11 messages2010-01-10 01:46 UTCthrough 2010-01-18 15:20 UTC
Re: [Cal_Boats] Antenna placement (Allen)
Al Waschka2010-01-10 01:46 UTC
I did some of that analysis using AREPS 3.0. A few comments -
"This difference could be easily made up by more antenna gain with a stern mounted antenna, for example one of the 8 ft whips." As Lee Corso says, not so fast my friend. My initial analysis assumed 6 dB antennas which is what the 8' antennas are. Further, according to AREPS, the additional gain required is 6 dB. So you would need a 12 dB antenna. Now you may be able to find (or build) one, but West doesn't appear to sell one.. Further, since the increased gain is as a result of pattern gain we would be either introducing peaks and nulls into the azimuth pattern, or narrowing the elevation beam. Narrowing the elevation beam is problematic in that, from the side, your signal is pointed either into the air or into the water when the boat is heeled. Fore and aft the heeling results in a polarization shift with part of the energy going into the horizontal plane but at moderate angles of heel, that loss is probably negligible..
My take is, if the range is important to you, go with the masthead mount. If not, or if the increased range does not offset the increased complexity, go with the rail mount.
I suspect that the differences are small enough that they can not be validated without a calibrated antenna range and test equipment. We would be trying to measure 170 dB or so of path loss to a 6 dB accuracy. In my experience that's hard, particularly in nature.
Al
RE: [Cal_Boats] Antenna placement
Husar, Charlie [USA]2010-01-10 02:05 UTC
I love it when you guys talk dirty.
I know a fair amount about radios, but the science of radiation is almost obscene. Ahh, the fond memories of messing with the IONCAP model to see if HF users could communicate.
Have you ever noticed that when you are driving along in the far boondocks, the only radio stations you can tune in are either country music or religious stations? Gave me the idea that all critical messages should be encoded as country songs. Bound to get through.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Al Waschka
Sent: Saturday, January 09, 2010 8:46 PM
Subject: Re: [Cal_Boats] Antenna placement (Allen)
"This difference could be easily made up by more antenna gain with a stern mounted antenna, for example one of the 8 ft whips." As Lee Corso says, not so fast my friend. My initial analysis assumed 6 dB antennas which is what the 8' antennas are. Further, according to AREPS, the additional gain required is 6 dB. So you would need a 12 dB antenna. Now you may be able to find (or build) one, but West doesn't appear to sell one. Further, since the increased gain is as a result of pattern gain we would be either introducing peaks and nulls into the azimuth pattern, or narrowing the elevation beam. Narrowing the elevation beam is problematic in that, from the side, your signal is pointed either into the air or into the water when the boat is heeled. Fore and aft the heeling results in a polarization shift with part of the energy going into the horizontal plane but at moderate angles of heel, that loss is probably negligible.
Al
Al Waschka2010-01-10 03:34 UTC
Charlie, I think you've got something there.
Al
--- On Sat, 1/9/10, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: RE: [Cal_Boats] Antenna placement
Date: Saturday, January 9, 2010, 9:05 PM
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Al Waschka
Al
Allen Edwards2010-01-10 07:16 UTC
Not so fast yourself. The antenna at the masthead is certainly a 3dB
antenna. According to Al Waschka from an earlier post using AREPS, the
advantage of the masthead height could be made up by having an extra 3dB on
the stern antenna. All I am saying is that I am seeing at least a dB better
gain from the lower antenna and over 2dB less loss from the cable so you get
the 3DB with the same antenna.
The December thread concluded that a 6dB antenna on the stern would give
better range than an 3dB antenna on the masthead assuming no cable loss. I
am just updating that with the finding of a better pattern from the lower
antenna and the lower loss from any real world cable.
I was also adding detail on where to mount the stern antenna.
> Al
Michael D2010-01-10 13:05 UTC
I know of no sailboats in the south Florida area that has a stern mounted antenna. I suppose they just aren't popular here in this area. Why, I have no idea.
