More on Cal 20 Spinnaker hardware locations
3 messages2009-05-07 23:19 UTCthrough 2009-05-08 16:31 UTC
Chris Barszcz2009-05-07 23:19 UTC
Hi Everyone, Any chance to go row out to the boat is a good excuse, so in spite of the damp weather, here are the dimensions on my Cal20. The spinnaker track starts 47" above the mast step and is 25" long. That puts the top of the track around 72". It's another 62" to the topping lift pulley, about 134" total. The other way to look it is the topping lift is just below the spreader brackets. Photo attached for reference. Hope this helps. Chris Barszcz of the Cal20 Club :)
Re: [Cal_Boats] More on Cal 20 Spinnaker hardware locations
Chris Campbell2009-05-08 13:07 UTC
Chris Barszcz wrote: > > > Hi Everyone, > > Any chance to go row out to the boat is a good excuse, so in spite of > the damp weather, here are the dimensions on my Cal20. The spinnaker > track starts 47" above the mast step and is 25" long. That puts the > top of the track around 72". It's another 62" to the topping lift > pulley, about 134" total. The other way to look it is the topping > lift is just below the spreader brackets. Photo attached for reference. > I think Chris B's block location is the same as mine. It's interesting that his track starts higher and is shorter than mine, which starts at 41" and continues another 34". Jensen Marine did seem to vary their hardware, depending on availability and price probably, so it may just be normal production variation. My boat's hull no. is 1220. Chris Campbell > >
RE: [Cal_Boats] More on Cal 20 Spinnaker hardware locations
Husar, Charlie [USA]2009-05-08 16:31 UTC
extending the spin track down lower leaves the option of having the pole attached and tacking over it more readily before the chute is set. Just a thought. Cheers Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Chris Campbell Sent: Friday, May 08, 2009 9:07 AM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] More on Cal 20 Spinnaker hardware locations Chris Barszcz wrote: Hi Everyone, Any chance to go row out to the boat is a good excuse, so in spite of the damp weather, here are the dimensions on my Cal20. The spinnaker track starts 47" above the mast step and is 25" long. That puts the top of the track around 72". It's another 62" to the topping lift pulley, about 134" total. The other way to look it is the topping lift is just below the spreader brackets. Photo attached for reference. I think Chris B's block location is the same as mine. It's interesting that his track starts higher and is shorter than mine, which starts at 41" and continues another 34". Jensen Marine did seem to vary their hardware, depending on availability and price probably, so it may just be normal production variation. My boat's hull no. is 1220. Chris Campbell
