8 messages2009-04-21 15:51 UTCthrough 2009-04-21 21:09 UTC
Re: [Cal_Boats] Re: Replacing Interior Vinyl on Cabin Walls
Rodney G Johnson2009-04-21 15:51 UTC
If the ceiling was already done, why are you planning to redo it? Or are
you removing the vinyl from the overhead? Your boat must look nice with
all the wood slats covering the ceiling, as well as all the bulkheads (I
assume that you mean bulkheads when you say "walls"? Houses have walls,
boats have bulkheads). The ceiling on a boat is the covering for the
inside of the hull.
As far as the idea of smoothing the hull interior surface with thickened
epoxy, then painting it....I regularly watch SHIPSHAPE-TV with John
Griviscus and he did exactly that on the inside of the hulls of several
of his fiberglass powerboats (well, he does things a bit fancy at times,
so used AWLGRIP, but still basically the same process!) and it sure
worked for him. I would think that the large flat areas of a powerboat
hull would flex at least as much as our old CAL hulls, if not more! He
used epoxy thickened with a mixture of microballoons and coloidial silica
fillers. You may be able to purchase a copy of that episode from his web
site, it aired about 5 years ago though.....worth checking though!
The early (ours was a 1970) CAL 21s were built with a layer of smooth
fiberglass cloth as the innermost layer of the hull laminate and this was
sanded and painted. It looked good and was easy to maintain. (that awful
paint/resin/glop coating everyone talks about was only on the overhead
and stood up fine on our boat...except on the underside of the cockpit
seats. That was down over the quarterberths, so wasn't really visible!)
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II #10201
and former co-owner of "NODROG"
1970 CAL 21 #285
On Tue, 21 Apr 2009 10:46:24 -0400 pw… [at] aol.com writes:
Okay,
So what I'm hearing is that don't attempt this job in August, wait until
the boat is on the hard, dress warm and attack the removal in January in
subfreezing temps. I was told not to go back with vinyl from someone not
on the list as the same thing will eventually happen again. I am leaning
toward West Systems epoxy with the 410 lightweight filler to smooth out
the texture in the walls and will paint it when done. I just hope that
it will flex enough not to crack. The ceiling was done with wood slats
by the previous owner as was the aft, port cabin wall and the v-berth
walls so all I have to do is the main saloon and the inside, aft cabin
wall.
This job is a long way off so I'm still willing to consider other ideas.
Thanks -
Paul
Free quote and debt consolidation information. Click Here.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTIk3kPfsppJmIqZHqAOutxZTwh07iWOA7DKhiumMW2IZC7zxypsFi/
pw… [at] aol.com2009-04-21 16:09 UTC
I'm not re-doing the ceiling, just the saloon walls between the ports (don't think this is called a bulkhead is it?) and the aft innermost wall (for clarification, aren't bulkheads perpendicular to the hull? ) of the aft cabin. The vinyl runs all the way under the decks and forms the ceiling of the cabinets.
Thanks -
Paul
Sent: Tue, 21 Apr 2009 11:51 am
Subject: Re: [Cal_Boats] Re: Replacing Interior Vinyl on Cabin Walls
If the ceiling was already done, why are you planning to redo it? Or are you removing the vinyl from the overhead? Your boat must look nice with all the wood slats covering the ceiling, as well as all the bulkheads (I assume that you mean bulkheads when you say "walls"? Houses have walls, boats have bulkheads). The ceiling on a boat is the covering for the inside of the hull.
As far as the idea of smoothing the hull interior surface with thickened epoxy, then painting it....I regularly watch SHIPSHAPE-TV with John Griviscus and he did exactly that on the inside of the hulls of several of his fiberglass powerboats (well, he does things a bit fancy at times, so used AWLGRIP, but still basically the same process!) and it sure worked for him. I would think that the large flat areas of a powerboat hull would flex at least as much as our old CAL hulls, if not more! He used epoxy thickened with a mixture of microballo
ons and coloidial silica fillers. You may be able to purchase a copy of that episode from his web site, it aired about 5 years ago though.....worth checking though!
