Re: [Cal_Boats]Bow cleats_was: Re: Cal29 Bow Roller
Chris, my O'DAY Day Sailer (17') has 2 aluminum mooring cleats at the bow
like many of the CALs. placed well out on the bow. They are backed up by
totally inadequate "backing plates" made from 1/8" aluminum plates, maybe
3/4" x 5" the holes are oversized in my opinion, and the bolts are
stainless-steel with "aircraft" nuts. Someday I will get around to making
up a single backing plate that will back up the 2 cleats and the stemhead
fitting [like the CAL 20, (well many of them?) there is no outside strap
backing up the headstay/jib tack fitting on the DS II You would be
unnerved to say the least at how O'DAY installed that stem fitting!] but,
I have to admit that the present setup has lasted for 30 years...... not
even a sign of corrosion on those aluminum plates even with 30 years of
saltwater use!
So, your boat is not alone in having a "weird" setup of the bow cleats.
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II #10201
On Tue, 06 Apr 2010 10:08:19 -0400 Chris Campbell
<cl… [at] charterinternet.com> writes:
Alfred Poor wrote:
Chri
We were stunned by how little backing there was for the bow cleats on
Pentaquod, and there really is not much area to put in backing plates.
My Cal 20 came with two Herreshoff-pattern four-bolt cleats at the bow,
not well secured nor well-backed. She was going to lie on a mooring
under my ownership, so this looked a bit flimsy. I made mahogany pads to
raise the cleats a bit, and used aluminum bar stock from the hardware
store to make backing plates. I know, stainless and aluminum are not a
happy combination, but (a) I'm in fresh water, and (b) the bolts are well
sealed, so it's satisfactory. There is no sign of stress after a decade
on the mooring.
Penny Stock Jumping 2000%
Sign up to the #1 voted penny stock newsletter for free today!
http://thirdpartyoffers.juno.com/TGL3141/4bbbf652a0e4f1c19dm02duc
