4 messages2009-04-28 22:59 UTCthrough 2009-04-29 23:57 UTC
Mast Wiring, et al
david dobbs2009-04-28 22:59 UTC
Listees,
All your mast wiring and rigging problems could be solved easily. Move to the Midwest. We take our masts down every Fall and put them back up in Spring. Gives you time to fix any problems, make improvements, etc. Course the weather is limiting, but we have all this white, fluffy stuff in Winter, you could get to like it. Well, I do have to admit it does get a trifle cold, but hey, down jackets. Bring your skis.
My apple trees have begun blooming, and I think I'll mow tomorrow. Thursday I'll be at the boatyard.
Regards,
David Dobbs, Cal29 411
Re: [Cal_Boats] Mast Wiring, et al
chris h2009-04-29 11:29 UTC
On Tuesday 28 April 2009 18:59:55 david dobbs wrote:
> Listees,
> trifle cold, but hey, down jackets. Bring your skis. My apple trees have
> boatyard.
> Regards,
Iv often wondered about that. Here in the North (North shore of Lake Ontario)
we always remove the masts. Yet strangely enough, on the South Shore the
masts always stay up when the boats are pulled. While it is a cost savings to
some degree I guess it really deters the owner from fully inspecting and
working on the mast and associated accoutrement's each spring. Whats more
interesting is when i see hurricane damaged boats from further south and
ofter wonder if the boats on the hard would not be better off with the stick
down and boats secured with additional straps anchored into the the ground.
Certainly would not hurt if liive in a hurricane prone area.
Chris Campbell2009-04-29 14:19 UTC
> Ontario)
Here in Michigan, both styles are seen. My Cal gets trailered away in
the fall and my Seafarer lives indoors all winter, so their masts are
unstepped. For boats stored outdoors, you see both choices where I am.
Leaving the stick up is cheaper, but you get weathering on your halyards
and mast paint (if any) all winter, and as you note, there's no
opportunity to have a look at things aloft (unless you have a skinny
dimwit who's willing to go up in the bosun's chair). There was some
discussion about physical problems with leaving the mast up. Some
people recommended slacking the standing rigging on the theory that it
would contract in the cold, but if you have an aluminum mast, it
probably shortens more than the stainless wire anyway. Of more concern
is the fact that a boat in a cradle or on poppets cannot move so as to
cushion wind forces on the mast and standing rigging. In the water, the
boat can move and heel a little when a gust hits the mast. On shore, it
cannot, and it's much less well supported, too.
RE: [Cal_Boats] Mast Wiring, et al
John Boyce2009-04-29 23:57 UTC
It seems that most people in Buffalo leave their masts up every year,
several years ago one of my competitors and I were talking about the merits
of taking your mast down and he said he was taking his down for the first
time in five years to check the rigging. I don't think it was part of his
plan but it came down on the first weather leg the next day. I take my mast
down every year using four of my friends and our club gin pole, local
marinas charge about $150 each way for a 27' Cal.
Of chris h
Sent: Wednesday, April 29, 2009 6:30 AM
Subject: Re: [Cal_Boats] Mast Wiring, et al
> Listees,
in
> boatyard.
> Regards,
Ontario)
to
