Re: [Cal_Boats] Cal 28 on the grid
2 messages2009-06-16 16:47 UTCthrough 2009-06-16 19:11
Rodney G Johnson2009-06-16 16:47 UTC
Boats built prior to 01NOV 1972 do not have a factory issued HIN. The CALs built prior to that date (1972 and earlier models) will have a HULL # that is marked on the INSIDE of the transom near the starboard side. This will be marked in black ink on a small label that is covered by a thin layer of glass cloth. The Hull# is also often marked on small components like the drawers in the galley. Since 1989 many states have required HINs on ALL boats and if the boat was built prior to the 01NOV1973 date when the USCG required the HIN, the state will usually assign an HIN to the boat. These State-issued HINs will start with the state registration abbreviation followed by a "Z" and then have 9 more digits. This HIN may or may not indicate the original model year of the boat depending on the State. These state-issued HINs are supposed to be marked on the hull by the owner just as the manufacturer's HIN, that is on the transom within 2" of the top and near the starboard edge, or on the starboard side within 2" of the rubrail, near the stern. But anyway, you will not find a CAL Hull I.D. Number on a boat built prior to the 1973 model year and your CAL 28-1 was out of production long before that requirement. So you can give up looking for a "CAB" number, however..you should find out whether your boat has a state-issued HIN (it should be on the Bill-of-sale and/or Title) and be sure that it is permanently marked in the correct spot. Rod Johnson, "SUNBIRD" 1979 O'DAY DS II (XDY10201M79E-D) and Former co-owner of "NODROG" 1970 CAL 21 #285 On Tue, 16 Jun 2009 16:25:22 -0000 "cal_28vi" <ca… [at] yahoo.com> writes: Hi all, Just joined and wanted to share some pics -- I have a blogspot here if you want to check it out on the tidal grid... My question is whether I should keep looking for a hull I.D. number -- I can't find one, and maybe it doesn't have one. I have not seen another boat like this with a hole in the transom rather than the bottom of the lazarette for an outboard. Mine has a large rectangular hole, suitably reinforced, for the outboard to hang out the back of the boat. In my limited research, I have discovered that some of the Cals were build in Vancouver, Canada for a short time by a company which eventually build the "Crown" make. Maybe this is a modification they made? Anyway, I will run the boat like this for a while, but my gut says to close up the giant hole in the transom and put the outboard on a bracket. Cheers, Todd Injured in a car or at work? Click here to find a personal injury lawyer. http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTOh2S8h7QQzWBWae7HjvEGTSewp3WjW3AdUkx6RWuFFvoGa8zo5RO/
Re: Cal 28 on the grid
markboulw2009-06-16 19:11
Todd, I have A 1967 cal-28. I found my no. inside the transom starboard side. It is on a piece of paper and glassed over, after 40 years it is pretty well yellowed and hard to see. My boat has inboard power and a lazarte to gain access to the inside of the transom. Do you have cockpit lockers? Maybe you can squeeze into one and have a peek. You'll love this boat! It is fast and stable. Fair winds. Mark cal-28 no.213 Aquarius. Dana Point Calif.
