5 messages2010-04-28 15:58 UTCthrough 2010-04-29 17:47 UTC
Evinrude shift lever
Chris Campbell2010-04-28 15:58 UTC
Cal friends,
Whee, Cal 20 #1220, the lovely /Martha C/, is floating happily on her
mooring--the first boat in the mooring field this year. We splashed
this morning in sunshine, with a light north wind and temps at about 50º
F. It's a good start for the summer.
The glitch was in the mechanical systems. The old 6 hp Evinrude
started, bless her old soul, and when all was ready I shifted into
reverse to back out of the launching slip. After a graceful arc, I
flipped the level into forward and it kind of flopped around and the
boat continued backing. Oops. Turn engine off, fiddle with shift
lever, try again, and on the second try I found forward.
I can't remember how the lever and shift rod mechanism are hooked up
inside the outboard's leg. Can anybody give me a quick tutorial so when
I go out tonight to take it apart, there won't be any big surprises?
The OB is from the late '60s, that same little 6 that OMC made forever.
This one has a long shaft (added later by a previous owner).
Re: Evinrude shift lever
Nick2010-04-28 18:36
You cd try looking at the drawings here to get an idea:
http://epc.brp.com/Index.aspx?lang=E&s1=bec94f48-4e68-4924-9452-705191371348
Select make, year, motor, then assembly, then blow up the drawings. (There's a zoom button top left).
Nick
--- In Ca… [at] yahoogroups.com, Chris Campbell <clcampbell@...> wrote:
> Cal friends,
> Thanks,
> Chris Campbell
Re: [Cal_Boats] Re: Evinrude shift lever
Chris Campbell2010-04-28 19:27 UTC
Thanks for the link. There's nothing more helpless than a sailboat
without a mast up and with no power. I could always row the dinghy and
tow the Cal 20 behind but it would be a slow passage. Once the mast is
stepped I can sail on & off the mooring and worry about the outboard at
leisure, but to get the mast stepped I need to be able to power into a
narrow channel. I will study the situation tonight after work, hoping
that it's just the setscrew securing the shift handle to the lever that
moves the shift rod.
Joseph McCloskey2010-04-29 17:13 UTC
Chris
I had a Johnson 5.5hp from the 60's. and if this is the same engine, and i think it probably is, you have to remove the powerhead to get to the shift lever parts. It was a long time ago so I could be mistaken.
Joe
--- On Wed, 4/28/10, Nick <Ni… [at] shaw.ca> wrote:
Subject: [Cal_Boats] Re: Evinrude shift lever
Date: Wednesday, April 28, 2010, 2:36 PM
http://epc.brp. com/Index. aspx?lang= E&s1=bec94f48- 4e68-4924- 9452-70519137134 8
Nick
--- In Cal_Boats@yahoogrou ps.com, Chris Campbell <clcampbell@ ...> wrote:
> Cal friends,
> Thanks,
> Chris Campbell
Chris Campbell2010-04-29 17:47 UTC
Joseph McCloskey wrote:
> Chris
I'm hoping there's some sort of joint at the bottom, because you have to
be able to disconnect the lower unit to service the water pump
impeller. And that seems to be where mine is making a rattling noise.
I did not try disassembly aboard last night, because if the drive shaft
comes out of the seal, the lube will leak all over. For now, mine seems
to be lodged in "Forward" so I can at least power in the right direction.
