3 messages2010-02-05 00:05 through 2010-02-06 21:19
Cal 34 cutlass bearing replacement
twoarchitects2010-02-05 00:05
Greetings fellow Cal sailors
I have been reading the post in this group for couple of years now started when my business partner was slogging through the dreaded beam replacement of his Cal 29 and made a connection here that was very helpful to his project. Very informative and welcome exchange of info most days. I am hoping one of you could lend me a little off your experienced replacing the cutlass bearing on a Cal 34 primarily the outside bearing tube diameter and length. Mine has one of the Westerbeke conversions in it with a paragon gear and Walter v-drive turning a 1" shaft. The cutlass bearing is lodged in the deadwood/back of keel I am assuming held in with screws through the fiberglass tube, easy enough to look at out of the water but where I live we only get a few days in the boat-yard at time (at great expense) and that is not enough time to order and fly in a new bearing after pulling it out and finding out what I have. In any case I suspect the tube dimensions are fairly standard and if one off you recall those at least that would give me a place to start. Any information you may impart in this would be appreciated.
Sean
S/V Tango
1975 Cal 34-2
Juneau, AK
Re: [Cal_Boats] Cal 34 cutlass bearing replacement
Tom Miller2010-02-05 01:40 UTC
Hi Sean,
I don't know the dimensions off hand but when I replaced mine in Seward, there were two shops that had them available there. As I recall, they cut the length down but that was it. This was on a 1975 Cal2-34 back in 92. Seems like someone in Juneau should have one on hand given all the boat traffic in southeast AK.
Tom
Sent: Thu, February 4, 2010 4:05:31 PM
Subject: [Cal_Boats] Cal 34 cutlass bearing replacement
Greetings fellow Cal sailors –
I have been reading the post in this group for couple of years now – started when my business partner was slogging through the dreaded beam replacement of his Cal 29 and made a connection here that was very helpful to his project. Very informative and welcome exchange of info most days. I am hoping one of you could lend me a little off your experienced replacing the cutlass bearing on a Cal 34 – primarily the outside bearing tube diameter and length. Mine has one of the Westerbeke conversions in it with a paragon gear and Walter v-drive turning a 1" shaft. The cutlass bearing is lodged in the deadwood/back of keel – I am assuming held in with screws through the fiberglass tube, easy enough to look at out of the water but where I live we only get a few days in the boat-yard at time (at great expense) and that is not enough time to order and fly in a new bearing after pulling it out and finding out what I have. In any case I suspect the
Sean
S/V Tango
1975 Cal 34-2
Juneau, AK
Yahoo! Groups Links
Re: Cal 34 cutlass bearing replacement
Sean2010-02-06 21:19
Thanks Tom - I will check around to see if anyone else local has a variety of stock to choose from (I did check in at one shop, who said they can order anythign, but so can I). Surprisigly enough I have found Seward and Homer seem to have better in-town parts resources than Juneau. Sitka as well. Not sure why - we cetaily have a large boat population here. Its $600/weekend to haul out here, so hate to not be prepared. Dont think I can put it off and squeeze a 5th year out of this bottom paint.
Thanks again for the comment.
Sean
--- In Ca… [at] yahoogroups.com, Tom Miller <tmiller111@...> wrote:
> Hi Sean,
> Tom
> From: twoarchitects <smb.architect@...>
> Greetings fellow Cal sailors â"
> I have been reading the post in this group for couple of years now â" started when my business partner was slogging through the dreaded beam replacement of his Cal 29 and made a connection here that was very helpful to his project. Very informative and welcome exchange of info most days. I am hoping one of you could lend me a little off your experienced replacing the cutlass bearing on a Cal 34 â" primarily the outside bearing tube diameter and length. Mine has one of the Westerbeke conversions in it with a paragon gear and Walter v-drive turning a 1" shaft. The cutlass bearing is lodged in the deadwood/back of keel â" I am assuming held in with screws through the fiberglass tube, easy enough to look at out of the water but where I live we only get a few days in the boat-yard at time (at great expense) and that is not enough time to order and fly in a new bearing after pulling it out and finding out what I have. In any case I suspect the
> Sean
> S/V Tango
> 1975Â Cal 34-2
> Juneau, AK
> Yahoo! Groups Links
