4 messages2009-08-22 13:48 UTCthrough 2009-08-24 16:53 UTC
Re:Cal 40/29 Beam drawing
Alfred Poor2009-08-22 13:48 UTC
Charlie suggested:
> Mark, I think you just need to make the CAL 40 drawing a little smaller.
The Cal 29 beam drawing that Roger Jones made should be floating around in a
number of places on the Web by now, but I've attached one here.
Note that we saved some fab costs by having the top flange simply rolled
from the web material, and then had the three tabs welded in place. It meant
for a lot less welding, and probably less cutting, too.
Alfred Poor
Husar, Charlie [USA]2009-08-22 14:44 UTC
Of course, I was kidding based on underside similarities. The forces obviously go up much faster than the linear dimensions. Birds have skinny legs and elephants have huge ones for a reason. I'm told that the linear dimensions must increase as the square root of the cube based on mass (and force).
A curiosity. Having seen many different encapsulated keel CAL undersides, I would note that the rudders do not increase in size proportionally with boat size (at least it seems that way). If true, Howcum?
Allen mentioned the difference in tab placement on the beams. On my end, I have worked on a lot of CAL 25s. There are many differences just within that flat-top product line over time. In addition to obvious changes, stern plates do not fit other boats, backstay tangs are placed differently, lead keel slugs were different, hatch cut-outs do not match, and so forth. Point is, one must be careful when buying scavenged/rebuilt parts for a model of boat.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Alfred Poor
Sent: Saturday, August 22, 2009 9:49 AM
Subject: [Cal_Boats] Re:Cal 40/29 Beam drawing [1 Attachment]
[Attachment(s) from Alfred Poor included below]
Charlie suggested:
> Mark, I think you just need to make the CAL 40 drawing a little smaller. : - ]
The Cal 29 beam drawing that Roger Jones made should be floating around in a number of places on the Web by now, but I've attached one here.
Note that we saved some fab costs by having the top flange simply rolled from the web material, and then had the three tabs welded in place. It meant for a lot less welding, and probably less cutting, too.
Alfred Poor
1 of 1 File(s)
[http://us.i1.yimg.com/us.yimg.com/i/yg/img/doc/pdf16x16.gif]
Cal 29 Beam Drawing.pdf<http://d.yimg.com/kq/groups/16485695/538246843/name/Cal%2029%20Beam%20Drawing%2Epdf>
Re: [Cal_Boats] Re:Cal 40/29 Beam drawing
Chris Campbell2009-08-24 12:56 UTC
> Howcum?
You could pose this as a question to Robert Perry, who has started
writing a series of boat-design articles for /Good Old Boat/ magazine.
Ted Brewer wrote an earlier series nbut now they've got Perry writing
from his perspective.
We could guess that on larger boats, the spade rudder is farther from
the fin keel, giving it more "leverage." You need les force farther
from the pivot.
RE: CAL model variations.
r good2009-08-24 16:53 UTC
sometimes the same model was built in different plants, IE. east coast versus west coast. additional variations arose.
Date: Sat, 22 Aug 2009 10:44:55 -0400
Charlie suggested:
The Cal 29 beam drawing that Roger Jones made should be floating around in a number of places on the Web by now, but I’ve attached one here.
Alfred Poor
1973 Tartan 34C #288 “Jambalaya”
1 of 1 File(s)
