5 messages2009-08-28 13:46 UTCthrough 2009-08-28 16:06 UTC
Re: [Cal_Boats] Cal 39 Displacement
Rodney G. Johnson2009-08-28 13:46 UTC
Charlie, the only CAL 39 model that was offered with a wing-keel was the
C.R. Hunt Associates-Designed CAL 39, built in the late 1980's. Perhaps
one or two owners of earlier CAL 39s swapped their fin-keels for
wings......?
Rod Johnson,
"SUNBIRD"
1979 O'DAY DS II
former co-owner of
"NODROG"
1970 CAL 21
On Fri, 28 Aug 2009 08:20:06 -0400 "Husar, Charlie [USA]"
<hu… [at] bah.com> writes:
Hi, Paul. I know a number of models had more and more cruising amenities
leading to displacement creep. The big items I would figure into weight
would be bigger engines or maybe a change in ballast to correct
tenderness? I've seen some reference to winged keel 39s as well.
Behalf Of pw… [at] aol.com
Sent: Friday, August 28, 2009 4:16 AM
Subject: [Cal_Boats] Cal 39 Displacement
Here is one source for the 19K displacement.
http://pages.sssnet.com/go2erie/cal39.htm
I guess no one knows why there is a wide range of displacements for the
Lapworth design?
Paul West
Adventure Kwest
'80 Cal 39
Best Weight Loss Program - Click Here!
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTFoYb73mHsa3IDCMd0V4i81sEyA8J9FecioM8UFAROTwnAR7v0Ibm/
Rodney G. Johnson2009-08-28 13:58 UTC
Wayne, basically the designer does add up all the weight of the boat and
then there is a formula that is used to set the waterline...... basically
though, that formula is used to verify the designer's "gut feeling" of
where the waterline will be. These formulas allow a designer to determine
how much deeper the boat will float for every added pound of ballast or
gear.
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II
former co-owner of "NODROG"
1970 CAL 21
On Fri, 28 Aug 2009 06:37:46 -0700 (PDT) Wayne Gillikin
<wa… [at] yahoo.com> writes:
OK - So I'm confused again. How do they come up with the displacement?
I would have thought it was by determining, by measurement, the size of
the hole the boat makes in the water. To do that I would think the
designer would have to decide on where to put the waterline. Waterline
placement, I again assume, would have to do with the actual weight of the
boat. When they are designing the boat do they add up all the estimated
weights of all the materials and equipment? This could account for
differences in displacement from model to model. Obviously, I am no
engineer.
The data on http://www.baconsai ls.com/database/ boatspec. php lists the
variations in models and years but the info at
http://pages.sssnet.com/go2erie/cal39.htm lumps all Lapworth 39s together
and, as far as I am concerened, is inaccurate and unreliable. Even
though there is a web based source, unless it is the manufacturer's site,
IMHO all data is suspect. I have to believe that the commercially
available databases used by sail makers et al must be based on the
designer's original specifications. Yes/No?
Regards,
Wayne
Sent: Friday, August 28, 2009 8:20:06 AM
Subject: RE: [Cal_Boats] Cal 39 Displacement
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On
Behalf Of pwestla@aol. com
http://pages. sssnet.com/ go2erie/cal39. htm
Lapworth design?
Paul West
Adventure Kwest
'80 Cal 39
Get 3 Roof Quotes Quick
Request 3 quotes from up to 3 local pre-screened roof contractors.
http://thirdpartyoffers.juno.com/TGL2141/c?cp=RCJtgiTxjMh_lNI5W-ORYgAAJ1CIixW8vmHn6WPZlsvVErEuAAQAAAAFAAAAAM3MDD4AAAAAAAAAAAAAAAAAB3iGAAAAAA==
pw… [at] aol.com2009-08-28 15:19 UTC
Wayne -
I was told that displacement was the weight of the water displaced by the
boat if you were to put it in a container full to the rim with water. Dunno
if that is accurate or not however.
My old CS 30 was supposed to be 8,000 lbs but on member on the CS list said
that lift at their yacht club had a scale (no way of knowing how accurate
it was) and that of the 5 CS 30's in the club, none was under 10,000 lbs.
But then you are comparing actual weight to displacement which is not apples
to apples.
On another web list, when I was looking at the C&C 99's, there was a lot of
"stuff" going around that C&C was "manipulating" their numbers by just
providing the weight of the hull w/o mast, rigging or fittings etc.
Bottom line is that all the numbers appear to be "best guesses" or
designers goals but I was just wondering if there were any concrete info on why
there are 3 different numbers published for the Cal 39's.
Paul West
Adventure Kwest
CS 30
**************A Good Credit Score is 700 or Above. See yours in just 2 easy
steps!
(http://pr.atwola.com/promoclk/100126575x1222846709x1201493018/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072&hmpgID=115&bcd
=JulystepsfooterNO115)
Allen Edwards2009-08-28 16:05 UTC
Weight and displacement are the same. A boat will displace its weigh.
On Fri, Aug 28, 2009 at 8:19 AM, <pw… [at] aol.com> wrote:
> Wayne -
> that lift at their yacht club had a scale (no way of knowing how accurate it
> was) and that of the 5 CS 30's in the club, none was under 10,000 lbs. But
> then you are comparing actual weight to displacement which is not apples to
> apples.
> of "stuff" going around that C&C was "manipulating" their numbers by just
> why there are 3 different numbers published for the Cal 39's.
> Paul West
> Adventure Kwest
> CS 30
Rodney G. Johnson2009-08-28 16:06 UTC
Paul, easy answer......
There are 3 different numbers because there were 3 different (actually 4
or more) CAL 39 models. (I believe there were a few changes to each
versio over their production runs)
1) 1971 design-Bill Lapworth
2) 1977 design-Bill Lapworth (deep and shoal models?)
3) 1987 design-C.R. Hunt associates
Rod Johnson
former co-owner of
"NODROG"
1970 CAL 21
on why there are 3 different numbers published for the Cal 39's.
Paul West
Adventure Kwest
CS 30
On Fri, 28 Aug 2009 11:19:49 EDT pw… [at] aol.com writes:
Messages in this topic (6) Reply (via web post) | Start a new topic
Messages | Files | Photos | Links | Database | Polls | Members | Calendar
MARKETPLACE
Mom Power: Discover the community of moms doing more for their families,
for the world and for each other
Change settings via the Web (Yahoo! ID required)
Change settings via email: Switch delivery to Daily Digest | Switch
format to Traditional
Visit Your Group | Yahoo! Groups Terms of Use | Unsubscribe
All is not lost! Click now for professional data recovery.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTLygLLjd9f7IwdFyZfmgwsUsB4pBOWdtgC3QEuNQPWX83EggEFBUM/