The early (ours was a 1970) CAL 21s were built with a layer of smooth fiberglass cloth as the innermost layer of the hull laminate and this was sanded and painted. It looked good and was easy to maintain. (that awful paint/resin/glop coating everyone talks about was only on the overhead and stood up fine on our boat...except on the underside of the cockpit seats. That was down over the quarterberths, so wasn't really visible!)
1970 CAL 21 #285
On Tue, 21 Apr 2
Okay,
So what I'm hearing is that don't attempt this job in August, wait until the boat is on the hard, dress warm and attack the removal in January in subfreezing temps. I was told not to go back with vinyl from someone not on the list as the same thing will eventually happen again. I am leaning toward West Systems epoxy with the 410 lightweight filler to smooth out the texture in the walls and will paint it when done. I just hope that it will flex enough not to crack. The ceiling was done with wood slats by the previous owner as was the aft, port cabin wall and the v-berth walls so all I have to do is the main saloon and the inside, aft cabin wall.
Thanks -
Paul
RE: [Cal_Boats] Re: Replacing Interior Vinyl on Cabin Walls
ti… [at] ch2m.com2009-04-21 16:15 UTC
West with 410 is a little brittle verses some of the other fillers, but I think if your boat flexes enough to break the 410 combination, you have other problems.
410 sands incredibly easy, so this project should go faster than you might think. Oddly when you have the nice thick 410 (heavy peanut butter) mixture, it tend to kick over fairly fast when in the mixing pot.
Consider keeping the mass of mixture "small" by mixing in a larger pot or on a sheet of plastic to slow down the kicking process.
We always use 205 fast catalyst in the Northwest.. so once you get started you should plan on moving fast with a fairly wide spreader.
Once the mixture starts to kick, you'll see pock marks while you are toweling, so you have to spread real slow, and maybe have to stop.
It usually take two to three layers to get a smooth surface.
A scratch coat to make the overall surface, then a blend coat to fill in any air bubbles and low spots, then a final coat to make a uniform system.
Each successive coat is sanded by a finer grain of sandpaper.
If you have ever done auto body work, this is similar and easier.
dEmO
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Rodney G Johnson
Sent: Tuesday, April 21, 2009 8:51 AM
As far as the idea of smoothing the hull interior surface with thickened epoxy, then painting it....I regularly watch SHIPSHAPE-TV with John Griviscus and he did exactly that on the inside of the hulls of several of his fiberglass powerboats (well, he does things a bit fancy at times, so used AWLGRIP, but still basically the same process!) and it sure worked for him. I would think that the large flat areas of a powerboat hull would flex at least as much as our old CAL hulls, if not more! He used epoxy thickened with a mixture of microballoons and coloidial silica fillers. You may be able to purchase a copy of that episode from his web site, it aired about 5 years ago though.....worth checking though!
1970 CAL 21 #285
On Tue, 21 Apr 2009 10:46:24 -0400 pw… [at] aol.com<mailto:pw… [at] aol.com> writes:
Okay,
Thanks -
Paul
Free quote and debt consolidation information. Click Here.<http://thirdpartyoffers.juno.com/TGL2142/fc/BLSrjpTIk3kPfsppJmIqZHqAOutxZTwh07iWOA7DKhiumMW2IZC7zxypsFi/>
Rodney G Johnson2009-04-21 16:35 UTC
That IS the ceiling.
Ceiling is what lines the insides of the hull, overhead is what we call a
"ceiling" on land. Bulkheads are usually perpendicular to the centerline
of the boat, unless it is a big boat and has "walls" that divide the
interior and run fore & aft, in that case those are also known as
bulkheads. So, I guess the true definition of a bulkhead is the same as a
partition on land....as well as a structural panel perpendicular to the
centerline. Basically, walls on land are bulkheads on a boat, unless we
are referring to the inside surfaces of the hull, then they are ceiling.
If the vinyl areas being replaced are covering the inside surface of the
cabin trunk (not the hull) then they are usually known as...........OK,
you got me there! I've always called that area "the inside of the cabin
trunk sides".......I'm not really sure what the correct term is...?
Anyone wish to chime in here? Occasionally even "know-it-alls" need help!
