Re: [Cal_Boats] CAL 25 Mainsail (Rod)
1 messages2009-11-08 05:15 UTCthrough 2009-11-08 05:15 UTC
Rodney G Johnson2009-11-08 05:15 UTC
Charlie, 2 very different boats. The CAL 2-24 was the one that sort-of looked like a smaller 25, the T/4 was the design that more or less seems to have replaced the 2-24 in the CAL model line up and the T/4 more or less looked like a smaller version of the first CAL 27 (AKA pop-top 27) but without the pop-top and with an outboard rudder on a reverse transom (top of transom was forward of the bottom). Other than that.... I believe the T/4 was designed to compete in the MORC 1/4 Ton class, just as the T/2 was designed to compete in the MORC 1/2 Ton Class. Rod Johnson On Sat, 7 Nov 2009 23:54:42 -0500 "Husar, Charlie [USA]" <hu… [at] bah.com> writes: I might have this messed up , but is not the CAL 2-24 also called a T/4 (designed for MORC)? I know that the T/4 had/has it's rudder on the stern. So many boats, so little time. Cheers Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Rodney G Johnson Sent: Saturday, November 07, 2009 2:18 PM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] CAL 25 Mainsail (Kevin) It would be the later, CAL 2-24 that looks like a slightly smaller version of the 25. Even then it is a VERY different boat, starting with the cast-iron fin-keel. The original CAL 24 was very similar to but beamier than the LAPWORTH 24/Gladiator 24. The CAL 24 had a shallow full-keel with a centerboard housed inside, the LAPWORTH 24 was a deep full-keel. The Gladiator was the same hull as the L24, but with a CAL25 style raised deck (so-called "flat deck"). I guess that the CAL 2-24 would look like the Gladiator from a distance, easy to tell apart when hauled out, since the Gladiator has a full-keel w/attached rudder and the CAL 2-24 has a Fin-Keel with a spade rudder. Rod Johnson, "SUNBIRD" 1979 O'DAY DS II #10201 and former co-owner of "NODROG" 1970 CAL 21 #285 On Sat, 7 Nov 2009 10:28:37 -0800 Martin Klos <sk… [at] skydocs.com> writes: Thanks for the advice Charlie. We are still trying to get a full ID, but it is not the flat deck type. Origin is 1964 on the registration, and it needs a lot of TLC. But the hull is very strong still so we are rebuilding the interior and the rigging. The boat is living in Oregon and eventually will be our little weekender then used for short week long cruises in the San Juans. Martin Online Medical Insurance Get free online medical insurance quotes and save more money today. The Art Institutes Live your passion. Pursue a graphic design or creative arts degree. http://thirdpartyoffers.juno.com/TGL2141/c?cp=pnlET-I77ZNptl2u7WtR8wAAJ1CIixW8vmHn6WPZlsvVErEuAAQAAAAFAAAAABsvXT4AAAMlAAAAAAAAAAAAAAAAAAhBIwAAAAA=
