4-107
4-107
4 messages2010-04-03 13:47 UTCthrough 2010-04-03 23:49 UTC
4-107
r good2010-04-03 13:47 UTC
so, since we have been in no rush, we've putted along at about 4.5-5 knots, getting fuel useage of 1/2 gal per hour. not too shabby! Reggie
Re: [Cal_Boats] 4-107
mike2010-04-03 17:55 UTC
It does sound pretty good. I calculated /Celtic Naut's/ 4-107 at .8 gallons at 6 kts. I had no idea what RPM I was running at since there isn't a gauge yet and since the old prop was severely over pitched to thepoint I couldn't make 2000 (by ear) before it bogged the motor. (I set the throttle to "just before bogging and belching smoke" when I calculated my fuel). I have already replaced the old 16x16 with a 16x10 but haven't had the opportunity to check it out. So all my numbers are going to change when I install gauges etc. I should get similar performance even though we're a little bigger. What RPM are you running at? Mike On 4/3/2010 9:47 AM, r good wrote: > > > so, since we have been in no rush, we've putted along at about 4.5-5 > knots, getting fuel useage of 1/2 gal per hour. not too shabby! > Reggie >
mike farrell2010-04-03 22:30 UTC
perkins 4/107 is a hell of an engine from a London Taxi to a marine application. My best, mike From: r good <my… [at] hotmail.com> To: ca… [at] yahoogroups.com Sent: Sat, April 3, 2010 6:47:56 AM Subject: [Cal_Boats] 4-107 so, since we have been in no rush, we've putted along at about 4.5-5 knots, getting fuel useage of 1/2 gal per hour. not too shabby! Reggie
RE: [Cal_Boats] 4-107
r good2010-04-03 23:49 UTC
installed new tach. need to calibrate it but don't know how reggie To: Ca… [at] yahoogroups.com From: mi… [at] wahini.org Date: Sat, 3 Apr 2010 13:55:04 -0400 Subject: Re: [Cal_Boats] 4-107 It does sound pretty good. I calculated Celtic Naut's 4-107 at .8 gallons at 6 kts. I had no idea what RPM I was running at since there isn't a gauge yet and since the old prop was severely over pitched to thepoint I couldn't make 2000 (by ear) before it bogged the motor. (I set the throttle to "just before bogging and belching smoke" when I calculated my fuel). I have already replaced the old 16x16 with a 16x10 but haven't had the opportunity to check it out. So all my numbers are going to change when I install gauges etc. I should get similar performance even though we're a little bigger. What RPM are you running at? Mike On 4/3/2010 9:47 AM, r good wrote: so, since we have been in no rush, we've putted along at about 4.5-5 knots, getting fuel useage of 1/2 gal per hour. not too shabby! Reggie
