3 messages2009-12-20 05:40 UTCthrough 2009-12-20 18:30 UTC
Re: [Cal_Boats] Mast pumping (Mike)
Allen Edwards2009-12-20 05:40 UTC
Mike,
You replied to my posting of Bill Lapworth's instructions on how to tune a
mast with this? WTF? My original post on mast pumping was that maybe it is
a good idea to leave the lowers alone. Get a life my friend. I have limited
racing, 6-1st, 10-2nd, and 2-3rd, out of 20 only races. The only guy who
beats me is a two time national champion in the Express-37 class. I have
nothing to be ashamed of. If this wasn't directed at me, then be careful
which post you are replying to when you get all high and mighty.
On Sat, Dec 19, 2009 at 7:05 PM, mike farrell <ve… [at] yahoo.com> wrote:
> If a mast doesn't pump it is set up too tight, and it will come down,
> Bend the mast, crank up the back stay. accomplish the impossible--- you
> still got 2nd place and you do not have a clew( word play) All the computer
> simulations and formulas will not make up for time at sea.
> God bless this mess, m Cal 20
> *From:* Allen Edwards <al… [at] PaloAltoPhoto.com>
> *Sent:* Sat, December 19, 2009 6:49:38 PM
> *Subject:* Re: [Cal_Boats] Mast pumping
> http://l-36.com/lapworth_letter.pdf
> <http://l-36.com/lapworth_letter.pdf>http://l-36.com/rigtune.php
> <http://l-36.com/rigtune.php>Allen
> On Sat, Dec 19, 2009 at 5:49 PM, Randall Alcorn <sa… [at] yahoo.com>wrote:
>> When I get around a computer I will see what I can find. I set mine up
>> with the mast at a 2 degree rake and then I made sure the mast head was
>> centered over the boat side to side with a halyard. Then I tighten the
>> lowers and made sure they were equal all the way around with no sideways
>> hooks in the mast. I then used a loos gauge to make sure I was not bar
>> tight. Then I tightened the forward lowers a little more than the afts.
>> -- Sent from my Palm Pixi
>> r good wrote:
>> fore and aft lowers
>> To: Ca… [at] yahoogroups.com
>> From: sa… [at] yahoo.com
>> Date: Thu, 17 Dec 2009 20:05:14 -0800
>> Subject: Re: [Cal_Boats] Mast pumping
>> Hi Reggie,
>> Does your boat have the fwd and aft lowers or a baby stay and 2 running
>> back stays, that is the only way I know that prevents the pumping.
>> Do you have Lapworths mast tuning guide?
>> Randy
>> CAL 2-29
>> Out Patient
>> Channel Islands Ca
>> *From:* r good <my… [at] hotmail.com>
>> *To:* ca… [at] yahoogroups.com
>> *Sent:* Wed, December 16, 2009 10:12:10 PM
>> *Subject:* RE: [Cal_Boats] Mast pumping
>> Allen,
>> the mast onmy CAL 36 pumps. where do I get info on tuning it out? it has
>> single uppers and dual lowers.
>> Reggie
>> To: Cal_Boats@yahoogrou ps.com
>> From: allen.edwards@ PaloAltoPhoto. com
>> Date: Wed, 16 Dec 2009 20:03:33 -0800
>> Subject: Re: [Cal_Boats] Blade jib?
>> The small amount of research I have done says that the dual lowers are
>> there to prevent the mast from pumping fore and aft. I have often seen my
>> mast get into an osculation in strong winds in the slip where the mast
>> wiggling around like a guitar string. I hate it when it does that. In
>> fact, I removed the mast partners for a time when I was doing some repair
>> work on the cabin top and the mast cracked from the wind and the
>> oscillations. Removing the mast partners makes the mast way weaker, maybe 3
>> or 4 times weaker. (I get cracks in my mast often and just glue it back
>> together so not a huge deal but it make the point.) My mast is wood and
>> the last thing I want is to have it come down so I am not going to try and
>> learn if it can be re-rigged. It might be that to remove them, the
>> designers used a different section of aluminum for the mast that gave more
>> fore and aft stability. In other words, there may be more to it than just
>> removing two shrouds and relocating the others. Perhaps a rigger would
>> know. Basically, by not supporting the middle of the mast, it is something
>> like 4 times weaker.. That however may be just fine as clearly most of the
>> stress on the mast is sideways. I have no idea really and like I said am
>> not going to experiment and find out. Some things are better left a
>> mystery.
