laptop inverter
laptop inverter
3 messages2009-07-09 20:44 UTCthrough 2009-07-09 21:55 UTC
laptop inverter
cp… [at] sympatico.ca2009-07-09 20:44 UTC
Timm, please check your junk mail for my reply :-) Peter
RE: [Cal_Boats] laptop inverter
ti… [at] ch2m.com2009-07-09 20:58 UTC
how did you know that's where it went? I did not have much to comment on. I have used the small unit exclusively for my Dell Laptop. My laptop power supply output is 19.5v @ 4.62a.= 90 watts - so the 300 watt inverter is 3x adequate. Input power required is 100-240v @ 1.5amps AC to produce the DC output at it's maximum capacity. Watt=Volts x amps Timm Subject: [Cal_Boats] laptop inverter Timm, please check your junk mail for my reply :-) Peter Sent from my BlackBerry(r) wireless device
laptop inverter (Timm)
Husar, Charlie [USA]2009-07-09 21:55 UTC
Timm, don't forget the phase in the W=VA calculation. I'm just being an idiot about it since it rarely matters in consumer electronics. Previously, the gentleman was questioning the DC amperage at 12-13VDC from battery to invertor. For 100 watts, we are indeed talking 8-12 amp drain depending on invertor. Cheers Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of ti… [at] ch2m.com Sent: Thursday, July 09, 2009 4:58 PM To: cp… [at] sympatico.ca Cc: Ca… [at] yahoogroups.com Subject: RE: [Cal_Boats] laptop inverter how did you know that's where it went? I did not have much to comment on. I have used the small unit exclusively for my Dell Laptop. My laptop power supply output is 19.5v @ 4.62a.= 90 watts - so the 300 watt inverter is 3x adequate. Input power required is 100-240v @ 1.5amps AC to produce the DC output at it's maximum capacity. Watt=Volts x amps Timm Subject: [Cal_Boats] laptop inverter Timm, please check your junk mail for my reply :-) Peter Sent from my BlackBerry(r) wireless device ------------------------------------ Yahoo! Groups Links