We typically use a handheld for ICW navigation and communication with the draw bridges. For our fixed mount VHF, we have a mast head mounted 3db antenna, cabled with hefty (.41 inch diameter) RG-213 coax.
I am no RF expert. A friend of mine that is a HAM operator "ran the numbers" for me and said that the RG-213 was the deal breaker and stay away from RG-8X. I took his advise.
Magic's Clear & Standing By.
I love it
I know a
communicate.
Have you
Waschka
To:
(Allen)
nature.
Al
Allen Edwards2010-01-10 16:58 UTC
The type of coax is important and you got good advice. 50 feet at 156MHz of
RG-213 has 1.4dB loss where RG-8x has 2.1dB so you picked up .7dB. RG-58A,
which West Marine sells, would cost you 2.9dB. That is the coax that comes
with some of the antennas you buy. I am guessing most people do not use
RG-213 as it is so big. Use RG-58A and there is no question that you are
better off stern mounted, which was my point. 4NEC2 says you pick up 1dB by
mounting an antenna at 5ft over water vs at 40ft, so that is the other dB I
was assuming.
The point from the post late last year was that an 8ft antenna on the stern
will beat a 3ft antenna on the mast even ignoring cable loss and pattern
differences.
By the way, it is important that a masthead antenna be 3ft long (or 8 ft if
you really want range). If you use one of the 1.5ft antennas like I see at
the marina, all the energy goes up about 20 degrees off of straight up and
you will get much less range.
Anyway, I see most people use mast mounted antennas and my guess is that
this is based on calculations that you get much more range but that the
calculations do not take into account transmission over water and cable
loss.
Just throwing it out there to perhaps same someone the trouble and weight
aloft.
Again, it would be great to have someone confirm this with a real world
test. I can't because I don't have a masthead antenna. It goes against
conventional wisdom but that doesn't make it wrong. Full disclosure: I am
a HAM and a degreed EE who worked in radio for 30 years but am not an
antenna or RF transmission expert.
> no idea.
> --- On *Sat, 1/9/10, Husar, Charlie [USA] <hu… [at] bah.com>* wrote:
> From: Husar, Charlie [USA] <hu… [at] bah.com>
> Cheers
> Charlie
> *From:* Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] *On
> Behalf Of *Al Waschka
> *Sent:* Saturday, January 09, 2010 8:46 PM
> *To:* Cal_Boats@yahoogrou ps.com
> *Subject:* Re: [Cal_Boats] Antenna placement (Allen)
> Al
Al Waschka2010-01-11 03:10 UTC
You may be using a 3 dB antenna at the masthead. I am too. But the analysis I ran before assumed a 6 dB antenna in all locations. At least that's what my spreadsheet said when I looked at it the other night. And that's why I said there is a benefit to mounting at the masthead..
BTW I agree with your suggestion on the centerline mount, and I don't disagree with the plan to use a stern mount. If you are considering a 3 dB antenna at the masthead vs. a 6 dB antenna on the rail and fed with the same coax in either case, the the performance will be almost identical, at least according to AREPS. The stern mount antenna has 3 dB more gain and 2 dB less line loss. The analysis I ran the other night indicates that the difference between a 10' ASL antenna and a 50' ASL antenna talking to a either a 10' ASL antenna or a 150" ASL antenna was 6 dB and you have made up 5.
Al
Date: Sunday, January 10, 2010, 2:16 AM
Not so fast yourself. The antenna at the masthead is certainly a 3dB antenna. According to Al Waschka from an earlier post using AREPS, the advantage of the masthead height could be made up by having an extra 3dB on the stern antenna. All I am saying is that I am seeing at least a dB better gain from the lower antenna and over 2dB less loss from the cable so you get the 3DB with the same antenna.
The December thread concluded that a 6dB antenna on the stern would give better range than an 3dB antenna on the masthead assuming no cable loss. I am just updating that with the finding of a better pattern from the lower antenna and the lower loss from any real world cable.
