Re: [Cal_Boats] Cal 29 shaft and strut alignment
Mark,
I was lucky when I redid mine. I removed the strut under water, sent it off to Martec to duplicate. When I got it back I pulled the boat, reinstalled the strut onto the shaft. Put in the screws, gooped it up and tightened everything down, I spun the shaft as I thightened it to make sure it didn't bind. When we put the boat back into the water, I reached down and spun the shaft and it moved without and binding. So I didn't have to redo the engine mounts.
My only issue is, the new strut is corroding very fast. Martec won't let the diver drill a hole to mount the zinc, that is where mine broke. I am no longer wired to the dock, I use a couple of 15 watt solar panels from Harbor Frieght to charge my batteries and only plug the boat in when I have to run something 110 AC. If I have to leave it plugged in the future, I will run a wire from the mounting screws to a Zinc and drop over the side.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
--- On Mon, 5/11/09, Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net> wrote:
Subject: Re: [Cal_Boats] Cal 29 shaft and strut alignment
Date: Monday, May 11, 2009, 4:03 PM
Has anyone seen a shaft and strut aligned as shown in the photo. Notice that the yard has epoxy vertical 2x4's to the hull to carry a horizontal with a notch cut for shaft. The 2x4's were also epoxy to the ground. Is this the standard of care for the alignment of a Cal 29 shaft and strut?
Mark
Sent: Sunday, May 10, 2009 10:00 AM
Subject: [Cal_Boats] Re: Paragon SAOV manual
Tom:
Thanks for the reply. My Mk III-34's Paragon has a nut w/out that cotter pin. I have backed that set nut off and adjusted gear two teeth clockwise. It then shifts into forward just as smooth as butta but provides virtually no forward power to prop. Reverse works flawlessly all the time. Once adjusted back one click, I get pretty much same result: no power. It's a thriling test in a breezy, tight fairway.
Once adjusted back to the original position, which SEEMS to be the last adjustment in that direction, and it takes The Govenator to shift it into forward. At this point the engine vibrates badly. I've got this nagging feeling this trannie needs a rebuild after all.
And as for for Charlies gloating about his outboard: "I'll race you to Hawaii!"
cheers,
Dan
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com] On
> Behalf Of Tom Vandiver
> Sent: Sunday, May 10, 2009 9:48 AM
> Subject: Re: [Cal_Boats] Paragon SAOV manual
> Check www.marinegears. com for manual.
> This gear is fairly easily adjustable in forward. I have several in my
> shop, some partially dissassembled. After removing the cover plate,
> carefully remove the cotter pin on the nut, back off the nut so it
> clears the adjusting nut, turn the adjusting nut one or two
> indentations. This tightens the clutch discs. Then re -attach.
> Adjusting the reverse is very diffiicult unless your fingers are about
> 10" long but it can be done.
> If I can help, call me next week, 850-572-1225, while I am in my shop
> and we can talk it through while I have a Paragon on my bench.
> BTW, if anyone needs Paragon parts, I am parting out several.
> Tom Vandiver, Cal 46 & 25, Bayou Chico, FL
> ____________ _________ _________ __
> From: Dan <saltybob2@. ..>
> Sent: Sunday, May 10, 2009 7:58:58 AM
> Subject: [Cal_Boats] Paragon SAOV manual
> Does anyone have a digitized Paragon SAOV manual or experience with
> adjusting this transmission? I thought I had the shifting issue solved.
> After adjusting the main gear, it now shifts smooth into forward. But I
> have very little power/speed in forward, almost like it's slipping. I
> can only get 2.3 knots at maximum RPM.
> TIA
> Dan
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4063 (20090508) __________
http://www.eset. com
