21 messages2010-03-23 14:30 through 2010-03-25 04:17 UTC
Holding tank repair (head)
sculler20002010-03-23 14:30
All,
I have a 20-25-ish Gal. holding tank on my Cal 31 for the head. It has a failed plastic heat weld on the top seam. The tank looks to be several flat sheets welded together and it feels like HDPE. Milky white, hard, not roto-molded.
The failed seam is on the top so no actual leaks yet, but that explains some funky odors this year.
I want to fix it in place. Anyone have good suggestions? Must I heat weld to repair or is there a glue or epoxy worth trying first?
If I must heat weld, how tough is that to learn on the fly?
Whiel I am at it, I am also going to re-plumb and get rid of the over-the-side capabiltiy as it is just more stuff to leak/ break / smell/ get fined for.
Thanks for any advice.
Chris
Cal 31
Poulsbo, WA
Re: [Cal_Boats] Holding tank repair (head)
Fred Haas2010-03-23 15:03 UTC
Chris,
Contact Marine Sanitation in Seattle. They are the experts, and a
bunch of really good folks. They are next door to Fisheries Supply. I
attended one of their classes and was pleased with what I learned and
how it was presented.
Fred Haas
3-30 Nemesis
Tacoma
On Mar 23, 2010, at 7:30 AM, sculler2000 wrote:
> All,
> Chris
> Cal 31
> Poulsbo, WA
1972 Cal Jensen T4
Sabine Faulhaber2010-03-23 15:42 UTC
Hello fellow Cal boaters,
I have found an interesting listing on San Diego craigslist but know virtually nothing about the model. Can anyone chip in some background on the Cal T4?
Sabine
http://sandiego.craigslist.org/csd/boa/1656173263.html
Re: [Cal_Boats] 1972 Cal Jensen T4
Gerald Sobel2010-03-23 16:44 UTC
Sabine,
Such a deal! Well, that's inflation for U. I paid $450 for my Cal 24 original oldie (not a T4 which is an IOR design) in 1996, but it didn't come with an outboard. I had to go far and fetch one, it cost me another $300. Your design is about 15-20 years 'newer' than mine....
But when I hauled her I spent three months at the boat yard, much of which was on the rusted out centerboard that would get stuck...the boatyard folks said I'd put too much paint on it, so all the time I spent scraping off the new paint was a waste, 'cause they were dead wrong. Turned out that the lifting fulcrum was in the wrong place, and I had to re-place (after I had built a new one and put it in the original location) it and cut it into the lowest rung of the companionway ladder. Lots of scraping and painting.
Believe it or not, the best thing would be to have it surveyed either by are paid one or a very experienced friend. It has no Centerboard so you won't have to worry about that. Best to go see the boat and see how you like it. I believe that are reasonably fast, stable boats.
Good Luck,
--- On Tue, 3/23/10, Sabine Faulhaber <su… [at] yahoo.co.uk> wrote:
Subject: [Cal_Boats] 1972 Cal Jensen T4
Date: Tuesday, March 23, 2010, 8:42 AM
Sabine
http://sandiego. craigslist. org/csd/boa/ 1656173263. html
RE: [Cal_Boats] Holding tank repair (head)
john raxter2010-03-23 16:47 UTC
My understanding is the HDPE can be welded like a glue stick (hot melt glue
gun). Otherwise, 5200 should seal crack. Epoxy will work to join panel,
edges or joints, the joining surfaces should be heated (plumbers torch)
prior to gluing.
YMMV
John
Of sculler2000
Sent: Tuesday, March 23, 2010 10:31 AM
Subject: [Cal_Boats] Holding tank repair (head)
All,
roto-molded.
get fined for.
Chris
Cal 31
Poulsbo, WA
RE: [Cal_Boats] 1972 Cal Jensen T4
Husar, Charlie [USA]2010-03-23 16:53 UTC
Sabine, it is almost a flat deck that was built for MORC. Bolt on keel I believe (as opposed to encapsulated). Rudder is off the stern as in J/24s. T/4 never really caught on. I've been in a couple of them, but can count the Chesapeake population I've seen on one hand. Do not know how they sail. Interior space less than a CAL 25 due to pinched stern and a few other IOR design considerations. Hope this helps a little.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Sabine Faulhaber
Sent: Tuesday, March 23, 2010 11:42 AM
Sabine
Chris Campbell2010-03-23 17:15 UTC
sculler2000 wrote:
> All,
The Gougeon Bros. have a method for using epoxy on plastics. It
involves waving a propane torch flame lightly over the surface to
oxidize the plasticizers, as I recall. Go to their web site. I've
used epoxy on a Porta-Potti waste tank corner. I roughed it up
thoroughly and then applied epoxy and some glass. This was before I
read their procedure. It's held for many years, but I do avoid
stressing it. I'm not sure what the plastic is--it's not the same stuff
as the top section of the device. This is a very old unit.
Frans Sell2010-03-23 18:17 UTC
Hello Sabine,
I used to own a Cal T4, it was a fun boat, especially for day sailing. We moved up to a Cal 29 though because we enjoy cruising a lot so we went for the head room. If you're just buying to day sail its a great boat and that's a cheap price to boot. It not as fast as a J24 and its also a pretty heavy boat. I never had any issues with mine although it was my first, I didn't know what I was looking at half the time.