>> Disclaimer: Don't listen to anything I say because I don't know what I am
>> talking about.
>> Allen
>> On Wed, Dec 16, 2009 at 6:52 PM, Randy Alcorn <saylorran@yahoo. com<sa… [at] yahoo.com>
>> > wrote:
>> Hi Fin,
>> My CAL 29 has the forward and aft lowers. I hate them when it comes to
>> windward leewards or just tacking in light winds.
>> I am intrested in removing them, is there a calculation I have to work out
>> to see if chainplate is strong enough to get away with it on my 2-29. I
>> have the wide wooden spreaders. (They were replaced 8 years ago).
>> Randy
>> CAL 2-29
>> Out Patient
>> Channel islands Ca
>> *From:* Fin Beven <finbeven@msn. com <fi… [at] msn.com>>
>> *To:* Cal_Boats@yahoogrou ps.com <Ca… [at] yahoogroups.com>
>> *Sent:* Wed, December 16, 2009 1:31:53 PM
>> *Subject:* Re: [Cal_Boats] Blade jib?
>> It was a bit easier on Radiant. We removed the forward lowers, so the
>> blade sheets just fine. We do have a low clew, maybe 1' above the deck,
>> and a full 100% sail. Just right.
>> However, this can only work if the remaining lower (the aft lower in the
>> case of an L-36) is secured to the same spot on the rail as the upper
>> shroud. If your chainplates for your uppers could be reinforced to also
>> carry the load of the lower shroud, it would sure be worth considering.
>> Our "blade" also touches the lifelines when eased, but I would consider
>> this inconsequential.
>> In anything over 15 kts of AWS, the blade is our sail-of-choice. It's
>> both faster, and much less work for the crew.
>> Fin.
>> ----- Original Message -----
>> *Sent:* Wednesday, December 16, 2009 1:10 PM
>> *Subject:* [Cal_Boats] Blade jib?
>> I am thinking of getting a new blade jib for my L-36. However, I have run
>> into a snag. In order to have a tight sheeting angle (11 degrees in this
>> case), I need to sheet inside all the rigging. I need to install a new
>> track but that is no big deal. The sticking point is that the sail needs to
>> clear the forward lower. I have finally done some calculations of what
>> will be where and have concluded that the clew can't come aft of the forward
>> lower by more than a few inches or the leech will hit the rigging.
>> The end of this long story is that to get any kind of decent sail size,
>> say a 90, the clew ends up having to be maybe a foot off the deck. I am
>> told this is a typical number for a blade jib but I want to be able to use
>> this sail for more than just beating and don't see how you can have a sail
>> that is a foot off the deck clear a lifeline that is 2 feet off the deck as
>> you let the sail out for off the wind sailing. Maybe I don't understand
>> something so I am asking this list if anyone has experience using a blade
>> jib with a low clew for general day sailing as well as racing..
>> Maybe I should forget the blade jib idea and just stick with the old sail
>> I have, which has a clew 4 feet off the deck.
>> All feedback will be greatly appreciated as I am fairly confused at this
>> point. It should be pointed out that there is lots of wind here and a 90 is
>> my typical sail of choice when not racing.
>> Allen
Re: [Cal_Boats] Mike Farrell replies to Mr. Edwards comments and concerns
mike farrell2009-12-20 13:18 UTC
Dear Allen,
I respect your racing record and . Never be ashamed of any thing. Shame and regret are too costly emotions to be squandered easily. If I have insulted you I can assure you that is not my intention. Congratulations for sailing in 20 races, many sailors will never enjoy your level of success.