Al
Husar, Charlie [USA]2010-01-11 03:51 UTC
Hi, All. Just wanted to drop a note on dBs for the less technically inclined. In power discussion, 3 dB is a factor of two. So a 3 dB loss at a transmitter could be the difference between 12.5 watts and 25 watts of power presented to the antenna. That's a lot. At a receiver, it is still a factor of two, but now we are talking microwatts or less - very small numbers. Here's the rub. If I/they radiate half as much, I/they receive half as much (close enough for discussion) at the receiver.
Effect of losses at each end are the same. If I get a radio with a more sensitive. selective receiver, I can get back some of the losses from the remote transmitters. There is some trade-off in cost. Ideally, I would like to optimize both ends, but the improved receiver can help. Keep in mind that the losses discussed here at the transmitter are also experienced at the receiver. For 3 dB loss, we get not only one-half losses in transmit, but also in receive. I will leave out noise figures/reflections related to poor coax and poor install and cheap radios. Good to go with good stuff if you will have a heavy reliance on your radio. Choices, choices. Lesse. New sail or new radio and antenna rig?
By the by, dBs are a log 10 scale. For power, 10 dB is a factor of 10. 20 dB is a factor of 100. 30 dB is a factor of 1000. It sure adds up quick.
Next time, we can discuss the multiple ways that stereo manufacturers can lie to you about the power output of their products.
Sent: Sunday, January 10, 2010 10:10 PM
Al
On Sat, Jan 9, 2010 at 5:46 PM, Al Waschka <awaschka@bellsouth. net<http://us.mc1806.mail.yahoo.com/mc/compose?to=aw… [at] bellsouth.net>> wrote:
Al
Allen Edwards2010-01-11 04:37 UTC
Thanks for clarifying what you did with your spreadsheet. I think I was
double counting the cable loss.
What I am taking away from this clarification is that the mast mount antenna
is 6dB better than the stern one. In practice you cannot gain all of that
advantage because of other factors.
Everyone agrees on the 2dB from line loss so that leaves 4dB. An 8ft
antenna will make most of that up. But is there a way to make some of that
up with a 3ft antenna. I am seeing better patterns with an antenna closer
to the water and a slight improvement by eliminating the mast under the
antenna. I am having trouble quantifying that. I do think some of the 4dB,
if not all, is made up though. Perhaps that is already in the AREPS program
though so I might be double counting again.
Anyway, I continue to not want the weight aloft and want the antenna to work
its best if I am dismasted so remain a fan of stern mounted antennas even if
I might need more TX power. As all I want to do is hear the committee boat,
I am happy with what I have. If I wanted more range I would put up the 8ft
antenna as I have about 6 of them brand new in my garage that I inherited
and have never used.
> 5.
> Al
> --- On *Sun, 1/10/10, Allen Edwards <al… [at] PaloAltoPhoto.com>*wrote:
> Allen
>> Al
Chris Campbell2010-01-12 21:55 UTC
I've got a 1922 Crosley two-tube regenerative radio receiver, a very
early commercial home radio that in its day was operated off three sets
of batteries. I bought a power supply and hooked the thing up to my
long-wire backyard antenna. I received the two local AM radio stations,
of course, and one other--WSM from Nashville (think Grand Ole Opry).
The radio gods had obviously figured out that I wasn't a good candidate
for religious messages.
Fort Lauderdale to Key West Race 2010
Michael D2010-01-18 15:20 UTC
Hello All,
We did the Fort Lauderdale to Key West race last week. Brenda and I crewed on Sempre Amantes, a 42 foot Hunter Passage. We finished elapsed time of 23:57:08 hours and took 5th place.
Here are some photos of the race and time spent in Key West.
Crosswinds, a Corsair F-27 Formula, hit the reef, took on water, and had to be towed into Marathon. Fortunately, no one was hurt.
Scoring for the race can be seen here.
Regards,
Michael
