5 messages2009-04-07 02:17 UTCthrough 2009-04-07 13:27 UTC
Main Halyard Sheave for Cal 29
sa… [at] aol.com2009-04-07 02:17 UTC
Hi everyone - I have a 1970 Cal 29, #154 and have what appears to be a
problem sheave for my mainsail halyard - its the original as far as I can see and
am looking to replace it. First I will pull the pin and take a look, to make
sure the pin is not bad, but has anyone recently replaced theirs and what did
you use, where did you buy it? I thought this was a recent post but I cant
find it in my storage of emails, any help appreciated...
Shelley Richards
Seven Sisters Cal 29
1970 #154
Wilson NY
**************A Good Credit Score is 700 or Above. See yours in just 2 easy
steps!
(http://pr.atwola.com/promoclk/100126575x1221621488x1201450096/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID
%3D62%26bcd%3DAprilfooterNO62)
RE: [Cal_Boats] Main Halyard Sheave for Cal 29
Husar, Charlie [USA]2009-04-07 02:42 UTC
Need to get the measurements on the sheave, Shelley. We had a batch
made for the CAL 25s in Annapolis by a local shop. Oilite bearing
centers and all. Info needed is:
-External diameter
-Thickness
-Diameter of pin
Do you still use wire halyards? This determines the type of groove.
The sheaves may be different sizes (aft main larger).
It is very hard to mess with these things while the mast is up. Parts
make the cutest little "blip!" when they hit the water.
Behalf Of sa… [at] aol.com
Sent: Monday, April 06, 2009 10:18 PM
Subject: [Cal_Boats] Main Halyard Sheave for Cal 29
can see and am looking to replace it. First I will pull the pin and take
a look, to make sure the pin is not bad, but has anyone recently
replaced theirs and what did you use, where did you buy it? I thought
this was a recent post but I cant find it in my storage of emails, any
help appreciated...
Shelley Richards
1970 #154
Wilson NY
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
<http://pr.atwola.com/promoclk/100126575x1221621488x1201450096/aol?redir
6hmpgID%3D62%26bcd%3DAprilfooterNO62">
Re: [Cal_Boats] Main Halyard Sheave for Cal 29
Terrence Spencer2009-04-07 03:00 UTC
I replaced mine a few years ago and used Zephyrwerks. The fellow who does
this is great. Send him your old ones and he will make you up some new.
Link as follows:
http://www.zephyrwerks.com/Sizing.asp
Terry Spencer
Cal 2-29
Capriccio
Tacoma
Reply-To: Ca… [at] yahoogroups.com
Date: Mon, 6 Apr 2009 22:17:40 EDT
see and am looking to replace it. First I will pull the pin and take a look,
to make sure the pin is not bad, but has anyone recently replaced theirs and
what did you use, where did you buy it? I thought this was a recent post but
I cant find it in my storage of emails, any help appreciated...
Shelley Richards
1970 #154
Wilson NY
<http://pr.atwola.com/promoclk/100126575x1221621488x1201450096/aol?redir=htt
p:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%
DavidOwen2009-04-07 03:59 UTC
Shelley,
I replaced mine a couple of years ago and used a high tech company
from Washington called Zephyrworks. Not cheap, but they made custom
sheaves to fit my rope halyards.
wilkie
> a problem sheave for my mainsail halyard - its the original as far
> as I can see and am looking to replace it. First I will pull the pin
> and take a look, to make sure the pin is not bad, but has anyone
> recently replaced theirs and what did you use, where did you buy it?
> I thought this was a recent post but I cant find it in my storage of
> Shelley Richards
> 1970 #154
> Wilson NY
r good2009-04-07 13:27 UTC
http://www.rigrite.com/
Date: Mon, 6 Apr 2009 22:42:29 -0400
Subject: RE: [Cal_Boats] Main Halyard Sheave for Cal 29
Need to get the measurements on the sheave, Shelley. We had a batch made for the CAL 25s in Annapolis by a local shop. Oilite bearing centers and all. Info needed is:
-External diameter
-Thickness
-Diameter of pin
It is very hard to mess with these things while the mast is up. Parts make the cutest little "blip!" when they hit the water.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of sa… [at] aol.com
Hi everyone - I have a 1970 Cal 29, #154 and have what appears to be a problem sheave for my mainsail halyard - its the original as far as I can see and am looking to replace it. First I will pull the pin and take a look, to make sure the pin is not bad, but has anyone recently replaced theirs and what did you use, where did you buy it? I thought this was a recent post but I cant find it in my storage of emails, any help appreciated...
Shelley Richards
1970 #154
Wilson NY
