Re: [Cal_Boats] Ah, Chemicals(Trich)
Charlie,Yeah it would clean anything. We used it because our stuff had to be LOX clean, we used it by the 55 gal. drum. I don't seem to remember how we disposed of the used stuff; in those days that wasn't an issue. Maybe that's why I can't remember!Just so you know, we are expecting a couple of inches of snow tonight in Chicago, winter doesn't want to leave.
Regards,Dave Dobbs
--- On Wed, 4/1/09, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: [Cal_Boats] Ah, Chemicals
Date: Wednesday, April 1, 2009, 7:42 PM
"I used trichloroetheleyne on a daily
basis without gloves."
Bingo,
David. Moi aussi. Damn, that was a good cleaner. Used it on
printed circuit boards. Did you have your own ball of mercury as a
child? Sure was fun to play with. Then there were the stamp
collection watermark detectors where you (or I) dripped carbon
tetrachloride over stamps on a dark card while poring over the result at very
close range. Hell, I'm gonna go install asbestos insulation in my
boat. Then I'll have my tofu sandwich. After all, don't want to get
fat.
[mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of david
dobbs
Sent: Wednesday, April 01, 2009 7:07 PM
To:
Cal_Boats@yahoogrou ps.com
Subject: Re:
[Cal_Boats]( TSP)
Timm,
If it don't have the "P", (the element phosphorus). in the compound
it ain't TSP.Tri Sodium Phosphate. It also don't clean the same.
I have Real TSP in my basement which I use with care when I need it.
The stuff they sell now as TSP is junk. I also have real
chlordane in my garden shed, only use that sparingly. I guess that
means I am a A Superfund site. My body is probably also a public
danger, when employed(?) by the USAF I used trichloroetheleyne on a daily
basis without gloves. Hey, I can't work in those clumsy things.
But so far I am disease/condition free except for my Scotch
addiction. And my sailing addiction.
Regards,
David Dobbs, Cal29 411
--- On Wed, 4/1/09,
timmothy.lessley@ ch2m.com <timmothy.lessley@ ch2m.com>
wrote:
timmothy..lessley@ ch2m.com <timmothy.lessley@ ch2m.com>
Subject:
[Cal_Boats]
1, 2009, 2:36 PM
Well then, I guess the boat will be
dirty?
That still leaves the 11 beers to be
consumed.
A pressure washer is only water delivered at a high
force and low volume - I would think that this method would be mandatory
if water usage was a concern..
Most at home units are not nearly powerful enough
to lift bonded caulking... if it is loose and leaking - needing
replacement then maybe.
I wonder how people wash dishes on board, all sinks
I am familiar with drain into the water....
Maybe "Phosphate free" TSP is okay, since it
is not a soap (foaming) and is a cleaner of gunk. (MSDS
attached)
Phosphate-Free
TSP-PF
A heavy duty cleaner with the equivalent
cleaning power of TSP for use where phosphate cleaners are
prohibited. The phosphate-free formula also removes heavy
deposits of greasy grime, smoke, soot stains and chalked
paint from walls, woodwork and floors. Cleans and restores
weathered and mildewed decks and siding. Removes mildew and
mildew stains when mixed with bleach. Also cleans remover
sludge and prepares surfaces for
repainting.
Dan
Sent: Wednesday, April 01, 2009 12:05 PM
To:
Subject: [Cal_Boats] Re: Cleaning
Gelcoat
dEmO:
If we followed these cleaning instructions here in the Puget
Sound, the enviro-mental wackos would have us arrested for assault of
Sacred Mother Earth! My first mate and I are very concerned about the
environment and really are very careful boatowners but these folks are
clearly trying to get ALL boats out of the water. It's reached a state
of being unreasonable.
Our marina does not allow soap of ANY kind,
including the Green Soap which we usually use. Pressure washing is also
discouraged for its damage to something or other.(I'm concerned about
opening up stantion and chain-plate seals with pressure washing
anyway..)
We are told to use plain water and elbow grease. Or wash at
night when the enviro-mental wackos are in earth church. Oxalic acid!
They'd keel haul us except for all the blood!
Dan
--- In Cal_Boats@yahoogrou
ps.com, <timmothy.lessley@ ...> wrote:
> Not an
expert at this one.
> Typically I try things until
something works best.
> I also may not be environmentally
friendly?
> General Deck Cleaning steps:
1. pressure washer pre-wet and get big bird poop spots off
> 2.
spray laundry bleach mostly on the stained areas or fiberglass.. avoid
soaking bare wood, stainless.
> 3.. moisten deck again to flow
bleach.
> 4. per the Cal factory manual, sprinkle laundry (Tide)
soap on the wet decks
> 5. Pressure wash at high power to get most
of the stains lifted.
> Go below and look for
leaks
> 6. Go back over with a scrubber brush and Oxalic
acid (Bar Keepers Friend) to get the black or rust spots
> 7. Hit
hard rust spots with Phosphoric acid (Naval Jelly) do not let the pink
jelly dry as it can stain a pink color. Repeat Step 6.
> 8. using
MEK or Acetone, hit greasy spots or real hard black sole marks. Repeat
Step 6.
> 9. have a pick and or tooth brush to get into groove or
joints, pick off caulking or varnish.
> 10. Dry and clean metal
parts and cables - w/WD 40 and a microfiber rag
> 11. Compound
& wax smooth surfaces. (Meguires or 3M)
> Get into
the hot tub, and enjoy the view!
> dEmO
> ____________ _________ _________ __
> From: Cal_Boats@yahoogrou
ps.com [mailto:Cal_Boats@yahoogrou
ps.com] On Behalf Of John
> Sent: Tuesday, March 31, 2009 3:16
PM
ps.com
> Subject: [Cal_Boats] Cleaning Gelcoat
> Hi all,
> Well, after much effort (and, of
course, money) I have managed to get my Cal 31 back to working order!
(rebuilt transmission, shaft, cutless bearing and motor mounts) However,
this ordeal left her seriously soiled with lots of grease and oil stains
in the cockpit. She's also got a number of places that are just
oxidized, ugly areas that need a serious cleaning. What are your
prefered methods/products for handling these problems? Your assistance
will be greatly appreciated!
> Thanks,
> John
Stacklyn
> Cal 31 #33 "Sol Survivor"
> Shell Point,
FL
