3 messages2009-06-11 03:47 UTCthrough 2009-06-11 12:58 UTC
Re: [Cal_Boats] Wire tension
mike farrell2009-06-11 03:47 UTC
WHAT BOOK?
--- On Wed, 6/10/09, Wayne Gillikin <wa… [at] yahoo.com> wrote:
Subject: Re: [Cal_Boats] Wire tension
Date: Wednesday, June 10, 2009, 10:38 AM
Sorry, I actually had the tuning sequence wrong. The way I stated it would have you adjusting the windward shrouds. Bad idea. Corrected process: Sight up the mast, see what's wrong, Tack, make an adjustment in the leewards, tack, repeat. Anyway, you get the idea. Never adjust the loaded windwards. Its all in the book.
Sent: Wednesday, June 10, 2009 1:29:54 PM
The initial set up at the dock is based on a percentage of the breaking strength of the wire. This is based no the size of the wire, naturally. There is an excelent, well illustrated, book "Sail & Rig Tuning" by Ivar Dedekam. Ivar covers it all.
Keep in mind that what you do at the dock is a preliminary set up. Tuning is done while sailing. Preferably in 15 kts of wind at a 20 degree heel angle. Sight up the mast, see what's wrong, fix it, tack, repeat on the other side.
Regards,
Wayne Gillikin
"Elusive"
Cal 39 Mk3
Sent: Wednesday, June 10, 2009 12:56:51 PM
Subject: [Cal_Boats] Wire tension
With all this talk about proper tension, Where would I find this information for my Cal31?
Thanks
Kevin O
"Kona"
Cal-31
Las Vegas
mike farrell2009-06-11 03:52 UTC
Go to cal20 class website and kick up links. Then apply it to your boat---Don't knock it until you have tried it---You will get a whole nother persective on Rig Tune. I've tried it and it works--- Dave Ulman on rig tune/ Noreh sails on rig tune
Date: Wednesday, June 10, 2009, 10:29 AM
Regards,
Wayne Gillikin
"Elusive"
Cal 39 Mk3
Thanks
Kevin O
"Kona"
Cal-31
Las Vegas
Wayne Gillikin2009-06-11 12:58 UTC
The book referenced in the thread, naturally.
Sent: Wednesday, June 10, 2009 11:47:01 PM
WHAT BOOK?
--- On Wed, 6/10/09, Wayne Gillikin <waynegillikin@ yahoo.com> wrote:
>From: Wayne Gillikin <waynegillikin@ yahoo.com>
>Regards,
>Wayne Gillikin
>"Elusive"
>Cal 39 Mk3
>>Thanks
>>Kevin O
>>"Kona"
>>Cal-31
>>Las Vegas
