10 messages2010-04-26 13:08 UTCthrough 2010-04-28 22:18 UTC
lube for turnbuckles
Chris Campbell2010-04-26 13:08 UTC
Listmates,
The lovely Cal 20, /Martha C/, will probably be launched this week.
This must be a record for me but our early spring and some other later
obligations got me working early.
Last week I went out and cleaned the old Johnson closed-body stainless
steel turnbuckles, and the only lube I had was some anhydrous lanolin.
What's a better choice for turnbuckle lube?
RE: [Cal_Boats] lube for turnbuckles
Husar, Charlie [USA]2010-04-26 14:00 UTC
Chris, how about a WD 40 treatment to loosen the crud, followed by an acetone cleaning to get the WD 40, followed by dry lube (aerosol spray can). Just make sure you have a good locking mechanism for the buckles. I would normally do the first two, but I do not typically lube the buckles. I use the dry lube in many other places though, e.g., track, blocks, ...)
Sent: Monday, April 26, 2010 9:09 AM
Subject: [Cal_Boats] lube for turnbuckles
Listmates,
The lovely Cal 20, Martha C, will probably be launched this week. This must be a record for me but our early spring and some other later obligations got me working early.
Last week I went out and cleaned the old Johnson closed-body stainless steel turnbuckles, and the only lube I had was some anhydrous lanolin.
john raxter2010-04-26 22:08 UTC
Chris,
I am not sure what is "better". I chose Lanacote (marine brand of the
Anhydrous Lanolin) for several reasons. Briefly:
- the moisture protection of surface materials
-non-staining
- it is better than no lube or Teflon spray that dissipates quickly
Even thought the lanacote is 'sticky' it seems to be a bit of a lubricant on
the threaded fittings, more so than dry or corroded stainless.
I use it on all my stainless connections, turnbuckles, lifeline adjustments,
etc.
YMMV
JOhn
Of Chris Campbell
Listmates,
me working early.
Re: [Cal_Boats] lube for turnbuckles
Chris Campbell2010-04-27 15:42 UTC
john raxter wrote:
> Chris,
I like having some lube on the stainless, too, after reading about the
tendency of stainless-on-stainless surfaces to gall. My other boat had
open-body bronze turnbuckles and they do fine with no lube at all. But
these Johnson stainless ones seem to get stubborn. I'll leave the
lanolin on mine this summer and see what the reults are.
And I'll know soon: /Martha C/, the pretty Cal 20, launches tomorrow!
This is early. I got the mooring ball out on Friday and got the winter
cover off the boat yesterday.
Gerald Sobel2010-04-27 20:29 UTC
Mates,
I vote for pure silicon grease. It's is used for lubricating seals in three way valves that are exposed to chlorinated, salty, high velocity, heated pool water. My experiance is that it completely protected my aluminum mast from galling by galvanic reaction from stainless steel sheet metal screws after several years exposure. You can get it at a pool supply store. Lately I have been using it to protect any steel screw insertion into aluminum, which is common in solar hot water panels, and replacing lag screws driven into redwood. Cadmimum plated lags are rusted to dust by tanic acid in moist redwood. I'm using only zinc dipped now, and dabbing the holes and screw ends with silicon grease. It comes in a large squeeze tube, like toothpaste, so it's very handy to work with.
--- On Tue, 4/27/10, Chris Campbell <cl… [at] charterinternet.com> wrote:
Subject: Re: [Cal_Boats] lube for turnbuckles
Date: Tuesday, April 27, 2010, 8:42 AM
john raxter wrote:
Chris,
I
am not sure what is “better”. I chose
Lanacote (marine brand of the Anhydrous Lanolin) for several reasons.
Briefly:
tendency of stainless-on- stainless surfaces to gall. My other boat had
And I'll know soon: Martha C, the pretty Cal 20, launches
tomorrow! This is early. I got the mooring ball out on Friday and
got the winter cover off the boat yesterday.
Chris Campbell2010-04-27 21:05 UTC
Gerald Sobel wrote:
> Mates,
You use sand for a lubricant? Or did you just forget the "e" on "silicone?"
> --- On *Tue, 4/27/10, Chris Campbell
Gerald Sobel2010-04-27 22:07 UTC
'You use sand as a lubricant?'
Nope, not Silicon dioxide, actually, this:
Silicone grease is a waterproof grease made by combining a silicone
oil with a thickener. Most commonly, the silicone oil is polydimethylsiloxane and the thickener
is amorphous fumed silica. Using this formulation, silicone
grease is a translucent white viscous paste, with exact properties
dependent on the type and proportion of the components.
