11 messages2009-09-11 16:42 UTCthrough 2009-09-14 00:54 UTC
I'm missing something obvious . . .
pw… [at] aol.com2009-09-11 16:42 UTC
When I bought the Cal 39 the PO said that he always had about 2 inches of
water in the bilge and it never got any deeper than that and sure enough that
is what I get too.
I thought I had found it when I discovered the seawater galley pump was
leaking but it still comes in somewhere. I've looked at all the other thru
hulls and don't see anything.
Maybe I'm having a brain fart, but how can something be leaking in a boat
and only get 2 inches inside? My simple mind thinks that if there is a leak
in the boat it isn't going to stop until the boat is sunk. I don't have a
bilge pump with a float switch that is maintaining this elevation (too
obvious even for me) so help me out here. I mostly race so I keep the water tanks
empty so it's not fresh. I do have a leak at a stanchion base that I am
aware of but even when we've not had rain the water is there! I hate having a
wet bilge and this is driving me nuts!
Thanks for your help.
Paul West
Adventure Kwest
'80 Cal 39 Mk III
RE: [Cal_Boats] I'm missing something obvious . . .
Randy Alcorn2009-09-11 16:59 UTC
where does the ice box drain. And then where is the outlet to your bilge pump. Mine will be under the water in following seas and I get water in that way. I am installing a anti siphon to get it above the water line.
Randy
CAL2-29
pw… [at] aol.com wrote:
> When I bought the Cal 39 the PO said that he always had about 2 inches of water in the bilge and it never got any deeper than that and sure enough that is what I get too.
> I thought I had found it when I discovered the seawater galley pump was leaking but it still comes in somewhere. I've looked at all the other thru hulls and don't see anything.
> Maybe I'm having a brain fart, but how can something be leaking in a boat and only get 2 inches inside? My simple mind thinks that if there is a leak in the boat it isn't going to stop until the boat is sunk. I don't have a bilge pump with a float switch that is maintaining this elevation (too obvious even for me) so help me out here. I mostly race so I keep the water tanks empty so it's not fresh. I do have a leak at a stanchion base that I am aware of but even when we've not had rain the water is there! I hate having a wet bilge and this is driving me nuts!
> Paul West
> Adventure Kwest
> '80 Cal 39 Mk III
ti… [at] ch2m.com2009-09-11 17:12 UTC
hard to say why it maintains a level, unless it is a condensation issue where the liquid/vapor is at an equilibrium...
When I have a slow leak to find, I sprinkle baby power around different locations.
Water movement makes trails appear.
Once you have a trail, you can keep sprinkling to eventually find the source.
In the past I have located stanchions, packing glands, bolts that retain a prop strut, propeller shaft log and a delaminated fiberglass reinforcement at a through hull.
I also look hard at locations that stay wet for a "long time" when I haul the boat out of the water. You can check these areas by soaping then and using a vacuum cleaner hose taped to the spout of a clear water bottle with the bottom cut out (you may have to duct tape around the bottom of the bottle to make a soft sealing surface). Leaky locations should bubble.
good luck!
dEmO
Sent: Friday, September 11, 2009 9:43 AM
Subject: [Cal_Boats] I'm missing something obvious . . .
Paul West
Adventure Kwest
'80 Cal 39 Mk III
Husar, Charlie [USA]2009-09-11 19:08 UTC
So it was that baby powder I smelled when I was on your boat, Timm. I was afraid to ask at the time.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of ti… [at] ch2m.com
Sent: Friday, September 11, 2009 1:12 PM
Subject: RE: [Cal_Boats] I'm missing something obvious . . .
good luck!
dEmO
Paul West
Adventure Kwest
'80 Cal 39 Mk III
Re: [Cal_Boats] I'm missing something obvious . . .
Michael Kennedy2009-09-11 19:12 UTC
It could be the packing gland that is dripping at the same rate as
evaporation.
Mike Kennedy
Conquest Cal 40 # 96
> Paul West
> Adventure Kwest
> '80 Cal 39 Mk III
Re: [Cal_Boats] I'm missing something obvious . . .(Michael)
Gerald Sobel2009-09-11 23:37 UTC
Michael,
Yes, when I bought Shpritz (Tempest) she had a reservoir of the saltiest water next to the Dead Sea or Great Salt Lake. There were salt crystals growing in the forward part of the hull from a tiny crack in the forward keel section. Patched the crack, and no more leak. And darn it... I forgot to bring my salt along for the cruise.
But yeah, it leaked so slowly that the water evaporated just as fast at a certain surface area.
--- On Fri, 9/11/09, Michael Kennedy <mt… [at] cox.net> wrote:
Subject: Re: [Cal_Boats] I'm missing something obvious . . .
Date: Friday, September 11, 2009, 12:12 PM
evaporation.
Mike Kennedy
> Paul West
> Adventure Kwest
> '80 Cal 39 Mk III
Yahoo! Groups Links
CCCCCCCCCCCCCCCCCCCCCC(Randy) was mystery leak.
Gerald Sobel2009-09-11 23:46 UTC
Randy,
Speaking of leaks, time is fast leaking away. Will there be a CCCCC in 2009, and if so, where is the coolest place to anchor in the Channel Islands, and where is the sea cave where i can hide Shpritz from the Homeland Defense Farce?