My experience is somewhat different than yours. I come to sailboat racing from professional motorcycle racing (Dirt Track) I held a Competition License and raced the Grand National circuit in 1967/1969. Physical injuries put an end to all that. I have raced on SF Bay and the ocean since 1971 in boats from 8 feet with unstayed masts to 80 foot wood M boats(2/3 of a 132 foot J) I raced and sailed New York 70's with a 5 spreader rig. Santa Cruz 70, Mexico, Carribbean, Atlantic, South China Sea. 4 Pacific crossings. 1988 Pacific Cup double handed div. Well I won't go on. I do not feel high and mighty. I chose to spend a lot of time at sea instead of earning financial gain ashore. I have a great life and I choose rather than react to situations that confront me. I would hope others can learn from my time at sea as an able bodied sailor. I have earned my living from the sea and perhaps I seem opinionated at
time I see a lot of time wasted at supposition when time at sea would be more benificial to one's goals.
I went sailing 2 days last week, I am going again today. I will most likely singlehand and set an "A" chute that I have heen working on. I have installed a 4 1/2 foot removable sprit on the Cal 20 I do keep busy. And thank you for your concern, of course I will be as careful as I can be.
As always, My Best, Mike Farrell Cal 20 1114 Rambler
Sent: Sat, December 19, 2009 9:40:54 PM
Subject: Re: [Cal_Boats] Mast pumping (Mike)
Mike,
You replied to my posting of Bill Lapworth's instructions on how to tune a mast with this? WTF? My original post on mast pumping was that maybe it is a good idea to leave the lowers alone. Get a life my friend. I have limited racing, 6-1st, 10-2nd, and 2-3rd, out of 20 only races. The only guy who beats me is a two time national champion in the Express-37 class. I have nothing to be ashamed of. If this wasn't directed at me, then be careful which post you are replying to when you get all high and mighty.
> If a mast doesn't pump it is set up too tight, and it will come down, Bend the mast, crank up the back stay. accomplish the impossible--- you still got 2nd place and you do not have a clew( word play) All the computer simulations and formulas will not make up for time at sea.
>Sent: Sat, December 19, 2009 6:49:38 PM
>Allen
>On Sat, Dec 19, 2009 at 5:49 PM, Randall Alcorn <sa… [at] yahoo.com> wrote:
>>When I get around a computer I will see what I can find. I set mine up with the mast at a 2 degree rake and then I made sure the mast head was centered over the boat side to side with a halyard. Then I tighten the lowers and made sure they were equal all the way around with no sideways hooks in the mast. I then used a loos gauge to make sure I was not bar tight. Then I tightened the forward lowers a little more than the afts.
>>________________________________
>>r good wrote:
>>fore and aft lowers
>>Hi Reggie,
>>Does your boat have the fwd and aft lowers or a baby stay and 2 running back stays, that is the only way I know that prevents the pumping.
>>Randy
>>CAL 2-29
>>Out Patient
>>Channel Islands Ca
>>To: ca… [at] yahoogroups.com
>>Sent: Wed, December 16, 2009 10:12:10 PM
>>Subject: RE: [Cal_Boats] Mast pumping
>>Allen,
>>the mast onmy CAL 36 pumps. where do I get info on tuning it out? it has single uppers and dual lowers.
>>Reggie
>>The small amount of research I have done says that the dual lowers are there to prevent the mast from pumping fore and aft. I have often seen my mast get into an osculation in strong winds in the slip where the mast wiggling around like a guitar string. I hate it when it does that. In fact, I removed the mast partners for a time when I was doing some repair work on the cabin top and the mast cracked from the wind and the oscillations. Removing the mast partners makes the mast way weaker, maybe 3 or 4 times weaker.. (I get cracks in my mast often and just glue it back together so not a huge deal but it make the point.) My mast is wood and the last thing I want is to have it come down so I am not going to try and learn if it can be re-rigged. It might be that to remove them, the designers used a different section of aluminum for the mast that gave more fore and aft stability. In other words, there may be more to it than just removing
two shrouds and relocating the others. Perhaps a rigger would know. Basically, by not supporting the middle of the mast, it is something like 4 times weaker.. That however may be just fine as clearly most of the stress on the mast is sideways. I have no idea really and like I said am not going to experiment and find out. Some things are better left a mystery.
>>Disclaimer: Don't listen to anything I say because I don't know what I am talking about.
>>Allen
>>On Wed, Dec 16, 2009 at 6:52 PM, Randy Alcorn <saylorran@yahoo. com> wrote:
>>>Hi Fin,
>>>My CAL 29 has the forward and aft lowers. I hate them when it comes to windward leewards or just tacking in light winds.
