Perkins 4-154 engine parts
1 messages2010-02-02 17:22 through 2010-02-02 17:22
richbel2010-02-02 17:22
We recently removed a perkins 4-154 engine for a motor swap. It was a running take out but #1 cylinder sucked a ring. Everything else is in good to great shape if anyone is interested. Exhaust Manifold with heat exchanger, boots and mixing elbow. $1000.00 Fresh Water Pump with housing and pulley. $200.00 Hurth Transmission with adaptor plate and flex plate HBW250-3R: Ia=2,74 Ib=2,72: Nr.:18-19553 $900.00 Injection Pump with 4 injectors & high pressure lines. $500.00 Cylinder head with bolts, rocker arm, push rods, valve cover & thermostat housing. $1000.00 Raw water pump (near new) with new pulley. $400.00 Double oil cooler. $300.00 Delco gear reduction starter, 12 tooth with adaptor. $50.00 2800 for all of it. Contact me offline if interested. Thanks, Rich ri… [at] yahoo.com
