4 messages2010-03-07 20:53 UTCthrough 2010-03-08 13:56 UTC
Re: [Cal_Boats] 39 Cal MK II
Paul2010-03-07 20:53 UTC
Is there a listing with photos we can look at? I have an 80 Mk.ll with aft cabin and starboard galley. Is this your layout? What engine do you have? Tall or short rig, deep or shallow draft? Look close for soft decking. Vinyl wall covering hides leaks. Look close at mast step. Pull up as much sole as you can around it. Marinized VW. Engines ran hot get an engine survey by a mechanic. Good luck,
PauL west
Adventure kwest
'80 Cal 39
cd… [at] yahoo.com wrote:
>Hello all Cal owners,
>I am new to the group. I joined this group to learn more about Cal Sail boats specifically the Cal 39.
>Anyone with info, remarks, faults, specs, etc... with this vsl would be helpful as I am about to purchase this beauty. A 1984 MK II.
>Thanks to all!!
>Chris
Bruce Stirling2010-03-07 22:43 UTC
http://sailboatdata.com/VIEWRECORD.ASP?CLASS_ID=3670
> PauL west
> Adventure kwest
> '80 Cal 39
Bruce Stirling2010-03-07 22:45 UTC
http://cal-39-2-maintenance-logs.blogspot.com/
>> PauL west
>> Adventure kwest
>> '80 Cal 39
Robert Bruce Stirling, II, Esq.
602.254.6638
602.460.5631 [Cell]
602-507-9445 [Fax]
520-302-5206 [Tucson]
http://www.stirlinglaw.com/lawyers
The information in this e-mail communication is Privileged and
Confidential. If you are not the intended recipient, please contact the
undersigned sender immediately and then delete this e-mail.
Wayne Gillikin2010-03-08 13:56 UTC
Bruce,
I have a couple of questions for you. First, are you getting an '84 Lapworth design or an '88 Hunt design? Big difference in the boats. Secondly, are you getting the boat from McMichaels? McMichaels is a stones throw from where I keep my boat and was the Cal dealer (back in '82/'83) who sold her to the original owner. I actually thought you were on the West coast.
If the McMichaels listing was only an example you need to be aware that there was a radical change in the boats about '85/'86. If you are looking at an '84 it is likely a Mk 3. Take a look at
http://www.cal39.info/nica/cal39nica.html
for an interior picture. Unfortunately none of us has put up a good pic of the cabin.
If you look here
http://www.cal39.info/mk3pg4.PDF
and here
http://www.cal39.info/mk3pg3.PDF
you will see the layout of the standard Mk 3 interior. The line drawing at
http://www.cal39.info/cal39mk3.html
shows the Mk3 with the optional head in the aft cabin. Adding the head removes the nav station.
If you have pix of the boat you are considering send them along. Also, look at the Roster at
http://www.cal39.info/cal39roster.html
and see if the HIN is listed.
If you have any questions don't hesitate to ask. Also, if you do ultimately choose a Lapworth Cal 39 let me know and I will put up a boat info page for you at www.cal39.info.
Regards,
Wayne Gillikin
"Elusive"
Cal 39 1983 Mk 3
Sent: Sun, March 7, 2010 5:45:27 PM
Subject: Re: [Cal_Boats] 39 Cal MK II
http://cal-39- 2-maintenance- logs.blogspot. com/
On 3/7/10, Bruce Stirling <bruce@stirlinglaw. com> wrote:
http://sailboatdata .com/VIEWRECORD. ASP?CLASS_ ID=3670
>>PauL west
>>>>Adventure kwest
>>>>'80 Cal 39
602.254.6638
602.460.5631 [Cell]
602-507-9445 [Fax]
The information in this e-mail communication is Privileged and Confidential. If you are not the intended recipient, please contact the undersigned sender immediately and then delete this e-mail.
