2 messages2009-05-26 22:25 UTCthrough 2009-05-27 00:02 UTC
Re: [Cal_Boats] Hull-To-Deck Joint (Mike)
Michael D2009-05-26 22:25 UTC
Mike,
Thanks for the link. The photos give me some idea as to what to expect. As you may know, the Cal 2-27 hull to deck joint is located along the side of the hull just below the molded toe rail. Attached are some older photos taken during some resealing. (That's the Admiral over on port inspecting my handiwork.) I suspect that I'll need to reglass the joint in similar fashion to your project.
Do you have any suggestions for replacing the teak? I suspect if I go that route, I'll end up needing to get it custom fabricated. I am also considering using a PVC based rubrail, but so far I have not been able to find a source except for rubber based sections.
BTW, Conquest is a beautiful boat!
Michael
--- On Tue, 5/26/09, Michael Kennedy <mt… [at] cox.net> wrote:
Subject: Re: [Cal_Boats] Hull-To-Deck Joint
Date: Tuesday, May 26, 2009, 5:33 PM
On May 26, 2009, at 1:25 PM, Michael D wrote:
> It's time to redo my hull to deck joint and rub rail. It leaks;
> especially in heavy weather, and the admiral has spoken.
> I remember at least one person here that has done this, including
> removal, reglassing, etc., but I forget just who it was.
I have some photos on Flikr of the project on Conquest.
http://www.flickr.com/photos/9030851@N08/sets/72157600368863025/
Feel free to ask for any more info you need. Wendy Siegel repaired one
toe rail (stbd) that was leaking without replacing the teak rail, Mine
were in worse shape having cracked on both sides from seven Bermuda
Races over the years.
Mike Kennedy
Conquest Cal 40 # 96
> A PO of Magic had teak rub railing installed with an SS cap. The
> teak is shot, plus it was glued on with 5200 I think. It'll be
> destructive removal. I'm not quite sure what to replace it with
> though.
> Thanks,
> Michael
Yahoo! Groups Links
Re: [Cal_Boats] Hull-To-Deck Joint (Mike) [4 Attachments]
Michael Kennedy2009-05-27 00:02 UTC
I didn't know what type of boat you were asking about. That teak rail
looks really nice. Why not go from the inside and glass and seal it
there ? I had no choice. My Cal 34 had that bolted joint and it never
leaked but the PVC was a pain. I would sure try to get at it from the
inside and seal it off. Maybe the fasteners that hold the teak in
place are the source of the leak.
Mike Kennedy
On May 26, 2009, at 3:25 PM, Michael D wrote:
> [Attachment(s) from Michael D included below]
> Mike,
> Thanks,
> Michael
> From: Michael Kennedy <mt… [at] cox.net>
> Mike Kennedy
> > though.
> > Thanks,
> > Michael
> Yahoo! Groups Links
