8 messages2010-01-09 22:37 UTCthrough 2010-01-13 21:39 UTC
Antenna placement
Allen Edwards2010-01-09 22:37 UTC
There was a thread a while back about antenna placement where it was pointed
out that propagation over water is different than over land and that antenna
height isn't as important as it is over land. My friend says this is due to
ducting in the water vapor layer. The result was that for some typical
antenna, all else being equal, the range would decrease from 43 miles to 40
miles if you move your antenna to the stern, if I am remembering correctly.
This difference could be easily made up by more antenna gain with a stern
mounted antenna, for example one of the 8 ft whips.
I have always had my antenna on the stern but this thread got me to thinking
and testing and I found that my antenna wasn't very good. I made a new one
that has a great VSWR. It is a simple stern pulpit mounted dipole with the
center conductor up from the pulpit and the ground half down from the
pulpit. It is grounded to the pulpit. I did this because I didn't want a 3
ft whip sticking above my pulpit if I could help it.
Next I started wondering if my pattern was any good so I looked for a
program to model antennas. I found 4NEC2, a great free program for antenna
modeling. I made a stab at modeling the stern mounted antenna as well as a
masthead mounted one.
I got better gain off a stern mounted antenna than a masthead mounted one
and if you consider the small but significant coax loss necessary for a
masthead mounted antenna, I think for sure you are better off with a stern
mounted antenna.
Next I modeled where to put the thing on the pulpit. With it off to the
side of the pulpit like I mounted it, you get some gain off to that side but
some dead spots in other directions. My conclusion was to center it on the
pulpit. Now, it might be good to have gain off to one side so that you could
turn your boat and reach further away. However, that wasn't my goal. I am
going to move my antenna to the center of the pulpit.
This is not very scientific but interesting enough that I thought I would
share it with the group in case someone wants to have a reason not to bother
with mounting an antenna up on the masthead. I continue to believe you will
get better reception over water with the antenna on the pulpit than on the
masthead.
I would love to see someone with both types of antennas run some experiments
with stations 40 miles across water.
Re: [Cal_Boats] Antenna placement
Chris Campbell2010-01-12 21:49 UTC
> one and if you consider the small but significant coax loss necessary
> for a masthead mounted antenna, I think for sure you are better off
> with a stern mounted antenna.
Does angle of heel affect your antenna? And I don't remember if you
posted a photo last time around.
Allen Edwards2010-01-12 22:04 UTC
You know, I might have been double counting the cable loss and gain
differences so the masthead mounted antenna is probably a little better. In
other words, the October analysis stands. The bottom line was that you
would get about 10% more range from a masthead antenna.
I personally don't think 10% is worth putting an antenna on the top of the
mast and risking not having range if you are distasted so my choice remains
to use a stern mounted antenna and give up the 10%
I did post a picture but if I were to build one again, I would build it
differently. I made some drawings that I have attached. I would probably
use a barrel and an elbow and then clamp the barrel to the pulpit and run
the coax along the pulpit.
On Tue, Jan 12, 2010 at 1:49 PM, Chris Campbell <
> mounted antenna.
> Does angle of heel affect your antenna? And I don't remember if you posted
> Chris Campbell
Allen Edwards2010-01-12 22:05 UTC
too much precision on the dimensions in the drawings. They don't need to be
that close.
> Allen
>> mounted antenna.
>> Chris Campbell
Re: [Cal_Boats] Antenna placement [2 Attachments]
Chris Campbell2010-01-13 17:06 UTC
> [Attachment(s) <#TopText> from Allen Edwards included below]
> it differently. I made some drawings that I have attached. I would
> probably use a barrel and an elbow and then clamp the barrel to the
> pulpit and run the coax along the pulpit.
Can you provide the dimensions? They weren't visible on the
attachments. I've got a whole binder of antenna plans for FM broadcast,
AM, the whole works. Yours looks like it's two elements secured to a
PL-259 connector. I'm happy with my masthead antenna (out of sight, out
of mind, plus it keeps birds off the Windex) but it's always fun to
experiment. And when I had to buy a new pointer for the Windex, it came
with a bird spike anyway.
Allen Edwards2010-01-13 20:46 UTC
The elements are 18 inches for 3 feet overall. The top element is intended
to be soldered into the center conductor of the connector and sealed with
silicon rubber. The bottom one is intended to be screwed to the part of the
connector that usually secures the shield. I have not built one and expect
I might have to solder the ground (down) rod to make the loop to screw to
the connector.
On Wed, Jan 13, 2010 at 9:06 AM, Chris Campbell <
> [Attachment(s) <#12628a69ec77a2ea_TopText> from Allen Edwards included
> below]
> Can you provide the dimensions? They weren't visible on the attachments.
> I've got a whole binder of antenna plans for FM broadcast, AM, the whole
> works. Yours looks like it's two elements secured to a PL-259 connector.
> I'm happy with my masthead antenna (out of sight, out of mind, plus it keeps
> birds off the Windex) but it's always fun to experiment. And when I had to
> buy a new pointer for the Windex, it came with a bird spike anyway.
> Chris Campbell
Chris Campbell2010-01-13 21:38 UTC
> intended to be soldered into the center conductor of the connector and
> sealed with silicon rubber. The bottom one is intended to be screwed
> to the part of the connector that usually secures the shield. I have
> not built one and expect I might have to solder the ground (down) rod
> to make the loop to screw to the connector.
Thank you. And remind me... these are 50 ohms, right? Seems to me that
the VHF-FM equipment differs from the standard for broadcast-band FM at
75 ohms.
Allen Edwards2010-01-13 21:39 UTC
Yes, 50 ohms.
On Wed, Jan 13, 2010 at 1:38 PM, Chris Campbell <
> 75 ohms.
> Chris Campbell
> Yahoo! Groups Links