I can see there being a small turnout, but chances are I'll see at least one Cal on my trip to and from the islands, that is, if I even go me self..
RE: [Cal_Boats] CCCCCCCCCCCCCCCCCCCCCC(Randy) was mystery leak.
Randy Alcorn2009-09-12 05:57 UTC
Jerry,
I had planned it for this weekend. But none responded positively. Everyone had other plans.
I passed the torch back to you guys. We should start to experience Santa Annas .more and more in the up coming months and the islands torn deadly if you find a poor anchorage.
I did get 3 CAL 34 s for the Prison Break this weekend and I will be sailing on Dave Paulsons Allegria.
wish us luck. Joe and Joanns Huba Huba is also going over. They have been putting up some stiff compitition out here.
catch up on Sunday. Be safe
Gerald Sobel wrote:
> Randy, Speaking of leaks, time is fast leaking away. Will there be a CCCCC in 2009, and if so, where is the coolest place to anchor in the Channel Islands, and where is the sea cave where i can hide Shpritz from the Homeland Defense Farce? I can see there being a small turnout, but chances are I'll see at least one Cal on my trip to and from the islands, that is, if I even go me self.. Jerry
Wayne Gillikin2009-09-12 19:19 UTC
Paul,
Not much to be done here, Paul. Since there is no sump there is always some water in the bilge. I don't think I have 2". Probably more like an inch. it is the level the bilge pump can't get to plus what is left in the hose that drains back into the bilge. The water comes into my boat from the mast (notwithstanding its being sealed), a couple of yet-to-be-fixed leaks in toe-rail bolts, and who knows where else. I 'm certain the water in the bilge is fresh but I'm waiting to get someone aboard who is actually willing to taste it. I would bet against a leak below the waterline. It strikes me as too huge a coincidence that the leak rate and the evaporation rate would be Identical.
There was a thread a few months ago about cutting a small sump into the bilge and putting a pump into it to scavenge the last bit of water out. Like the bilge water tasting, I'm still waiting for someone to actually do it.
Wayne Gillikin
Elusive
Cal 39-III
Sent: Friday, September 11, 2009 11:42:42 AM
Paul West
Adventure Kwest
'80 Cal 39 Mk III
Allen Edwards2009-09-13 01:57 UTC
With this pump
http://www.defender.com/product.jsp?path=-1|51|299222|84462|315207&id=84716<http://www.defender.com/product.jsp?path=-1|51|299222|84462|315207&id=84716>and
a 3/4 inch garden hose and a check valve at a high spot I keep the water
down to about 1/2 inch. The small hose means not much water flows back when
the pump shuts off. You can't put the check valve at the pump as the
backpressure of the water in the hose will keep the pump from working. I run
the hose up to a high spot then put the check valve so as to have the
minimum hose between the pump and the valve yet no water on the outlet side
of the valve to provide pressure. I switched to plastic check valves
because the expensive bronze one kept getting stuck. The plastic one
doesn't. The check valve is there just to make sure the system doesn't sink
my boat and to prevent a siphoning action when the pump shuts off from
pulling all the water in the hose back.
Hope this is helpful.
On Sat, Sep 12, 2009 at 12:19 PM, Wayne Gillikin <wa… [at] yahoo.com>wrote:
> Paul,
> it.
> Wayne Gillikin
> Elusive
> Cal 39-III
> *From:* "pw… [at] aol.com" <pw… [at] aol.com>
> *Sent:* Friday, September 11, 2009 11:42:42 AM
> *Subject:* [Cal_Boats] I'm missing something obvious . . .
> Paul West
> Adventure Kwest
> '80 Cal 39 Mk III
RE: [Cal_Boats] I'm missing something obvious . . .(Paul)
Knize, Duane J.2009-09-14 00:54 UTC
Paul,
I think Allen has the answer.
I periodically sponge out the last inch to keep the boat drier when I
know I will not be visiting it for a while.
With a renewed packing gland and no ice in the ice box, I find that the
bilge will stay bone dry, except for rain,
where some finds its way in (probably through the sheave box at the top
of the mast).
Cheers,
Duane Knize
Marlyn 1978 Cal 2-39 #18
Behalf Of Allen Edwards
Sent: Saturday, September 12, 2009 6:57 PM
With this pump
716
and a 3/4 inch garden hose and a check valve at a high spot I keep the
water down to about 1/2 inch. The small hose means not much water flows
back when the pump shuts off. You can't put the check valve at the pump
as the backpressure of the water in the hose will keep the pump from
working. I run the hose up to a high spot then put the check valve so as
to have the minimum hose between the pump and the valve yet no water on
the outlet side of the valve to provide pressure. I switched to plastic
check valves because the expensive bronze one kept getting stuck. The
plastic one doesn't. The check valve is there just to make sure the
system doesn't sink my boat and to prevent a siphoning action when the
pump shuts off from pulling all the water in the hose back.
wa… [at] yahoo.com> wrote:
Paul,
do it.
Wayne Gillikin
Elusive
Cal 39-III
Paul West
Adventure Kwest
'80 Cal 39 Mk III
