3 messages2010-01-09 00:53 UTCthrough 2010-01-09 02:24 UTC
Re: [Cal_Boats] Re: Sail design
Jeff2010-01-09 00:53 UTC
Allen:
I'd like to know a bit of what your sailmaker explained if you don't mind.
I have learned quite a bit from this list, and since I will be looking for a set of sails, I certainly would benefit from what you and the rest of the group coul comment on the subject.
Speaking of sails, I have what looks to be a 150 headsail for a Cal 33. I want to sell it as the luff is about 12" too long, about the distance taken by the furler. I thought of getting it cut to fit, but the 130 is probably a better fit for the trades in the Caribbean.
The 150 looks to be in pretty decent shape, if anyone is interested, I can send detailed photos.
Jeff Cal 33
On Jan 8, 2010, at 8:18 PM, Allen Edwards <al… [at] PaloAltoPhoto.com> wrote:
Nevermind, the sailmaker explained it. Sorry to bother the list.
On Fri, Jan 8, 2010 at 1:02 PM, Allen Edwards <al… [at] gmail.com> wrote:
There are a lot of smart people on this list so maybe someone can help
me here. I just spent most of the last hour on Google trying to
figure this out but all it got me was the definition of camber. I am
trying to specify a new sail and trying to model it with a program
called SailCut CAD. No matter about that. I asked the sailmaker what
the parameters of the sail would be. I asked about entry and exit
angles and draft for three levels, and sail twist. Below is what I
got back. Anyone know how to translate between the two? The only
thing I have been able to figure out is that Camber is another word
for draft. I expected three draft numbers and one twist number, but
that isn't what I got.
Camber 11.8
Twist
Lower 18.0
Mid 22.7
3/4 30.6
Allen Edwards2010-01-09 01:12 UTC
Sure, this is what he said:
"The twist numbers work like this. if you were to have a straight plane
from the headstay to the mast, the twist numbers are degree off of that
plane to the leech of the sail. measured from the headstay."
The sailcut CAD wants the slightly different numbers. If you lay out a sail
cross section on a line from luff to leech then it wants the angle the
leading edge is relative to that line, same with the trailing edge. Draft
and camber are the same thing. SailcutCAD has a twist input that is like
the twist we all know and live but I don't yet know how it is measured.
Quantum sails are very flat on the trailing edge. I think they say this is
fast. I use them because the sails guy is wonderful. If anyone is in SF
area, ask for Don and tell him I sent you so he is even more inclined to
give me great service.
Please let me know if I can help in any way. I am spending way too much
time specifying this sail and I am just getting started.
If you are getting a 130, make sure it clears the spreaders. A fraction
less area gives you way more pointing ability.
On Fri, Jan 8, 2010 at 4:53 PM, Jeff <je… [at] yahoo.com> wrote:
> Allen:
> Jeff Cal 33
> Sent from my iPhone
> Allen
> On Fri, Jan 8, 2010 at 1:02 PM, Allen Edwards <allen.p.edwards@<al… [at] gmail.com>
>> Camber 11.8
>> Twist
>> Lower 18.0
>> Mid 22.7
>> 3/4 30.6
>> Allen
Jeff2010-01-09 02:24 UTC
Allen:
Thanks for the feedback, I'll run some measurements on the 130, I don't recall if it cleared the spreaders, I'll have to check some pics to see of it does.
I sent a couple of e mails to the quantum guys, never got a response, maybe if I let them know that I know you....
Jeff, Cal 33
