try to get more water into the chute.
The Olson 30s have just reformed as a Cruising One Design (COD) Class on
the Chesapeake. I will pass this shot on to their Class rep.
Behalf Of ti… [at] ch2m.com
Sent: Wednesday, March 04, 2009 4:20 PM
Subject: RE: [Cal_Boats] Re: boom vang recommendations for older Cal 25?
(Mike K)
like this?
vang,
> Cheers
> Charlie
to Manzanillo.
Mike Kennedy
Re: nidacore
Fred Haas2009-03-04 21:50 UTC
Timmo,
Not nidacore, but Fisheries had a cool product at the Seattle Boat Show
called MultiPanel. The manufacturer's website is www.thermoboat.com. It
may be of interest to you. You could stop and buy me a beverage on your
way home from picking it up in Seattle.
Fred Haas
3-30 Nemesis
Tacoma
RE: [Cal_Boats] Re: nidacore
ti… [at] ch2m.com2009-03-04 21:53 UTC
why stop at one?
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Fred Haas
Sent: Wednesday, March 04, 2009 1:51 PM
Subject: [Cal_Boats] Re: nidacore
Timmo,
Fred Haas
3-30 Nemesis
Tacoma
mtkennedy12009-03-04 22:55
--- In Ca… [at] yahoogroups.com, <timmothy.lessley@...> wrote:
> like this?
Kind of like that. Except the main was backed and holding the boat down until I got the preventer released.
A lot like that, though.
Mike Kenedy
Conquest Cal 4 # 96
Re: Death Rolling IOR Boat (Mike)
mtkennedy12009-03-05 00:00
> place.
> end).
> Cheers, I Guess
> Charlie
We were flying a chicken chute at the time, a starcut 1.5 with narrow shoulders and the sheet pulled down about where the guy was on the other side. Those old IOR boats were a handful. It was probably blowing 40 but the boat wouldn't go over 12 so the apparent never dropped the way it does with a lighter boat, especially a Cal 40.
Mike Kennedy
Sailing and Golf (Chris C)
Husar, Charlie [USA]2009-03-05 04:04 UTC
People have been attacked by alligators on golf courses.
Sent: Wednesday, March 04, 2009 4:34 PM
Subject: Re: [Cal_Boats] Re: boom vang recommendations for older Cal 25?
golf.
Re: [Cal_Boats] Sailing and Golf (Chris C)
Patrick Fiega2009-03-05 04:26 UTC
Mike,
Did the same thing with my Bristol 30 and for the same reasons also. With this knowledge I now bring even the preventer back to the cockpit.
Chris Campbell2009-03-05 15:19 UTC
Which leads to me to conclude that there is justice, after all.
avoiding alligators in his iceboat
Re: [Cal_Boats] Sailing and Golf (Charlie)
Donald Dutton2009-03-05 15:56 UTC
I was attacked by a cottonmouth at Duck Woods CC in North Carolina that narrowly missed my inner thigh! Problem solved with a swift 7-iron!!
Sent: Wednesday, March 4, 2009 8:04:06 PM
Subject: [Cal_Boats] Sailing and Golf (Chris C)
Campbell
Non skid
Jeffrey owen2009-03-06 15:32 UTC
Well, I am the point of deciding what to do about non skid. The deck is completely repaired and primed, and I'd like to pick some brains. After reading about bloody knees, I'mturning away from sand.
I read about kiwi-grip, which seems to be a good altenative - it is a roll on putty used with textured rollers, supplied by the same manufacturer - anyone heard of it? Comments?
Other alternative is Vetus or treadmaster-M non-skid overlay - expensive, but easy to apply (easy is a relative term), apparently very durable, good for boat owners with small children (such as myself).
So, feedback, as usual, is welcome, thanks to all.
Jeff '72 Cal 33
Sent: Wednesday, March 4, 2009 2:06:32 PM
I used sand on a previous iteration and my crew did a lot of bleeding. I used a water-catalyzed epoxy deck coating and it is very aggressive without as much bleeding. It can be adjusted with a few hours and a sander (requires a recoat of paint) but I like my crew staying on the boat and will live with it.
Wilkie
Jeff
Greg
Greg:
Jeff
Jeff,
Greg
Regards
Jeff
Checked by AVG.
Checked by AVG.
