20 messages2010-04-01 16:12 UTCthrough 2010-04-05 23:12 UTC
priveleges
r good2010-04-01 16:12 UTC
I've learned a new rule about the ICW.
when 2 boats meet, the more expensive or faster boat can do anything it wishes.
people do not realize how fragile their priveleges are. In the current political climate, someone could submit a bill to place a speed limit on the ICW, citing fund raising for local law inforcement, conservation of fuel, reduced damage from no wake, etc.
To prevent this, a little courtesy in reducing the wakes created for others would work.
in the intercoastal waterway in Cape Coral, FL
Re: [Cal_Boats] privileges (Reggie)
Michael D2010-04-01 21:06 UTC
In Southeast Florida, Privileges is defined as "the rule of gross tonnage". I wholeheartedly agree with you regarding courtesy.
--Michael--
To: ca… [at] yahoogroups.com
Sent: Thu, April 1, 2010 12:12:17 PM
Subject: [Cal_Boats] priveleges
Re: [Cal_Boats] priveleges
mike2010-04-01 22:08 UTC
What's the matter Reggie? Don't like being bounced by power boat wakes?
It is annoying. It always gets me to speaking with sign language.
Inconsiderate bastards.
Anyway, have you started cutting across Fl using the ditch? Let me know
how it goes. I'm especially interested if you have draft issues since I
only draw a little more than you and may be following the same path someday.
Sail safe and don't let the jerks get you down. Enjoy your voyage. My
best to Barb.
Mike
1965 Cal 40 #44 /Celtic Naut
> it wishes.
> others would work.
> Reggie
RE: [Cal_Boats] priveleges
r good2010-04-02 01:34 UTC
spending tonight at Franklin Lock, mile 122 out of 147. no problems with depth. corp of engineers is showing 8'minimum for the whole trip at present. whatis your bridge clearance?
reggie
Date: Thu, 1 Apr 2010 18:08:56 -0400
Subject: Re: [Cal_Boats] priveleges
What's the matter Reggie? Don't like being bounced by power boat wakes? It is annoying. It always gets me to speaking with sign language. Inconsiderate bastards.
Anyway, have you started cutting across Fl using the ditch? Let me know how it goes. I'm especially interested if you have draft issues since I only draw a little more than you and may be following the same path someday.
Sail safe and don't let the jerks get you down. Enjoy your voyage. My best to Barb.
Mike
1965 Cal 40 #44 Celtic Naut
Re: [Cal_Boats] ICW clearances Ft. Meyers to Atlantic (was privileges)
mike2010-04-02 04:22 UTC
I can squeak under a 55' bridge (46' mast to deck, about 5' deck to
waterline, and 3' whip antenna = 54'). That sounds great! I draft 6' so
it shouldn't be a problem unless there are some low bridges.
Mike
> reggie
Randy Alcorn2010-04-02 05:10 UTC
My mom lives in Naples.
Hope all is well
Sent: Thu, April 1, 2010 9:22:56 PM
Subject: Re: [Cal_Boats] ICW clearances Ft. Meyers to Atlantic (was privileges)
I can squeak under a 55' bridge (46' mast to deck, about 5' deck to waterline, and 3' whip antenna = 54'). That sounds great! I draft 6' so it shouldn't be a problem unless there are some low bridges.
Mike
>reggie
Re: [Cal_Boats] Dealing with PB AH's in the ICW
Tom Vandiver2010-04-02 11:52 UTC
Hi,
How well we remember our trip from Jacksonville, FL to Norfolk in 2001. The power boat alpha hotels either don't have a clue about their liability for any damage their wake causes are just alpha hotels. Even our 20,000 pound Cal Cruising 46 takes a big roll from wakes. I tried several approaches on the VHF, with the most effective being, "Northbound powerboat at mile marker ____, please reduce your speed so as to SAFELY pass me"
If this did not work, we would get the digital camera out and stand where we were visible,, then call again," Northbound power boat that is approaching the sailboat Satori at mile marker ______
at an UNSAFE speed, we are taking a photo of your unsafe action and will be forwarding it to ALL boat insurers."
This worked well for us.
Passing through Savanna one Saturday morning,, we had a go fast type power boat sneak up from behind at about 35 knots and pass us close enough to see the eye colors of it's crew. I immediately called a PAN PAN on the VHF announcing the boat's name, unsafe action and location.
Unless the Coast Guard or local water cops actually witness the unsafe action, they will do nothing, but pictures sent to insurance companies should work.
Anyway, it was such an unpleasant experience, when we returned south in October we went offshore, staying inshore close enough to avoid the Gulf Stream and catch the counter current.
I hate inconsiderate people!
