4 messages2010-03-16 21:20 UTCthrough 2010-03-17 16:28 UTC
Rail removal -- Forstner Bits
Donald Dutton2010-03-16 21:20 UTC
http://www.traditionalwoodworker.com/default.php?cPath=269_270&gclid=CLK_t-eXvqACFSgnawod-jSF1A
This site gives a look at the bits similar to the ones I use. Do not buy a cheap one! Same as with good chisels or planes or saw blades -- the quality of the carbide steel cutting edge matters a lot when trying to save a $100 piece of teak! I have owned my bits for well over 25 years. The Admiral said they were too expensive when I bought them!
You can get name brand bits from Lowes, Home Depot, or Sears, also.
Re: [Cal_Boats] Rail removal -- Forstner Bits (Donald)
Wayne Gillikin2010-03-16 21:34 UTC
Do you use these forstner bits in an electric drill or a hand drill (Brace)?
Sent: Tue, March 16, 2010 5:20:50 PM
Subject: [Cal_Boats] Rail removal -- Forstner Bits
http://www.traditio nalwoodworker. com/default. php?cPath= 269_270&gclid=CLK_t- eXvqACFSgnawod- jSF1A
Re: [Cal_Boats] Rail removal -- Forstner Bits (Wayne)
Donald Dutton2010-03-17 16:00 UTC
I use a variable speed electric drill, though a brace would work well also. I start out at a very low rpm to make certain the bit is cutting the surface evenly. This eliminates any potential for drift. Plus, if my centerpunch was off I can see it immediately and adjust -- rarely happens! As the bit cuts I increase pressure on the trigger and speed the bit up, but rarely above half of the operational speed of the drill. That way I can "feel" when the bit finds the screw head and immediately stop the drill.
BTW I agree with your not using epoxy or glue on interior bungs. My interior is oiled as well and the teak plugs don't have any problem when oiled rather than varnished. I would always use glue or epoxy if varnishing. I prefer epoxy as the oils in teak keep wood glues from working well. However, I still prefer drilling out the bung rather than having to break it if stuck. This is bound to cause extra pressure on one side or the other of the original drilled hole causing an uneven fit of the new plug. Small detail, but perfectionism runs in my blood.
PS I inherited a 50 year old Stanley brace when clearing out my father's home last May. I plan on passing it on, along with how to use it, to my son. Something about handtools that is so satisfying. I think it has something to do with why I love a sailboat. I don't mind a motorboat -- was raised riding on my uncles' Chris Crafts -- but the press of sail and the harnessing of forces of nature and the skill required are definite motivators!
Sent: Tue, March 16, 2010 2:34:03 PM
Subject: Re: [Cal_Boats] Rail removal -- Forstner Bits (Donald)
Michael Kennedy2010-03-17 16:28 UTC
On Mar 17, 2010, at 9:00 AM, Donald Dutton wrote:
> snipped
I have a hand drill that my grandfather repaired by replacing a wooden
handle with a piece of pipe and a cap. He soldered the pipe to the
metal frame and it is still good 65 years later. I had a rip saw that
my great grandfather had owned with the sawyer mark on the blade still
readable but I made the mistake of mentioning it to a contractor
working on my house and it was gone the next day. I still have the
crosscut saw but the sawyer mark isn't readable anymore. I carved my
initials in the wood handle when I was six, which would be 66 years
ago. Both saws date to about 1865.
Mike Kennedy
Conquest Cal 40 # 96
> From: Wayne Gillikin <wa… [at] yahoo.com>
> (Brace)?
