8 messages2010-01-23 16:01 UTCthrough 2010-01-24 16:35 UTC
Re: [Cal_Boats] Cal29 sheaves
Yahoo2010-01-23 16:01 UTC
Don-
Go to Annapolis Performance Sailing.
Www.apsltd.com
Put Sheave into the search pane. They have what you need.
Read
Read S Howarth
On Jan 23, 2010, at 7:45 AM, "cayugacalsailer" <dt… [at] twcny.rr.com> wrote:
Cal group,
Upgrading from wire/rope halyards to all 3/8 rope. Looking for sources to purchase new sheaves. There are three 4" and one 5 1/2 ", and it seems like not many sources for sheaves of that size.
Would like to hear from anyone who has gone this route, and where they purchased new sheaves. Only source I have found so far is Rig-Rite, which has exactly what I need, but not in stock.
Replacing the sheaves themselves and the new halyards seems pretty straight-forward, is there anything else I should be concerned about?
Another question on spinnaker pole length. Is as simple as from mast to just forward of the bow rail or bowsprit (if you have one)? Was given an older spinnaker from another Cal29 I would like to tryout this summer. I also acquired a 'BLOOPER', and am considering adding a bowsprit to bring it forward of the bow rail and hanging anchor. Any advice?
Always a great source of useful info, Thanks,
Don Trepanier
'74 Cal 2-29 Moses #613
Cayuga Lake
Patrick Fiega2010-01-23 23:26 UTC
I would admit, Zephyrworks is awesome. I had a full set made for my Cal40 and everything fit perfectly. They were great to work with and extremely quick in delivery.
Partick
Wheee Dogggie, Cal 40
On Jan 23, 2010, at 10:27 AM, David Wilkie Owen <dw… [at] cox.net> wrote:
Don,
Zephyrwerks. Not cheap, but they will build any sheave you want and are very top quality: http://zephyrwerks.com/
For halyards; 3/8" Sta-set works OK - relatively low stretch. 3/8" Sta-set X works better -- has even less stretch, but it "grows" after a while and in my case the cabin top clutches now are too tight, making it harder to handle. My Lewmar clutches were expensive and it's painful to think about replacing them.
Spinnaker Pole length should equal your "J" measurement from the mast to the headstay. Cal 29 should be 12' 3" and this per PHRF rules if you want to race her as such.
I replaced one of the through bolts on my stem fitting with a piece of 3/8" stainless threaded rod, cut to the proper length. I bought a section of 1" stainless tube and a 3/8" threaded stainless eye - http://tinyurl.com/eyenut - to cap it with. I made the tube/nut combination 6" long so it would clear the bow fitting but not carry too much side loading. It looks marginal but has worked like a charm for several years. I believe that the latest PHRF class rules allow this modification, though your local PHRF may not.
Hope this helps:
David Wilkie Owen
On Jan 23, 2010, at 7:45 AM, cayugacalsailer wrote:
Cal group,
Don Trepanier
Cayuga Lake
RE: [Cal_Boats] Cal29 sheaves
Husar, Charlie [USA]2010-01-24 10:37 UTC
Don, make sure to check the thickness. In some cases, the old sheaves were skinnier.
Standard spin pole for symmetric chute would match your J measurement (front of mast to forestay base).
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Yahoo
Sent: Saturday, January 23, 2010 11:02 AM
Subject: Re: [Cal_Boats] Cal29 sheaves
Don-
Www.apsltd.com<http://Www.apsltd.com>
Read
Read S Howarth
On Jan 23, 2010, at 7:45 AM, "cayugacalsailer" <dt… [at] twcny.rr.com<mailto:dt… [at] twcny.rr.com>> wrote:
Cal group,
Don Trepanier
Cayuga Lake
Read Howarth2010-01-24 12:56 UTC
Charlie-
Very good point. He only gave the diameter, but if enough people are having them made, then It may mean they are not available in the required thickness.
