4 messages2010-04-26 13:35 UTCthrough 2010-04-28 22:28 UTC
bending a traveler extrusion
Chris Campbell2010-04-26 13:35 UTC
Listmates:
While I was working on my other boat I struck up a conversation with a
Hunter owner who had just replaced his traveler. I was laughing about
the one on my 1961 vessel--a piece of stiff sail track with a C-shaped
sliding car (no bearings). He gave me his old traveler, which at least
has some rollers to reduce friction and allow moving it under load..
But my traveler's location is on a cockpit coaming that's curved or
crowned. The extrusion is roughly X-shaped. The rollers ride under the
upper limbs of the X. Does anybody have a suggestion for putting a
slight bend into the extrusion? I need less than 2" in four feet,
roughly. The X-shaped extrusion seems pretty rigid.
RE: [Cal_Boats] bending a traveler extrusion
Husar, Charlie [USA]2010-04-26 14:14 UTC
I use hardwood wedges on the sides in the cockpit on a CAL 25. Similar curvature. Dark rosewood stain. Good appearance.
Sent: Monday, April 26, 2010 9:36 AM
Subject: [Cal_Boats] bending a traveler extrusion
Listmates:
While I was working on my other boat I struck up a conversation with a Hunter owner who had just replaced his traveler. I was laughing about the one on my 1961 vessel--a piece of stiff sail track with a C-shaped sliding car (no bearings). He gave me his old traveler, which at least has some rollers to reduce friction and allow moving it under load..
But my traveler's location is on a cockpit coaming that's curved or crowned. The extrusion is roughly X-shaped. The rollers ride under the upper limbs of the X. Does anybody have a suggestion for putting a slight bend into the extrusion? I need less than 2" in four feet, roughly. The X-shaped extrusion seems pretty rigid.
Yahoo! Groups Links
Re: [Cal_Boats] bending a traveler extrusion
Wayne Gillikin2010-04-26 14:54 UTC
I agree with Charlie's solution. I replaced the ancient Nicro X-track on my 39 with Harkin about 3 years back. The old track had a slight radius which conformed to the deck. I probably would have bent the new track but couldn't think how to measure the radius, how to put the bend into the new track, or who I could do it for me. So, rather than make the track fit the deck I made the deck fit the track. I used teak wedges to fill the voids at the ends of the new track. It seems to have worked out fine and doesn't look half bad.
Wayne
s/v Elusive
Sent: Mon, April 26, 2010 10:14:05 AM
Subject: RE: [Cal_Boats] bending a traveler extrusion
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com] On Behalf Of Chris Campbell
Listmates:
Yahoo! Groups Links
Allen Edwards2010-04-28 22:28 UTC
Garhauer will build a track with the same holes as your existing traveler
and curve it to match your deck. I don't even think they charge extra for
that. I got the MT-2 which I see is $250, for my L-36 and it works just
fine.
> look half bad.
> Wayne
> s/v Elusive
> *From:* "Husar, Charlie [USA]" <hu… [at] bah.com>
> *Sent:* Mon, April 26, 2010 10:14:05 AM
> *Subject:* RE: [Cal_Boats] bending a traveler extrusion
> Cheers
> Charlie
> -----Original Message-----
> From: Cal_Boats@yahoogrou ps.com <Cal_Boats%40yahoogroups.com> [mailto:Cal_Boats@yahoogrou
> ps.com <Cal_Boats%40yahoogroups.com>] On Behalf Of Chris Campbell
> To: Cal_Boats@yahoogrou ps.com <Cal_Boats%40yahoogroups.com>
> Listmates:
> Chris Campbell
> Yahoo! Groups Links