Good luck,
Frans
Sent: Tue, March 23, 2010 8:42:20 AM
Sabine
Re: [Cal_Boats] 1972 Cal Jensen T4(Frans and Sabine)
Gerald Sobel2010-03-23 21:27 UTC
Sabine, Frans,
Consider this: If this is your first boat, it is a lot of boat, a lot of boat that will take you anywhere you want to go, when you are ready for it. My experience with sailboats is you are either on deck sailing, or below, sleeping prone, so headroom isn't a big issue. After you have mastered handling a 24', two ton, boat, move up from there. What I see often is people biting off more than they can chew, and consequently, never leaving the dock.
Get plenty of boat handling experience, get an experience good crew to help you, then, teach some novice crew to be useful, then plan some local cruising, and by all means, do some cruiser class racing if you really want to learn how to sail. I can walk all over Hunter and Benetaus in the 35' to 45' class because so often the skippers haven't a clue how to get maximum power out of their sails by properly trimming them for maximum L/D, lift over drag, as pilots would say...or optimum trim for a given wave state or wind strength.
My two centavos,
--- On Tue, 3/23/10, Frans Sell <fr… [at] yahoo.com> wrote:
Subject: Re: [Cal_Boats] 1972 Cal Jensen T4
Date: Tuesday, March 23, 2010, 11:17 AM
Hello Sabine,
Good luck,
Frans
Sabine Faulhaber <supergirl_sb@ yahoo.co. uk>
Sabine
mike farrell2010-03-24 00:08 UTC
If when you look at the boat you are considering--- It should look like your first boyfriend (or girlfriend) As you walk away from your boat, as you look over your shoulder, you should feel something in your chest. Pride, success, contentment, far shores to be conquered and explored. If you look at "Your boat" and say " O s---, What a turkey! your sailing career with this vessel will be short and sad. Then ---a new (another) boat or perhaps Golf.
My 2 pesos worth
Mike Farrell, a 2 boat owner ( or do they own me?)
Sent: Tue, March 23, 2010 2:27:10 PM
Subject: Re: [Cal_Boats] 1972 Cal Jensen T4(Frans and Sabine)
Sabine, Frans,
My two centavos,
>From: Frans Sell <fr… [at] yahoo.com>
>Hello Sabine,
>Good luck,
>Frans
From: Sabine Faulhaber <supergirl_sb@ yahoo.co. uk>
>Thanks,
>Sabine
Sabine Faulhaber2010-03-24 00:52 UTC
Thanks all for your input. I was just curious about this boat (thirst for knowledge I guess) and eyeing what's out there to putz around in Mission Bay (San Diego) with while my beautiful Cal 3-30 sits up in Santa Barbara waiting for me to break free from my Mo-Fr 9-5 chains to visit her - sadly let me first love, my little Cal 25 go early last year - had I know I would be back in SD...
Sabine
Sent: Tue, 23 March, 2010 17:08:34
If when you look at the boat you are considering- -- It should look like your first boyfriend (or girlfriend) As you walk away from your boat, as you look over your shoulder, you should feel something in your chest. Pride, success, contentment, far shores to be conquered and explored. If you look at "Your boat" and say " O s---, What a turkey! your sailing career with this vessel will be short and sad. Then ---a new (another) boat or perhaps Golf.
My 2 pesos worth
Sabine, Frans,
My two centavos,
--- On Tue, 3/23/10, Frans Sell <franssell@yahoo. com> wrote:
>From: Frans Sell <franssell@yahoo. com>
>Hello Sabine,
>Good luck,
>Frans
>Thanks,
>Sabine
Dave & Cathy Paulson2010-03-24 01:04 UTC
Regarding HHDPE repair the surface must be treated with the very tip of the flame to oxidise the surface. you can tell if you have done it right by spraying water on the surface and it should not bead up but leave a shine. This is need to be done in my years of making plastis containers before printing. Dont cook it but use the very tip of the flame.
Dave Paulson
Allergia
Channel Islands Ca
Sent: Tuesday, March 23, 2010 10:15 AM
Subject: Re: [Cal_Boats] Holding tank repair (head)
sculler2000 wrote:
> All,
Allen Edwards2010-03-24 01:11 UTC
I had a guy "weld" the holding tank on my motor home and watched what he
did. He had a strip of scrap plastic of the same type and used it like
solder with one of those old soldering guns we used to use in metal shop 50
years ago. Seemed simple enough and what I would try rather than holding a
flame to the tank and then putting something non-flexible on
a flexible tank. But again, I don't know what I am talking about so don't
listen to me.
On Tue, Mar 23, 2010 at 6:04 PM, Dave & Cathy Paulson <dp… [at] socal.rr.com
> Dave Paulson
> Allergia
> Channel Islands Ca
> *From:* Chris Campbell <cl… [at] charterinternet.com>
> *Sent:* Tuesday, March 23, 2010 10:15 AM
> *Subject:* Re: [Cal_Boats] Holding tank repair (head)
> sculler2000 wrote:
> > All,
> roto-molded.