R
Read S. Howarth
rs… [at] yahoo.com
--- On Sun, 1/24/10, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: RE: [Cal_Boats] Cal29 sheaves
Date: Sunday, January 24, 2010, 5:37 AM
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Yahoo
Don-
Www.apsltd.com
Read
Read S Howarth
On Jan 23, 2010, at 7:45 AM, "cayugacalsailer" <dtrepan1@twcny. rr.com> wrote:
Cal group,
Don Trepanier
Cayuga Lake
Donald2010-01-24 15:59 UTC
Well, once again a lot of helpful links/tips. Thanks
Sheave thickness is exactly 1/2 inch. Don't know if the old ones were
original, but have them here. They're made of some kinda brownish
composite material, doesn't look plastic, definitely not any type of
metal or alloy.
Think I will give Zephyrwerks a call. Rig-Rite has the exact sizes I
need, but availability is iffy.
I was thinking 12'3" for the spinnaker pole. Thanks for confirming it.
Since haul out in October I've purchased new halyards, sheets for the
blooper, had the sails serviced and cleaned @ Sailcare (I highly
recommend them), and now working on the new sheaves. Think a spinnaker
pole might wait a bit. Really looking forward to playing with the Blooper.
How much attention should I pay to the pin in my sheave project? It
looks to be 1/2 inch aluminum and in decent shape.
Thanks once again
Don Trepanier
Cayuga Lake
> were skinnier.
> Cheers
> Charlie
Carlos Alden2010-01-24 16:07 UTC
Don:
I haven't been following your thread, just saw this latest post. If you're looking to replace the blocks with the original material, those are likely made of tufnol. You can find replacements at the Wooden Boat Foundation store:
http://shop.woodenboat.org/c-112-tufnol-blocks-for-38-to-58-line.aspx
Carlos
Date: Sun, 24 Jan 2010 10:59:05 -0500
metal or alloy.
Thanks once again
Don Trepanier
Cayuga Lake
> were skinnier.
> Cheers
> Charlie
Allen Edwards2010-01-24 16:20 UTC
You desceiption of the sheave material matches my sheaves, which are Phenolic.
Mine were machined by Svendsen's Marine in Alameda. There are actually 5
things you need to specify. Diameter, thickness, hole diameter, hole lining
(bronze or not), and grove shape. There are 3 basic grove shapes. Wire is
a "V", rope which is half circle, and high tech, which is a "U". There are
also combinations like a half circle with a "V" in the bottom that will hold
either rope or wire. My pin is a SS bolt. It used to be bronze but I bent
it. There was no sign of wear in the old phenolic sheaves in the hole area
after 50 years so I didn't get the bronze insert and am not too worried
about the pin. I used SuperLube to grease things up, which was recommended
by Svendsen's and is the best grease for a boat owner there is. I replaced
mine because one of my crew ran the halyard up hard with the jib tack not
snapped.
The other thing to note is that this material is not always the same
thickness because of how it is made. They can machine it down to size but
that puts a rough surface on it instead of the stock smooth surface. Or you
can get it a few thousands oversize if it happens to be a little thick like
I did thinking it would be fine and spend 4 hours at the top of the mast
sanding to make it fit. Obviously, take the time to figure that out and
don't do what I did.
> metal or alloy.
> Thanks once again
> Don Trepanier
> Cayuga Lake
> > were skinnier.
> > Cheers
> > Charlie
mike farrell2010-01-24 16:35 UTC
We used bloopers on IOR boats to improve steering balance . It added 1//4 to 1/2 a knot. It is trimmed with the halliard as opposed to the sheet. So the mast man trims it. Let it way out till it almost touches the water in smooth seas .It adds another layer of complication and is cut very full so it is best when going deep. You competition will know when you are going to gybe when the bloop comes down.
My Best, Mike Farrell Coyote Cal 20 #61
Sent: Sun, January 24, 2010 7:59:05 AM
metal or alloy.
Thanks once again
Don Trepanier
Cayuga Lake
> were skinnier.
> Cheers
> Charlie
Yahoo! Groups Links