Tom Vandiver, Cal Cruising 46 #3 who has owned us since 17 March 1982
Sent: Thu, April 1, 2010 11:12:17 AM
Husar, Charlie [USA]2010-04-02 15:55 UTC
Spelling lesson, Reggie. O-K-E-E-C-H-O-B-E-E. Just in case you get lost and need directions.
Sent: Thursday, April 01, 2010 9:34 PM
Subject: RE: [Cal_Boats] priveleges
reggie
Chris Campbell2010-04-02 16:46 UTC
That's also a name with meaning for cruisers in the North Channel of
Lake Huron, leading us to pause and sigh briefly while sitting in a
stuffy office. See here: http://www.ohwy.com/on/q/q0191916.htm
Channel Island YC Race Tomorrow
Kevin O2010-04-02 19:24 UTC
Hi All
Maybe, or specially Randy?
There is a womans regatta tomorrow put on by the CIYC
Is anyone racing?
I'm on a friend's C&C 36 and this will be our first race in the area and we don't know much about the marks used.
Since there are two women on board we can use another guy or woman on board
Anyone?
give me a call
Thanks
Kevin O
702-591-1986
"Kona"
Cal-31
Las Vegas
Re: [Cal_Boats] Channel Island YC Race Tomorrow
Randy Alcorn2010-04-02 23:29 UTC
Yes tomorrow is Lady at the Helm at Channel Islands Yacht club. The skippers meeting is 9 am, so you have to get there earlier to sign up. The start is 12 noon at the Mandaly Plant, it is half way between Ventura and Channel Islands harbors. Thier will be spinnaker and non spinnaker classes.
It is really a good race, the lady has to be at the helm at the start line, rounding the marks and finish, afterwards they have a really good party and since CIYC just started a womens sailing association up here, there will be a lot of give away prizes.
Their will also be a all womans crew and a double handed prize as well.
Randy
CAL 2-29
Out Patient
Sent: Fri, April 2, 2010 12:24:22 PM
Subject: [Cal_Boats] Channel Island YC Race Tomorrow
Hi All
Is anyone racing?
Anyone?
give me a call
Thanks
Kevin O
702-591-1986
"Kona"
Cal-31
Las Vegas
RE: [Cal_Boats] ICW clearances Ft. Meyers to Atlantic (was privileges)
r good2010-04-03 13:52 UTC
you'll have to tip her to go under one overhead, 49 ft. says up to 55' can get under if tipped. locals can help I'm told. of course 49' is @ avg high water, I believe 14.5'. right now it is 13.5'. as they say, YMMV. corps of engineers and lock people can help with info.
Date: Fri, 2 Apr 2010 00:22:56 -0400
Mike
reggie
mike2010-04-03 18:06 UTC
What if I just move all Beth's stuff to one side of the boat? Would that
tip it far enough? (Just kidding, Honey. I know my tools weigh more than
your stuff.)
Well, what more excuse do you need to sail the Keys? Thanks for the info.
Mike
> Reggie
> From: mi… [at] wahini.org
> privileges)
> Mike
> reggie
ICW clearances Ft. Meyers to Atlantic( MIke)
Gerald Sobel2010-04-03 19:14 UTC
Mike,
Wouldn't it be easier to leave the ICW, go off shore around the bridge, and then return at the next inlet? I recall in NJ we had numerous inlets, and it was great fun as a kid growing up, riding in and out of them on the ocean rollers, in a small rented skiff loaded with family, fishing gear, pic nick ice box, and pushed by a golden anniversary (1960) Evinrude 5.5 hp "fisherman" which is still in my garage and operational. Ha ha, back then, a seat cushion was sufficient as a PFD...we figured we could all swim if one of those %$#@ passing cabin cruisers swamped us, plus all the boats then were made of wood and would float.
Date: Saturday, April 3, 2010, 11:06 AM
that tip it far enough? (Just kidding, Honey. I know my tools weigh
more than your stuff.)
info.
Mike
privileges)
some low bridges.
Mike
reggie
Re: [Cal_Boats] ICW clearances Ft. Meyers to Atlantic( MIke)
mike2010-04-03 22:12 UTC
Jerry,
I wouldn't know since I haven't been far enough along in our boats rehab
to do any proper route planning. I was just curious as to what our
advance scout, Reggie and Barb, had to say about clearances and such.
Sounds like you had fun as a kid. Cool. Way to go on keeping the
evinrude running all these years. It was a simple engine that would keep
going an going as long as you maintained it.
Mike
P.S. Cursed cabin cruisers! They've spilt my beer in the past before I
had proper cup holders. The horror... :'(
On 4/3/2010 3:14 PM, Gerald Sobel wrote:
> Mike,
> Jerry
> --- On *Sat, 4/3/10, mike /<mi… [at] wahini.org>/* wrote:
> From: mike <mi… [at] wahini.org>
> (was privileges)
> Would that tip it far enough? (Just kidding, Honey. I know my
> tools weigh more than your stuff.)
