8 messages2009-04-03 00:34 through 2009-04-04 07:14 UTC
walter vee drive
cal46capt2009-04-03 00:34
My vee drive is totally trashed anyone know of a walter r-30 3to 1 for sale let me know
gene
RE: [Cal_Boats] walter vee drive
r good2009-04-03 01:38 UTC
check with Walter. a new one may be a better deal than you think. and faster to get also. Just did the same thing recently.
Wa… [at] aol.com
Date: Fri, 3 Apr 2009 00:34:04 +0000
Subject: [Cal_Boats] walter vee drive
gene
Re: [Cal_Boats] walter vee drive
Tom Vandiver2009-04-03 02:00 UTC
Hi Gene,
How do you mean, "totally trashed"?
My Cal 46 is older than yours, (hull #3 launched in November 1967), has been around the world by the previous owner, Jack Jensen and was alledgedly rebuilt in England in about 1980. I have never had to do anything to mine but change the oil. I did change to 90# in about 1984 and fill to above the top bearing. I have 3,600 hours on it since 1987. I always assure perfect prop shaft alignment.
So far, no problems.
Tom Vandiver
Sent: Thursday, April 2, 2009 7:34:04 PM
gene
Husar, Charlie [USA]2009-04-03 02:41 UTC
Also me. Walter ran off a match to my CAL 40 (don't remember specific
model) five years ago. It cost about $2K.
Behalf Of r good
Sent: Thursday, April 02, 2009 9:38 PM
To: ca… [at] yahoogroups.com
Subject: RE: [Cal_Boats] walter vee drive
Wa… [at] aol.com
sale let me know
gene
Re: walter vee drive
Dan2009-04-03 03:25
I too have a Walters V-drive. Check with Great Lakes Power Products @ 440/951-5111. They repair big trucks, tractors and earth movers. The founder owns the patents on the Paragon transmissions so many of us have. They offered to completely rebuild my trannie for approximately $1,000 and said they could handle the Walters too.
Dan
> gene
Michael Kennedy2009-04-03 03:31 UTC
Walter will rebuild drives. You should check with them.
Mike Kennedy
Conquest Cal 40 # 96
On 4/2/09 7:41 PM, "Husar, Charlie [USA]" <hu… [at] bah.com> wrote:
> Also me. Walter ran off a match to my CAL 40 (don't remember specific model)
> Cheers
> Charlie
> From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf
> Of r good
> Wa… [at] aol.com
> Reggie
> From: ca… [at] yahoo.com
> let me know
> gene
Walter vee drive
cal46capt2009-04-03 13:48
I could rebuild my own drive but the problem is corrosion in the cases
so i guess ill have to get new i have talked with walter already but was trying to see what was out there
Re: [Cal_Boats] Walter vee drive
Tom Vandiver2009-04-04 07:14 UTC
Hi Gene,
I just sold a running take out, Walters RV 30, 1.5 - 1 redux on eBay for $250.
I have another RV 30 attached to an old Paragon gear. The vee drive housing is cracked, but the internals appear okay. I am going to part it out. Paragon gears are hard to find.
"corrosion in the case" ?
Are the gears pitted? Is the cast iron case damaged?
If your case is sound, you may be able to replace, bearings and seals.
Maybe you can use some of the internal parts of my RV30.
Tom Vandiver, Cal 46 & 25, home ported in Baja Alabama
Sent: Friday, April 3, 2009 8:48:01 AM
Subject: [Cal_Boats] Walter vee drive