Silicon is an essential element in this grease, but I stand corrected.
PS:
(I got out of the bed on the right side, but unfortunately I put my head on backwards because I took some muscle relaxants before hitting the rack, for me bad back, I'm still sleepy and my back still aches. I think I must have cross threaded my head too, cause me neck hurts as well..nothing like drilling your body head first into the side of a mountain with a hang glider in '81, looking for a short cut to China, that's before global something or other melted the arctic ice and opened the Northwest Passage to us sailors. But, maybe I'll have better luck with me turnbuckles)
Husar, Charlie [USA]2010-04-28 02:16 UTC
I knew what you meant, Jerry. Just one question. On a hot day does the stuff start to drip down your mast like a dude with Brylcream in his hair. I have been using Lanocote.
I just read on a web site that 8-18 stainless (the screws I use) does not react with aluminum. Any truth?
http://www.finishing.com/156/25.shtml
Sent: Tuesday, April 27, 2010 6:08 PM
Silicone grease is a waterproof grease<http://en.wikipedia.org/wiki/Grease_%28lubricant%29> made by combining a silicone oil<http://en.wikipedia.org/wiki/Silicone_oil> with a thickener. Most commonly, the silicone oil is polydimethylsiloxane<http://en.wikipedia.org/wiki/Polydimethylsiloxane> and the thickener is amorphous fumed silica<http://en.wikipedia.org/wiki/Fumed_silica>. Using this formulation, silicone grease is a translucent white viscous paste, with exact properties dependent on the type and proportion of the components.
PS:
RE: [Cal_Boats] lube for turnbuckles(Charlie)
Gerald Sobel2010-04-28 04:14 UTC
Charlie, the part I removed from my mast that had silicon..woops! silicone grease on it was a carbon reinforced whiskerpole ring, mounted on the leading edge of the mast. There was no corrosion on the holes in the mast. I use it on screws going into hot water solar panels, lots of moisture and heat developing daily, and 300 degree temps inside them...they will melt the polyethelene pipe insulation off the pipes for 100' if the system stagnates (pump or control failure).
So normal weather would have no effect.
What's nice is that it prevents the steel from rusting, and the parts, like glass frames, motor valve coupling screws (carbon steel into brass, dripped on by swim pool water and evaporated to concentrate the salts) come apart easily years later for servicing.
Another trick I've learned is using teflon tape pipe dope on metal threads of bolts, for example, the linkage bolts on outboard motor mounts, to prevent the nuts from backing away from vibration and falling into the drink while motoring. Haven't had one nut come lose since I've started doing this. The teflon tape is probably ok for steel bolts tapped into aluminum, or, you could combine the two. I guess any type of pipe thread dope paste might work well, too.
--- On Tue, 4/27/10, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
Subject: RE: [Cal_Boats] lube for turnbuckles
Date: Tuesday, April 27, 2010, 7:16 PM
I
I
http://www.finishin g.com/156/ 25.shtml
[mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Gerald
Sobel
To:
Cal_Boats@yahoogrou ps.com
turnbuckles
<clcampbell@charteri nternet.com> wrote:
'You
this:
made by combining a silicone oil with a
thickener. Most commonly, the silicone oil is polydimethylsiloxan e
and the thickener is amorphous fumed silica. Using
components.
PS:
turnbuckles)
Allen Edwards2010-04-28 22:18 UTC
http://l-36.com/superlube.php
This stuff is great.
On Tue, Apr 27, 2010 at 7:16 PM, Husar, Charlie [USA] <hu… [at] bah.com
> Cheers
> Charlie
> Behalf Of *Gerald Sobel
> *Sent:* Tuesday, April 27, 2010 6:08 PM
> *Subject:* Re: [Cal_Boats] lube for turnbuckles
> *Silicone grease* is a waterproof grease<http://en.wikipedia.org/wiki/Grease_%28lubricant%29>made by combining a silicone
> oil <http://en.wikipedia.org/wiki/Silicone_oil> with a thickener. Most
> commonly, the silicone oil is polydimethylsiloxane<http://en.wikipedia.org/wiki/Polydimethylsiloxane>and the thickener is amorphous fumed
> silica <http://en.wikipedia.org/wiki/Fumed_silica>. Using this
> Jerry
> PS:
