5 messages2009-06-11 21:35 through 2009-06-13 22:53
Back to ground plates
sj24brad2009-06-11 21:35
Hello to All,
I am refitting my Cal29 more or less from scratch. To date I have seen a ground connection in the bilge, which is simply an attachment to a very large and rusty eye-bolt (one of two such bolts), and another connection to a through-hull located in the engine compartment a few inches to the port side of the center-line of the vessel.
This boat has no engine and will not have one installed.
I would greatly appreciate learning what ground plate arrangements you have on your boats, including external plates with through-hull attachments in the cabin. I would like to learn about both AC and DC grounds that you currently use.
Thanks in advance,
Brad Bates
Br… [at] verizon.net
Re: [Cal_Boats] Back to ground plates
Allen Edwards2009-06-12 00:59 UTC
I am not answering your question but rather making a comment about having
multiple ground connections to things that go to the water. Some people
like to do this and I wanted to offer another opinion on this. As an
Electrical Engineer, I think of having two metals in a conductive liquid
like salt water as being a battery. The voltage you get depends on how
different the two metals are. If they are identical alloys, there is no
voltage. All boats are full of such batteries. One of particular interest
has zinc as one of the electrodes. In all cases, the battery action is such
that one element moves ions to the other and electrons flow the other way.
The ions take the metal with them so eventually that electrode is gone.
That is why you have to replace your zincs.
Anyway, the end of this long story is that if you don't connect a wire
between two pieces of metal on your boat, you basically have a battery
sitting on the shelf. Bronze as a battery element has a 100 year shelf
life. If you connect the two electrodes (through hulls) together, you have
a shorted battery. Which do you think lasts longer? Moral, don't bond the
metals in your boat together.
By the way, my boat (L-36) is wood and the process of the ions and electrons
creates hydroxyl ions which eat the inners of the wood. You are left with a
honey comb where the wood used to be right around the zinc. I quit
"protecting" so much of the metal on my boat because it is easier to replace
the metal then the wood. Besides, if you don't bond them, the shelf life is
very long and it will last longer than I will and at that point I don't
care.
On Thu, Jun 11, 2009 at 2:35 PM, sj24brad <Br… [at] verizon.net> wrote:
> Hello to All,
> currently use.
> Thanks in advance,
> Brad Bates
> Br… [at] verizon.net <Bradley.Bates%40verizon.net>
Back to ground plates (Brad)
Husar, Charlie [USA]2009-06-12 01:07 UTC
Brad, sorry I diverted the discussion to lightning. I am also curious
as to how one would do AC ground system in a boat with an encapsulated
keel.
I also note that through-hulls are often not metal.
Annapolis
Behalf Of sj24brad
Sent: Thursday, June 11, 2009 5:36 PM
Subject: [Cal_Boats] Back to ground plates
Hello to All,
Thanks in advance,
Brad Bates
Yahoo! Groups Links
Re: [Cal_Boats] Back to ground plates (Brad)
Allen Edwards2009-06-12 02:14 UTC
Why not just ground to the shore ground wire? I really wouldn't want the
boat next to me connecting any part of the AC system to the water. If it
gets screwed up, it frys all the boats in the harbor. When you are under
way, you don't need to worry about the shore power ground. Perhaps you are
talking about a gen set. In that case, ground to the gen set.
On Thu, Jun 11, 2009 at 6:07 PM, Husar, Charlie [USA] <hu… [at] bah.com
> keel.
> Cheers
> Charlie
> Annapolis
> -----Original Message-----
> From: Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com> [mailto:
> Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>] On
> Behalf Of sj24brad
> To: Ca… [at] yahoogroups.com <Cal_Boats%40yahoogroups.com>
> Hello to All,
> Thanks in advance,
> Brad Bates
> Yahoo! Groups Links
Re: Back to ground plates (Brad)
sj24brad2009-06-13 22:53
I want to say thanks to all of you who responded to this question. Allen's points about how different metals react with salt water and grounding to shore power and a gen set are spot on. And Charlie, no apology needed for me. This is a discussion forum, right?
I know just enough about electricity and electronics to be uncomfortable with any assumptions. So please bear with me when I have more to ask on the subject. I just want to be sure that crew, the boat, and me remain safe as I install things!
Thanks again,
Brad Bates
> Allen
> On Thu, Jun 11, 2009 at 6:07 PM, Husar, Charlie [USA] <husar_charlie@...
> > keel.
> > Cheers
> > Charlie
> > Annapolis
> > Behalf Of sj24brad
> > Hello to All,
> > Thanks in advance,
> > Brad Bates
> > Bradley.Bates@... <Bradley.Bates%40verizon.net>
> > Yahoo! Groups Links