Rod Johnson
On Tue, 21 Apr 2009 12:09:35 -0400 pw… [at] aol.com writes:
Thanks -
Paul
inside of the hull.
Griviscus and he did exactly that on=2 0the inside of the hulls of
checking though!
=0 A
1970 CAL 21 #285
Okay,
wall.
Thanks -
Paul
_______ _____________________________________________________
Green cleaning products -- do they work as well? Find out now!
Can't pay your bills? Click here to learn about filing for bankruptcy.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTLjhZ3FV5tXDu1VGcjm04b4YpuooGigwDj3FlmwhvCAOi6lkfBGuc/
DavidOwen2009-04-21 16:53 UTC
Nautical Jargon can be a killer.... like the story of the new crew
who was told to trim the main sheet.
"When we tack, just pull in this line, but don't make it fast." In
the tack the main was flogging wildly and the skipper looked at the
new crew and he was pulling the main sheet in _very slowly_.
So -- the "ceiling" is the covering on the inside of the Hull while
the Overhead is the underside of the deck more or less. Technically,
even the cabin sole was part of the ceiling, as it covered floors and
ribs.
Dating back to wooden boat terminology, many smaller craft did not
have ceilings as the inside of the hull is visible between the ribs,
floors etc. Taking this forward to fiberglass construction, Mariposa
had a teak ceiling when I bought her (prior owner installed firring
strips and battens) but it's been stripped and she has no ceiling at
all now.
Wilkie
> Thanks -
> Paul
> -----Original Message-----
> From: Rodney G Johnson <rj… [at] juno.com>
> with John Griviscus and he did exactly that on=2 0the inside of the
> 1979 O'DAY DS II
> #10201
> =0 A
> "NODROG"
> 1970 CAL 21 #285
> Okay,
> ideas.
> Thanks -
> Paul
> ____________________________________________________________
pw… [at] aol.com2009-04-21 18:58 UTC
Those of you who removed your vinyl . . . was it sandwiched between the port frames? My ports are painted aluminum and I'd like to remove them and repaint them while I'm at it to make it easier to sand the interior between them as well as making the ports look better but may not have that much time available to get involved in re-bedding all the ports.
Thanks -
Paul
197
0 CAL 21 #285
Okay,
Thanks -
Paul
Wayne Gillikin2009-04-21 19:18 UTC
The ports on my 39 have an aluminum trim feature that allowed me to remove the vinyl without compromising the bedding seal. The PO had re-bedded the ports just prior to sale and I didn't want to undo that job because of the vinyl. The vinyl job is nasty enough.
Regards,
Wayne
Sent: Tuesday, April 21, 2009 2:58:48 PM
Thanks -
Paul
As far as the idea of smoothing the hull interior surface with thickened epoxy, then painting it....I regularly watch SHIPSHAPE-TV with John G riviscus and he did exactly that on the inside of the hulls of several of his fiberglass powerboats (well, he does things a bit fancy at times, so used AWLGRIP, but still basically the same process!) and it sure worked for him. I would think that the large flat areas of a powerboat hull would flex at least as much as our old CAL hulls, if not more! He used epoxy thickened with a mixture of microballoons and coloidial silica fillers. You may be able to purchase a copy of that episode from his web site, it aired about 5 years ago though.....worth checking though!
The early (ours was a 1970) CAL 21s were built with a layer of smooth fiberglass cloth as the innermost layer of the hull laminate and this was sanded and painted. It looked good and was easy to maintain. (that awful paint/resin/ glop coating everyone talks about was only on the overhead and stood up fine on our boat...except on the underside of the cockpit seats. That was down over the quarterberths, so wasn't really visible!)
; 1979 O'DAY DS II #10201
1970 CAL 21 #285
On Tue, 21 Apr 2009 10:46:24 -0400 pwestla@aol. com writes:
Okay,
Thanks -
Paul
____________ _________ _________ _________ _________ _________ ___
Chris Campbell2009-04-21 21:09 UTC
Does anybody know what this stuff was? It's a perplexing goop because
it's tenacious as hell where it wants to be, and just flakes off
elsewhere. It's resistant to all but the strongest, smelliest paint
removers. Ugh.