>>>I am intrested in removing them, is there a calculation I have to work out to see if chainplate is strong enough to get away with it on my 2-29. I have the wide wooden spreaders. (They were replaced 8 years ago).
>>>Randy
>>>CAL 2-29
>>>Out Patient
>>>Channel islands Ca
>>>Sent: Wed, December 16, 2009 1:31:53 PM
>>>It was a bit easier on Radiant. We removed the forward lowers, so the blade sheets just fine. We do have a low clew, maybe 1' above the deck, and a full 100% sail. Just right.
>>>However, this can only work if the remaining lower (the aft lower in the case of an L-36) is secured to the same spot on the rail as the upper shroud. If your chainplates for your uppers could be reinforced to also carry the load of the lower shroud, it would sure be worth considering.
>>>Our "blade" also touches the lifelines when eased, but I would consider this inconsequential.
>>>In anything over 15 kts of AWS, the blade is our sail-of-choice. It's both faster, and much less work for the crew.
>>>Fin.
>>>From: Allen Edwards
>>>>Sent: Wednesday, December 16, 2009 1:10 PM
>>>>Subject: [Cal_Boats] Blade jib?
>>>>I am thinking of getting a new blade jib for my L-36. However, I have run into a snag. In order to have a tight sheeting angle (11 degrees in this case), I need to sheet inside all the rigging. I need to install a new track but that is no big deal. The sticking point is that the sail needs to clear the forward lower. I have finally done some calculations of what will be where and have concluded that the clew can't come aft of the forward lower by more than a few inches or the leech will hit the rigging.
>>>>The end of this long story is that to get any kind of decent sail size, say a 90, the clew ends up having to be maybe a foot off the deck. I am told this is a typical number for a blade jib but I want to be able to use this sail for more than just beating and don't see how you can have a sail that is a foot off the deck clear a lifeline that is 2 feet off the deck as you let the sail out for off the wind sailing. Maybe I don't understand something so I am asking this list if anyone has experience using a blade jib with a low clew for general day sailing as well as racing..
>>>>Maybe I should forget the blade jib idea and just stick with the old sail I have, which has a clew 4 feet off the deck.
>>>>All feedback will be greatly appreciated as I am fairly confused at this point. It should be pointed out that there is lots of wind here and a 90 is my typical sail of choice when not racing.
>>>>Allen
Allen Edwards2009-12-20 18:30 UTC
Mike,
To be clear, I never did and never would challenge your knowledge,
experience, or advice. What did offend me was that I was trying to help the
OP who wanted to find the Lapworth mast tune papers and out of the blue you
tell me I "didn't have a clew". I am not even the one complaining about
mast pump. I guess you didn't like my other posts. Perhaps you don't like
the tools I have posted for others to use. So ignore them, don't insult me
about them.
I am happy you got to go sailing last week.
In terms of simulations, one is attached. I have learned a great deal about
what is important in specifying this sail by looking at the 3d models as
well as from comments by the great people on this list. Besides, I have
learned a new skill. I hope you like it.
Best to all,
On Sun, Dec 20, 2009 at 5:18 AM, mike farrell <ve… [at] yahoo.com> wrote:
> Dear Allen,
> level of success.
> living from the sea and perhaps I seem opinionated at time I see a lot of
> one's goals.
> Rambler
> *Sent:* Sat, December 19, 2009 9:40:54 PM
> *Subject:* Re: [Cal_Boats] Mast pumping (Mike)
> Mike,
> Allen
>>> r good wrote:
>>> fore and aft lowers
>>> Hi Reggie,
>>> Randy
>>> CAL 2-29
>>> Out Patient
>>> Channel Islands Ca
>>> Allen,
>>> Reggie
>>> like 4 times weaker... That however may be just fine as clearly most of the
>>> mystery.
>>> talking about.
>>> Allen
>>> > wrote:
>>> Hi Fin,
>>> Randy
>>> CAL 2-29
>>> Out Patient
>>> Channel islands Ca
>>> Fin.
>>> jib with a low clew for general day sailing as well as racing...
>>> Allen
