7 messages2010-05-05 20:24 UTCthrough 2010-05-06 21:18 UTC
Re: [Cal_Boats] Vinyl & Glue Removed . . . more fun begins
pw… [at] aol.com2010-05-05 20:24 UTC
Well done, Paul! Damned impressive job.
Thanks but I think the the demo is going to be the easy part. Making it
look good is going to be the hard part . . . I see lots of sanding in my
future.
Question, was all the glue you removed with the brush dry? Did you have
any glue that was gummy? If so how did you remove the gummy glue?
Thankfully it was all dry and crusty. Probably when I wipe it all down
with acetone I'll make it gummy again with my luck.
Hey, did you ever get your website up and running?
Paul
Cc: mr… [at] efni.com
Sent: Wed, May 5, 2010 3:59:29 PM
Subject: [Cal_Boats] Vinyl & Glue Removed . . . more fun begins
Well, all the vinyl is gone and most of the glue taken off with an angle
grinder with one bad ass wire brush attached. I was smart enough to mask
off the areas where I didn't want residue with masking tape and cheap drop
cloths which saved me a lot of cleanup.
I also wore appropriate safety gear . . .LUKE . . . I AM YOUR FATHER . . .
at least that's what I felt like ;-)
The clean spot in the middle is after one pass of the grinder
My next step is to wash down the walls with acetone and get as much
remaining residue off as I can. Then I hope to fair it with West Systems 410,
the light micro-ballons.
Here is the question of the day . . . am I now going to be getting
condensation on these "walls" and the underside of the decks? If so, was the foam
backed vinyl that was there preventing it before or just absorbing it?
Donald if you're reading this, did your wife ever have the chance to look
into insulation values of paints or fillers with the microballoons?
The one thing that has really struck me about this job so far is how
inaccessible the genny track bolts, the stanchion base bolts and basically
anything bolted to the side decks are. Without basically destroying the
interior of the boat they are basically not accessible which explains why I have 2
stanchion bases that are cracked and probably 3 others that wobble!
Paul West
Adventure Kwest
'80 Cal 39
Wayne Gillikin2010-05-05 20:30 UTC
If the glue on your boat is the same as the glue on my boat it will completely ignore the acetone. I removed all the crusty glue on my boat with a stiff wire brush on a hang drill. However, when the brush got into the gooey stuff it got gummed up and nothing except paint remover will get it off. Could be the glue that is holding the boat together.
Which web site?
Regards,
Wayne
Sent: Wed, May 5, 2010 4:24:11 PM
Subject: Re: [Cal_Boats] Vinyl & Glue Removed . . . more fun begins
Well
part. Making it look good is going to be the hard part . . . I see lots of
sanding in my future.
>Question,
> was all the glue you removed with the brush dry? Did you have any glue
all down with acetone I'll make it gummy again with my luck.
Paul
> <pw… [at] aol.com>
>To: > Ca… [at] yahoogroups.com
>Cc: > mr… [at] efni.com
>Sent: Wed, May
> 5, 2010 3:59:29 PM
>Subject: > [Cal_Boats] Vinyl & Glue Removed . . . more fun begins
> mask off the areas where I didn't want residue with masking tape and cheap
> drop cloths which saved me a lot of cleanup.
> . at least that's what I felt like ;-)
> Systems 410, the light micro-ballons.
> the foam backed vinyl that was there preventing it before or just
> absorbing it?
> have 2 stanchion bases that are cracked and probably 3 others that
> wobble!
>Paul West
>Adventure Kwest
>'80 Cal 39
pw… [at] aol.com2010-05-05 20:40 UTC
I'm on the Chesapeake where the air and water temps stay pretty close to
each other if 20-30 degrees is considered close. On the West Systems site
they have an article about it, oddly enough, and they say that good
ventilation will prevent condensation. So maybe I'll put my dorade vents back on
and make their removal just one more thing to do before racing.
Paul
In a message dated 5/5/2010 4:36:34 P.M. Eastern Daylight Time,
cl… [at] charterinternet.com writes:
If it's any help, I get condensation below the waterline on the bare,
painted fiberglass interior of my Cal 20. It happens when the weather is warm
& humid. You can see where the waterline is by viewing the condensation
line down below. We're in a place where the water tends to stay cold all
summer, especially when the wind is offshore, driving off the warm surface
water and causing the upwelling along shore of cold deep water.
RE: [Cal_Boats] Vinyl & Glue Removed . . . more fun begins
Wyatt Hendricks2010-05-06 15:46 UTC
Paul we went through this nightmare on our 2-46.
My experience was that after trying every brain toxin known to man the
glue won and we got a nice chemical buzz.
Here's what we ended up doing:
1. Thoroughly clean the glue with the stuff you thought would
remove it.
2. paint 2- 3 coats of 2 part epoxy.
3. wipe down with acetone.
4. 2 coats of 1part topside primer
5. 2 coats of topside finish
4 years and it still looks great.
Good luck
Wyatt
s/v Blythe Spirit
St. Pete
Behalf Of pw… [at] aol.com
Sent: Wednesday, May 05, 2010 4:24 PM
future.
you have any glue that was gummy? If so how did you remove the gummy
glue?