> the info.
> Mike
>> can help with info.
>> Reggie
>> From: mike@wahini. org
>> (was privileges)
>> bridges.
>> Mike
>> reggie
RE: [Cal_Boats] ICW clearances Ft. Meyers to Atlantic( MIke)
r good2010-04-03 23:47 UTC
we did not disturb the rust on the underside of the aport Mayaka RR bridge. It is shown as 49' with an average high water level of 14.5 ft. the lockmaster said current water is 14.2.
Date: Sat, 3 Apr 2010 18:12:41 -0400
Subject: Re: [Cal_Boats] ICW clearances Ft. Meyers to Atlantic( MIke)
Jerry,
I wouldn't know since I haven't been far enough along in our boats rehab to do any proper route planning. I was just curious as to what our advance scout, Reggie and Barb, had to say about clearances and such. Sounds like you had fun as a kid. Cool. Way to go on keeping the evinrude running all these years. It was a simple engine that would keep going an going as long as you maintained it.
Mike
P.S. Cursed cabin cruisers! They've spilt my beer in the past before I had proper cup holders. The horror... :'(
Mike,
What if I just move all Beth's stuff to one side of the boat? Would that tip it far enough? (Just kidding, Honey. I know my tools weigh more than your stuff.)
Mike
Mike
reggie
Kevin O2010-04-05 17:09 UTC
Randy,
Thanks for all the info
I was a pleasure to meet you and ....
GREAT RACE!
congrats on the win!!
We are still not good at the down wind with swells and wind chop
just a bunch of flat water sailors LOL
Great bunch of people we met and hope to be back again soon.
Kevin O
"Kona"
Cal-31
Las Vegas
PS. heard someone ask us about almost rounding up in the harbor?!?!?!
We were under power circuling Mystic so Tom could talk to them
Don't know what they were looking at (or smoking)
--- On Fri, 4/2/10, Randy Alcorn <sa… [at] yahoo.com> wrote:
Subject: Re: [Cal_Boats] Channel Island YC Race Tomorrow
Date: Friday, April 2, 2010, 4:29 PM
Randy
CAL 2-29
Out Patient
Hi All
Is anyone racing?
Anyone?
give me a call
Thanks
Kevin O
702-591-1986
"Kona"
Cal-31
Las Vegas
Randall Alcorn2010-04-05 17:40 UTC
Glad you made it out, lots more wind than most races, but it made for a lot of miles in a short amount of time.
Join our Island Series.
5/15 PBYC has a Santa Barbra to Ventura Race
5/22 AYC has a around Anacapa Race.
Randy
C 2-29
Out Patient
-- Sent from my Palm Pixi
On Apr 5, 2010 10:11, Kevin O <fi… [at] yahoo.com> wrote:
Randy,
GREAT RACE!
Kevin O
"Kona"
Cal-31
Las Vegas
Randy
CAL 2-29
Out Patient
Hi All
Is anyone racing?
Anyone?
give me a call
Thanks
Kevin O
702-591-1986
"Kona"
Cal-31
Las Vegas
Kevin O2010-04-05 22:23 UTC
May have been a short (time) race for you but we did not take the direct route
I have seen blind snakes take a straighter course LOL!
I would love to do more but I am dependant on the Kiim, the owner, and when she will be there
Kevin O.
"Kona"
Cal-31
Las Vegas
To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com>
Date: Monday, April 5, 2010, 10:40 AM
Randy
C 2-29
Out Patient
On Apr 5, 2010 10:11, Kevin O <first4banger@ yahoo.com> wrote:
Randy,
GREAT RACE!
Kevin O
"Kona"
Cal-31
Las Vegas
Randy
CAL 2-29
Out Patient
Hi All
Is anyone racing?
Anyone?
give me a call
Thanks
Kevin O
702-591-1986
"Kona"
Cal-31
Las Vegas
john raxter2010-04-05 23:12 UTC
Our Easter trip was a 4 hour trip from Oriental to Beaufort NC, down the ICW
a section called Adams Creek. The trip was relatively uneventful since it
is still a little early for most of the Snow birds, migrating north. There
were a few power boaters, and they behaved themselves for the most part.
Still in a 100' wide channel, it seems the only place to safely pass a
sailboat is a boat width on their port side. If the sailboat is "in the
channel" the best depth is next to them, Right?
This is a good time to monitor the marine radio, lots of entertaining
conversation, as long as you are not one of the offended parties. We can
usually hear about a 50 nm range on the radio. It is a shame when you can
hear the warnings about some A-H power boat not showing the no wake
courteously for an entire segment of the trip.
Reggie, have a safe trip, keep the "no-hurry" attitude, this will ease the
stress of your journey.
When you are in the Oriental area, let us know so we can plan a trip down
to see your lovelies,
john
