2 messages2009-04-12 17:37 through 2009-04-12 19:50 UTC
Asym Spinnaker
wheee_dogggie2009-04-12 17:37
I am trying to find anyone out there with experience flying an asymmetrical spinnaker. I am familiar with a symmetrical but not the correct way to rig an asym. Went sailing with a friend on his new "family friendly" boat that was equipped with a spinnaker but not all of the needed running rigging. One item that I found to be different was that it had a short line attached to the clew but no place on the bow to connect.
We were able to fly it and it worked great, however it felt like we were just guessing as to the correct way to rig it.
Any ideas?
Patrick
s/v L'Esprit Libre
Cal 40
Re: [Cal_Boats] Asym Spinnaker
Matt Beland2009-04-12 19:50 UTC
The one's I've seen (not many) mostly just attached to a shackle at
the base of the headstay. But the best system is on a friend's
mid-80's Hunter; he has an old spinnaker pole with a ring on deck and
a bail on the bow roller. To fly the spinnaker, just slide the pole
out through the bail and lock it into the ring (same fitting as a
spinnaker car but fixed at deck level.) The spinnaker then flies from
the end of the pole as a bowsprit.
That not only makes the spinnaker much more effective and even easier
to tack, but it's also cheap and easy to rig - the pole was a broken
one with a sleeve welded over the break (and positioned so the sleeve
is under the bail at the point of max stress) and the rest is pretty
minimal. The spinnaker and sheets were the only significant costs
required.
> Any ideas?
> Patrick
> s/v L'Esprit Libre
> Cal 40
> Yahoo! Groups Links
Matt Beland
ma… [at] rearviewmirror.org