Paul
an angle grinder with one bad ass wire brush attached. I was smart
enough to mask off the areas where I didn't want residue with masking
tape and cheap drop cloths which saved me a lot of cleanup.
FATHER . . . at least that's what I felt like ;-)
much remaining residue off as I can. Then I hope to fair it with West
getting condensation on these "walls" and the underside of the decks?
If so, was the foam backed vinyl that was there preventing it before or
just absorbing it?
chance to look into insulation values of paints or fillers with the
microballoons?
how inaccessible the genny track bolts, the stanchion base bolts and
basically anything bolted to the side decks are. Without basically
destroying the interior of the boat they are basically not accessible
which explains why I have 2 stanchion bases that are cracked and
Paul West
Adventure Kwest
'80 Cal 39
Chris Campbell2010-05-06 15:54 UTC
> to each other if 20-30 degrees is considered close. On the West
> Systems site they have an article about it, oddly enough, and they say
> that good ventilation will prevent condensation.
It may reduce condensation, but you're not going to prevent it when you
have warm, moist air and a cooler surface. Tent campers know about the
use of a waterproof fly over a tent. It has two effects. First, it's a
barrier between the tent and the cold, dark night sky, preventing
radiation heat losses from the tent surface to the black sky. Second,
it allows the permeable tent surface to breathe moisture that would
accumulate if the surface were impermeable (waterproof). My other boat
has an uncored cabin trunk top. It tends to be affected by radiant heat
losses at night, even when unoccupied. The surface loses heat to the
dark night sky and to the cool ambient air. The relatively warmer air
inside condenses its moisture, the overhead gets damp, and then I have
to scrub the mildew off. The Cal 20's cored deck insulates it some,
diminishing that effect, but the hull is not cored. When we get really
warm, moist days, the warm air condenses out moisture onto the cool hull
below waterline. You can actually see where the waterline is, because
there's condensation below it but not above it. Ventilation actually
makes it worse, since it introduces more warm, moist air to the cold
surfaces. Ventilation works under more normal conditions.
pw… [at] aol.com2010-05-06 16:42 UTC
I think I got the majority of it off . .. hopefully. I am wiping down
with acetone to prep the fiberglass for the West Systems mainly but to
hopefully remove any remaining residue. We'll see what happens I guess.
Here’s what we ended up doing:
Thoroughly clean the glue with the stuff you thought would remove it.
So no fairing of the rough glass and uneven surfaces?
No sanding between coats was necessary?
4years and it still looks great.
That's encouraging. No stress cracks or anything?
Good luck
Thanks!
Paul
Wyatt
s/v Blythe Spirit
St. Pete
From: Cal_Boats@yahoogrou Cal_Boats@yaho Cal_Boats@y Cal_BoOn Behalf Of
pw… [at] aol.pwe
To: Cal_Boats@yahoogrou C
future.
Paul
Paul West
Adventure Kwest
'80 '80 39
Husar, Charlie [USA]2010-05-06 21:18 UTC
I painted thickly over the remnants of the crap. Adequate result, I guess.
However, if using epoxy, I would assume that a sanding is needed before painting. I have been using Mas epoxy in recent times because of the "non blushing" characteristic that theoretically reduces sanding between coats of epoxy.
Sent: Thursday, May 06, 2010 12:43 PM
My experience was that after trying every brain toxin known to man the glue won and we got a nice chemical buzz.
I think I got the majority of it off . .. hopefully. I am wiping down with acetone to prep the fiberglass for the West Systems mainly but to hopefully remove any remaining residue. We'll see what happens I guess.
Good luck
Thanks!
Paul
Wyatt
s/v Blythe Spirit
St. Pete
Thanks but I think the the demo is going to be the easy part. Making it look good is going to be the hard part . . . I see lots of sanding in my future.
Question, was all the glue you removed with the brush dry? Did you have any glue that was gummy? If so how did you remove the gummy glue?
Thankfully it was all dry and crusty. Probably when I wipe it all down with acetone I'll make it gummy again with my luck.
Paul
Well, all the vinyl is gone and most of the glue taken off with an angle grinder with one bad ass wire brush attached. I was smart enough to mask off the areas where I didn't want residue with masking tape and cheap drop cloths which saved me a lot of cleanup.
[cid:460161421@06052010-0C38]
I also wore appropriate safety gear . . .LUKE . . . I AM YOUR FATHER . . . at least that's what I felt like ;-)
[cid:460161421@06052010-0C3F]
[cid:460161421@06052010-0C46]
My next step is to wash down the walls with acetone and get as much remaining residue off as I can. Then I hope to fair it with West Systems 410, the light micro-ballons.
Here is the question of the day . . . am I now going to be getting condensation on these "walls" and the underside of the decks? If so, was the foam backed vinyl that was there preventing it before or just absorbing it?
Donald if you're reading this, did your wife ever have the chance to look into insulation values of paints or fillers with the microballoons?
The one thing that has really struck me about this job so far is how inaccessible the genny track bolts, the stanchion base bolts and basically anything bolted to the side decks are. Without basically destroying the interior of the boat they are basically not accessible which explains why I have 2 stanchion bases that are cracked and probably 3 others that wobble!
Paul West
Adventure Kwest
'80 Cal 39
