Soldering Volvo Penta exhaust outlet
2 messages2010-04-07 11:00 UTCthrough 2010-04-07 20:34 UTC
John2010-04-07 11:00 UTC
Hello All, If any of you are familiar with soldering cooper and cast iron together and/or with the cooling arrangement on a Volvo Penta MD7A (1979 Cal 31); I could dearly use some advice. I have been trying for quite some time to get the copper cooling pipe installed without leaks. I even broke down and ordered a new one for $100 for a copper pipe about 15" long with 3 fittings on it; one from the raw water pump, a "T" fitting into the bottom of the exhaust manifold and then one into the bottom of the thermostat housing. I would like to redesign this rather lame arrangement by soldering copper fittings onto the exhaust manifold and thermostat housing and then use simple heat rated tubing on barbs w/ hose clamps; anything that would make a better, easier fit than the existing POS. In fact, I think this is how it was done on the MD6A and B engines. Any advice would be greatly appreciated, John Stacklyn Cal 31 #33 "Sol Survivor" Shell Point, FL
Re: [Cal_Boats] Soldering Volvo Penta exhaust outlet
Bob Connell2010-04-07 20:34 UTC
Yes you can solder cast iron. When you google it there are some YouTube videos that show how. When you do it please document it because I will follow your lead. Bob Connell "Jollygood!", Cal 31, #59 Olympia, WA From: John <st… [at] embarqmail.com> To: Ca… [at] yahoogroups.com Sent: Wed, April 7, 2010 4:00:12 AM Subject: [Cal_Boats] Soldering Volvo Penta exhaust outlet Hello All, If any of you are familiar with soldering cooper and cast iron together and/or with the cooling arrangement on a Volvo Penta MD7A (1979 Cal 31); I could dearly use some advice. I have been trying for quite some time to get the copper cooling pipe installed without leaks. I even broke down and ordered a new one for $100 for a copper pipe about 15" long with 3 fittings on it; one from the raw water pump, a "T" fitting into the bottom of the exhaust manifold and then one into the bottom of the thermostat housing. I would like to redesign this rather lame arrangement by soldering copper fittings onto the exhaust manifold and thermostat housing and then use simple heat rated tubing on barbs w/ hose clamps; anything that would make a better, easier fit than the existing POS. In fact, I think this is how it was done on the MD6A and B engines. Any advice would be greatly appreciated, John Stacklyn Cal 31 #33 "Sol Survivor" Shell Point, FL
