RE: [Cal_Boats]Monel, UHDPE, Salsa, rigging (Charlie)
Charlie,
I guess that's my point, as far as I know there's no such thing as a dyneema bolt, although dyneema has a higher tensile strength than steel, or, at least, stainless steel cable of the same diameter.
--- On Sun, 4/19/09, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: RE: [Cal_Boats]Monel, UHDPE, Salsa, rigging, was: cal20 bulkheads
Date: Sunday, April 19, 2009, 4:48 AM
Hi, Jerry. Here is what I
got from McMaster-Carr web site. Don't know much about these
things.
About Plastic Cap Screw Material Types
Plastic Type
Features
Kynar
Possesses excellent corrosion and chemical resistance. Also known as
PVDF (polyvinylidene fluoride), it's a tough and durable material.
Nylon 6/6
This nonconductive material resists chemicals and solvents, except
mineral acids.
PTFE
Has high dielectric properties, so it's perfect for electrical
applications. Resists moisture and chemicals, and has excellent mechanical
properties.
PVC
Provides excellent corrosion resistance against weak acids, alkalies,
and alcohols.
[mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Gerald
Sobel
Sent: Sunday, April 19, 2009 3:06 AM
To:
Cal_Boats@yahoogrou ps.com
Subject: Re: [Cal_Boats]Monel, UHDPE, Salsa,
Monel bolts? OK, What about Ultra High Density
Polyethylene? My new centerboard will be suspended by a cable of such
stuff, no more worries about corroding copper swedges!!!! That was the
down fall of my old one (no pun intended). Does anyone make UHDPE
fastners? If not, why not? And why not UHDPE instead of carbon fiber? I
bet it wouldn't fail catastrophicly, maybe just creep to death if it is
woven. And what about the new "ultra-high strength concrete? Sounds like
good centerboard material. Gotta check this out.
PS BTW my
main halyard is SK75 Dyneema, 1/8" fits nicely into the groove of my
halyard sheave. (it might be the old SK60, all I know is it was called
Amsteel, and has a silver color to it). The latest stuff is SK78, heated
and prestreached, it has less streach and creep than SK 60 and
70.
BTW, anyone use New England rope Salsa single braid for genoa
sheets? What about those new synthetic thimble style shackles? There are
new ones out that look like miniature hangmen's knots with a little tiny
line to disengage them.
--- On Sat, 4/18/09, Lord Nougat
<lord_nougat@ yahoo.com> wrote:
Lord Nougat <lord_nougat@ yahoo.com>
cal20 bulkheads
Date: Saturday,
April 18, 2009, 7:16 PM
Seriously? Monel can handle those kinds of loads?
Either
way, I'm considering changing my name to chris.
(MAS Consulting) <masconsult@cox. net>
ps.com
Sent: Saturday,
April 18, 2009 12:57:14 PM
Subject: Re: [Cal_Boats] cal20
bulkheads
I believe that better than SS is monel for
Cal 20 keel bolts.
Original Message -----
chris
h
To:
Cal_Boats@yahoogrou
ps.com
Sent:
Saturday, April 18, 2009 11:42 AM
Subject:
Re: [Cal_Boats] cal20 bulkheads
On Saturday 18 April 2009 14:06:57 Lord Nougat wrote:
> Cal
20s are wonderful. My comment would be: Congratulations!
Here's
a summary of an offline conversation I had with a lad who works at
Schooner Creek repairing CAL-20's. There is quite a large fleet up
there.
One thing that is not in the discussion is the cost of
keel bolts. Most of the
stuff I need to fix up my boat will be
purchased from Steve Seals so I don't
mind saying that if you drop
the quality of stainless steel on the bolts to
one grade lower you
save over a 100 bucks and available anywhere. Personally,
I don't
think it makes a difference if the bolts are properly sealed and
routinely checked.
The bolts specs are here:
http://www.go2marin e.com/search.
do?q=fasco+ screw+30995& x=21&y=13
Fasten All in
Canada has the same bolts in a lower quality of SS for 17CDN a
piece which means I also don't have to deal with the 20 percent
exchange
rate.
Best of luck, they are very nice
boats.
BTW...if you do buy a CAL-20 I think you will be either
the 4th or 5th Crhis
on the list with a CAL-20, its getting rather
weird, as Chris's seem to like
CAL-20's. Perhaps we should run a
pole or something on the yahoo page to see
what the names of other
owners are on this list with a CAL-20
Enjoy the boat.......she'
s sweet.
Information from ESET NOD32 Antivirus, version of virus signature
database 4018 (20090418) __________
The message was checked by
ESET NOD32 Antivirus.
http://www.eset.
com
