FW: Cal-36 aft Cockpit Window
1 messages2010-02-13 17:23 UTCthrough 2010-02-13 17:23 UTC
r good2010-02-13 17:23 UTC
in case anyone can use this info. Reggie > Subject: Cal-36 Cockpit Window > > Here are the dimensions for the cockpit window. The screws were > stubborn, of course, but we took off the inside frame, took measurements > and even traced a template to double check our measurements. I then > plugged the numbers into my CAD program and am attaching the results. > Maybe the window manufacturer can use the file. It is saved in Autocad > 2000 format. I also scanned a copy so that you can see it as well. > Mike