> Chris Campbell
Gerald Sobel2010-03-24 04:35 UTC
Sabine,
Many years ago I raced against a T4 in the Del Rey Yacht Club Bill Stein cruiser series, it sailed very well, very competitively, and from what I gleamed, it's owner was very happy with her. Good looking boat too.
I owned a Cal 25 for a number of weeks, that I bought off of EBay. It came from San Diego, a Navy Base, and I sailed it up to Marina del Rey, and sold her after racing her once. Too big a boat for me...smaller boats are just more fun, closer to the waves and water!
Date: Tuesday, March 23, 2010, 5:52 PM
Sabine
<vectormenow@ yahoo.com>
My 2 pesos worth
Sabine, Frans,
My two centavos,
Hello Sabine,
Good luck,
Frans
Sabine
Helen Horn2010-03-24 18:00 UTC
the difference between "TURN KEY" and "TURKEY" is the N... it is easier to Buy ...than to sell..but go ahead drive in ... any boat is better than no boat..and Cal'S are Great..try to get a boat that some good points (nice interior & complete With sails
galley ect)..craigslist is great ... remember 1 year slip
rent is appox $2000.00 so LOW purchase price is not as important ..2 or 3 years later ... good luck ed&helen
Sent: Tue, March 23, 2010 5:08:34 PM
My 2 pesos worth
Sabine, Frans,
My two centavos,
>Hello Sabine,
>Good luck,
>Frans
>Thanks,
>Sabine
Chris Campbell2010-03-24 20:52 UTC
Beth Leonard wrote, "If you get a thrill motoring up to your boat in
the dinghy and think she's the best-looking yacht in a crowded tropical
anchorage, you'll resent it less when the head clogs or the generator
breaks down." Nick Nicholson wanted a good-looking boat: "When I row
away from it, I have to have the irresistible urge to rest on my oars
and be happy with what I see." For Red Marston, "it was important to
look out a window and see one's boat in a cove, and silently reflect,
'Isn't she a beauty.'.... all it had to do was to please the eye, to
make the purchase and upkeep, large or small, worthwhile." Joel White
observed that "More attention is paid to a handsome craft by everyone
involved in her care.... Such a boat will last longer than the homely
and less-loved craft on the next mooring."
And as I've said before, when I row away from /Martha C/, I always get a
big smile when gazing on that pretty and durable little boat.
Cal 20 #1220
Seafarer Polaris #13
and all those little boats too.
Chris Campbell2010-03-24 20:58 UTC
Since I've got my collection of boat quotes out, I'll cite Ernest Gann:
"In large vessels there is travail and perplexity; in small vessels
there is joy."
chris1232010-03-25 01:28 UTC
Completely agree. Moving from a 22 footer (the cal 20 is still a project) to
a 29 footer was real interesting. You tend to overlook things like,
electrical systems AC & DC, auxilary power thats not an outboard, water
intake sytems, plumbing, septic, ventilation, ground tackle, sails,
navigation systems and the list goes on. Now what's interesting is that you
have two options. Become proficient in all areas or bend the wallet inside
out. In either case, there's a lot of bending going on.
Smaller boats once sorted, tend not to have the same level of maintenance
and upkeep requirements as larger ones. Would I trade the 29, never...my
solution is to buy more reference manuals and even they are getting
expensive. Ever see the price of the ABYC electrical standard reference
text....wow.
best regards with whatever choice you make.
The other Chris
mike farrell2010-03-25 01:54 UTC
God bless you!
Sent: Wed, March 24, 2010 1:52:30 PM
Beth Leonard wrote, "If you get a thrill motoring up to your boat in the dinghy and think she's the best-looking yacht in a crowded tropical anchorage, you'll resent it less when the head clogs or the generator breaks down." Nick Nicholson wanted a good-looking boat: "When I row away from it, I have to have the irresistible urge to rest on my oars and be happy with what I see." For Red Marston, "it was important to look out a window and see one's boat in a cove, and silently reflect, 'Isn't she a beauty.'.... all it had to do was to please the eye, to make the purchase and upkeep, large or small, worthwhile." Joel White observed that "More attention is paid to a handsome craft by everyone involved in her care.... Such a boat will last longer than the homely and less-loved craft on the next mooring."
And as I've said before, when I row away from Martha C, I always get a big smile when gazing on that pretty and durable little boat.
Cal 20 #1220
mike farrell2010-03-25 02:03 UTC
Ernie Gann is one of my Heroes. He is the one of the most sensitive writers I have ever experienced
My Best, Mike.
Sent: Wed, March 24, 2010 1:58:01 PM
Since I've got my collection of boat quotes out, I'll cite Ernest Gann: "In large vessels there is travail and perplexity; in small vessels there is joy."
David Wilkie Owen2010-03-25 04:17 UTC
Absolutely agree -- All Sailors (not to mention pilots -- many sailors
being same) should be required to read pretty much everything Gann has
ever written. Highly recommended.
Wilkie
> My Best, Mike.
> Chris Campbell
