4 messages2010-04-24 12:22 UTCthrough 2010-04-27 12:37 UTC
Departing Chesapeake
chris1232010-04-24 12:22 UTC
Greets all, especially those of you in the Bay.
Please accept my apologies for not being in touch nor finding the time
to tell lies of adventures past and present. However since we got down
here, (Chris & Chris) its been a steady push to get the boat ready,
thanks to Chris B. Due to the weather over the weekend we are leaving
port for Chesapeake City to sit out the thundershowers and then make
our way down to Cape May most likely in two hops. from there its up
the Jersey Coast to Atlantic City, Brielle, Sandy Hook and then NYC
where we will reprovision and set the boat up for the next leg up the
Hudson.
The good news (all in one week)
- engine serviced and all fuel components replaced and cleaned
- water intake system cleaned and hoses replaced as needed
-new plugs installed, engine runs like a top now.
- AC system is now fully operational with an addition house battery,
so one cranking, two house, with all DC loads on the house bank and
new battery charger installed and tested.
- all deck fittings checked and refastened, every single accessible
bolt/screw, cotter pin or O ring (1550 miles to go)
- dink repaired and tested, she's a little wet but should get us out
of trouble if needed.
- com check completed and radio's functional
- gps systems checked and functional
- two sets of electronic charts and paper charts thanks to Chris B,
and two computers.
- radar reflector installed.
- rope from shaft drive removed (thanks chris) ....its one of those
dont ask me why issues, but it was rather funny.
- all lights checked and functional
- all standing rigging checked and cleared
- all running rigging checked and all, pullies, whinched etc, lubed
- sail slide lubed and new "preventer" put in place (a simple piece of
rope) as that darn clip always wants to come undone when you bring
down the main.
- new used 35lbs CQR storm anchor (100 bucks off craigslist) arrived,
tested and installed on foredeck
- tanks filled and flushed and refilled.
- fuel guage remains off line, but not an issue. 11 gallon tank, hr
meter works and we run 1gal/hr so we are good and we are carrying
2x5gal spare tanks so lots of fuel.
-sail check complete and main pre-set to first reef point, all lines
marked and preset so its a simple pull, pull, pull and your off the
deck in less then 2-3 minutes.
-anchor sail checked and functional.
- new mountain climbing loop purchased from REI to make preset bridle
for anchor rode, slip it on, wrap twice through itself, then push down
with boat pole, and tie off with standard 3 strand braid on opposite
cleat to bring rode to center line of boat. The entire system can be
preset. (got this trick off cruisersforum)
- cabin denuded, truck loaded and put into storage so I can come back
to pick it up in five weeks.
- little chance for "strewnage' on the boat while underway.
The best news:
HS/Customs is Baltimore, Ms Betty is simply amazing. Provided me with
an export permit for 19US, meaning that I am cleared all the way to
Kingston ON Canada, with no check in required with HS. Supper nice
woman and knows her stuff, and will assist to make life simple and
easy. My hat is off to this woman.
The not so good news:
OWL anchor light from Fiji did not make it in time.
No time to "yarn" with all of you in the Bay, so pls accept my
apologies as this is something I was really looking forward too.
We are actually leaving Rock Hall......that sucks. Nice place, good
people, uncomplicated, leaving behind lots of friends and characters.
Hope to be back in the summer of 2011 as the boat is going home to
Picton ON (google that one as its a pretty harbour) where she will be
rebuild and outfitted for proper voyageing. Things that need to be
addressed include:
- haul out and bottom redone
- ports replaced with lexan
- electrical reone and relocated
- bow rollers installed
- propane locker build and propane dickerson heater installed
- 80 watt solar panel and rig installed
- all deck fitting removed and rebedded with all existing holes
redrilled, expoxied and redrilled
- chainplates refasted
- interior cabinetry mods to accommodate dry storage
Most of the work will be done in the winter in Port Credit Marina
where folks on Lake ON winter over. Nice setting as its a burb of
Toronto so you have access to everything by bicycle, sub-way or car.
Cost is 1700 for the season inclusive of 30AMP power. Here the boat
will be shrink wrapped over a jig (mast up boom down) at 8 ft on deck,
to 1 foot above the water line, the trick being its clear, so the boat
basically becomes a green house. This will also be the time to figure
out and test a proper insulation system.
Thats about it from the Bay and Rock Hall. Will update the list on
progress north, if desired, as internet access becomes available. We
will try to do this trip on the hook as much as possible to test out
systems and practise and improve skills. In other words, trial and
error with marina's as backup and warmup as needed. Only planned
marina access is for fuel and water.
All for now, and thanks for understanding. Keep well all. this is one
jewel of an area and one where folks treat you real well.
My best
RE: [Cal_Boats] Departing Chesapeake
Husar, Charlie [USA]2010-04-24 12:37 UTC
Chris, impressive list. Sorry we missed you. Bon voyage (or is that Quebec talk?).
