Cal 20 Spinnaker hardware locations
5 messages2009-05-06 17:08 UTCthrough 2009-05-07 20:56 UTC
Chris Gossett2009-05-06 17:08 UTC
Howdy from Texas! I was wondering if one of my fellow Cal 20 sailors could tell me the dimensions and location of their Spinnaker track (how far off the deck is it mounted and how long is it)? I addition, how high off the deck is the block for the topping lift mounted? The bottom of my broken mast seems to have walked away and taken the attached hardware with it. Thanks in advance for helping me not reinvent the wheel. And yes I am another Chris with a Cal 20! --Chris
Re: [Cal_Boats] Cal 20 Spinnaker hardware locations
Chris Campbell2009-05-06 17:18 UTC
Chris Gossett wrote: > > > > Howdy from Texas! > > I was wondering if one of my fellow Cal 20 sailors could tell me the > dimensions and location of their Spinnaker track (how far off the deck > is it mounted and how long is it)? I addition, how high off the deck is > the block for the topping lift mounted? > > The bottom of my broken mast seems to have walked away and taken the > attached hardware with it. > > Thanks in advance for helping me not reinvent the wheel. > > And yes I am another Chris with a Cal 20! > We Chrises do have the best taste in boats, don't we? My Cal 20 has spinnaker gear but it's out in the storage yard under a cover. If it's not raining tonight, I'll be going out to do some work, and I'll try to remember to measure then. My spring projects include varnishing the rudder and tiller, spot-priming and fairing the keel, adding some bottom paint, and waxing the topsides. The other project is getting a diver to replace my mooring chain. The winter ice, heavier than we're accustomed to in recent years, tore off my winter buoy. The chain was getting a bit worn anyway, so I'm going to just go ahead and replace it. Chris Campbell > > > -- >
Chris Campbell2009-05-07 13:08 UTC
Chris Gossett wrote: > > > > Howdy from Texas! > > I was wondering if one of my fellow Cal 20 sailors could tell me the > dimensions and location of their Spinnaker track (how far off the deck > is it mounted and how long is it)? I addition, how high off the deck is > the block for the topping lift mounted? > I rolled back the cover last night and measured the track. On my boat, the bottom is 41" above the bottom of the mast's bottom aluminum casting, and it's 34" long. I did not notice your inquiry about the topping lift block so I did not measure that. Maybe this weekend if nobody else replies. Chris Campbell > >
Chris Gossett2009-05-07 16:26 UTC
>>Chris Gossett wrote: >> Howdy from Texas! >> >> I was wondering if one of my fellow Cal 20 sailors could tell me the >> dimensions and location of their Spinnaker track (how far off the deck >> is it mounted and how long is it)? I addition, how high off the deck is >> the block for the topping lift mounted? >> > Chris Campbell wrote: > I rolled back the cover last night and measured the track. On my boat, > the bottom is 41" above the bottom of the mast's bottom aluminum > casting, and it's 34" long. > > I did not notice your inquiry about the topping lift block so I did not > measure that. Maybe this weekend if nobody else replies. > > Chris Campbell Thanks Chris. I imagine that as long as the topping lift block is around halfway between the center of the spinnaker track top and the halyard block that it should do its job. Having said that if you do get back out there it would be nice to know for sure. Thanks again for your help! --Chris
Chris Campbell2009-05-07 20:56 UTC
Chris Gossett wrote: > > > > > > I imagine that as long as the topping lift block is around halfway > between the center of the spinnaker track top and the halyard block that > it should do its job. Having said that if you do get back out there it > would be nice to know for sure. > I just tried to find a photo on my computer (no luck) but I wonder if the block is attached at the lower end of the diamond stays. I can't remember offhand what kind of attachment point it uses there--tangs or what--but maybe there's a cast fitting there that the block is secured on? Chris Campbell > >
