Re: [Cal_Boats] Bad Voltage Regulator -- Timm
1 messages2010-05-17 19:55 UTCthrough 2010-05-17 19:55 UTC
Allen Edwards2010-05-17 19:55 UTC
I ended up ordering one this morning from Van Ness Engineering. I don't know who makes it but Dave recommended it and it is solid state. This way I know it is a match for the alternator. It is also CG approved. Hopefully this will cure the strange engine problem you said was caused by the charging system. Allen On Mon, May 17, 2010 at 12:40 PM, <ti… [at] ch2m.com> wrote: > > > Why not get a modern solid state regulator, like an ARS? > > > > We did that on California Girl when she still had a Flathead Fireball 410 > Gray Marine. > > > > *From:* Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] *On > Behalf Of *Allen Edwards > *Sent:* Sunday, May 16, 2010 2:55 PM > *To:* Ca… [at] yahoogroups.com > *Subject:* [Cal_Boats] Bad Voltage Regulator > > > > > > I seem to have fried my voltage regulator. It works with an alternator on > my Gray Marine engine. It is a metal box, about 3x4x2.5 deep. Has 5 (6 > counting ground) connections. > > BAT > > IGN > > NEUT > > FLD > > LAMP (unused) > > The case is ground. > > > > The marking is > > LEECE-NEVILLE CO > > CLEVELAND OHIO > > > > It has two relays inside and three resistors on the back. No part numbers. > > > > Anyone know what I have and where I can get another one? > > > > Allen > > > > > > >