We'll catch up with you next time. From my end, off to the boat yard again. Hope to have my rehab CAL 25 ready to race the NOODs next week. Also a long list.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of chris123
Sent: Saturday, April 24, 2010 8:22 AM
Subject: [Cal_Boats] Departing Chesapeake
Please accept my apologies for not being in touch nor finding the time to tell lies of adventures past and present. However since we got down here, (Chris & Chris) its been a steady push to get the boat ready, thanks to Chris B. Due to the weather over the weekend we are leaving port for Chesapeake City to sit out the thundershowers and then make our way down to Cape May most likely in two hops. from there its up the Jersey Coast to Atlantic City, Brielle, Sandy Hook and then NYC where we will reprovision and set the boat up for the next leg up the Hudson.
- water intake system cleaned and hoses replaced as needed -new plugs installed, engine runs like a top now.
- AC system is now fully operational with an addition house battery, so one cranking, two house, with all DC loads on the house bank and new battery charger installed and tested.
- all deck fittings checked and refastened, every single accessible bolt/screw, cotter pin or O ring (1550 miles to go)
- dink repaired and tested, she's a little wet but should get us out of trouble if needed.
- two sets of electronic charts and paper charts thanks to Chris B, and two computers.
- rope from shaft drive removed (thanks chris) ....its one of those dont ask me why issues, but it was rather funny.
rope) as that darn clip always wants to come undone when you bring down the main.
- new used 35lbs CQR storm anchor (100 bucks off craigslist) arrived, tested and installed on foredeck
- fuel guage remains off line, but not an issue. 11 gallon tank, hr meter works and we run 1gal/hr so we are good and we are carrying 2x5gal spare tanks so lots of fuel.
-sail check complete and main pre-set to first reef point, all lines marked and preset so its a simple pull, pull, pull and your off the deck in less then 2-3 minutes.
- new mountain climbing loop purchased from REI to make preset bridle for anchor rode, slip it on, wrap twice through itself, then push down with boat pole, and tie off with standard 3 strand braid on opposite cleat to bring rode to center line of boat. The entire system can be preset. (got this trick off cruisersforum)
- cabin denuded, truck loaded and put into storage so I can come back to pick it up in five weeks.
The best news:
HS/Customs is Baltimore, Ms Betty is simply amazing. Provided me with an export permit for 19US, meaning that I am cleared all the way to Kingston ON Canada, with no check in required with HS. Supper nice woman and knows her stuff, and will assist to make life simple and easy. My hat is off to this woman.
No time to "yarn" with all of you in the Bay, so pls accept my apologies as this is something I was really looking forward too.
We are actually leaving Rock Hall......that sucks. Nice place, good people, uncomplicated, leaving behind lots of friends and characters.
Hope to be back in the summer of 2011 as the boat is going home to Picton ON (google that one as its a pretty harbour) where she will be rebuild and outfitted for proper voyageing. Things that need to be addressed include:
- all deck fitting removed and rebedded with all existing holes redrilled, expoxied and redrilled
Most of the work will be done in the winter in Port Credit Marina where folks on Lake ON winter over. Nice setting as its a burb of Toronto so you have access to everything by bicycle, sub-way or car.
Cost is 1700 for the season inclusive of 30AMP power. Here the boat will be shrink wrapped over a jig (mast up boom down) at 8 ft on deck, to 1 foot above the water line, the trick being its clear, so the boat basically becomes a green house. This will also be the time to figure out and test a proper insulation system.
Thats about it from the Bay and Rock Hall. Will update the list on progress north, if desired, as internet access becomes available. We will try to do this trip on the hook as much as possible to test out systems and practise and improve skills. In other words, trial and error with marina's as backup and warmup as needed. Only planned marina access is for fuel and water.
All for now, and thanks for understanding. Keep well all. this is one jewel of an area and one where folks treat you real well.
My best
Yahoo! Groups Links
Re: [Cal_Boats] Departing Chesapeake
Donald Dutton2010-04-26 22:08 UTC
There is a great anchorage just past the 231 bridge on the C & D canal just across from Shaeffer's Canal House Restaurant on the south side of the canal. Stay to the left on the way in, but inside water is deep all around.
chris1232010-04-27 12:37 UTC
TKS. much appreciated. Trip reports are all sanitized to keep friends and
family unconcerned. Accurate details will follow as time and internet
connections allow.
Lets just say blasting down Delaware Bay at 9 knots on the engine alone
(wind less then 5 knots) outrunning thunder and lightening was a blast. Got
in to Hudson Marina just in time to spend a safe night at dockside. River
was over 40 feet deep in some places as everything is flooded in Lower
Delaware and the river current alone was over 4 knots. At the entrance and
heading south you have to be aware and keep a sharp lookout for crab pots
that are every where if you stay to the east of the shipping lanes. Water is
thin but with the current flood stage, plenty of depth all the way to Cape
May.
Cape May is interesting, the only really dicey part was the railway bridge
as all the water is pinched and there is a wicked current in there. Had to
push the engine to the max to get through and then the trani started
slipping. Chris and I has to do some trick manouvering to make it through
and keep her pointed into the headwaters, slip sliding all the way. Took
about 5 to 10 minutes to get through but seemed like an hour.
Laid up in Cape May to wait out the weather and see what I can do with the
trani. Moyer's A-4 Manual is good. There is an adjusting nut that needs to
be tensioned but getting at is the challenge for the day.
More later.
