2 messages2010-06-06 15:57 UTCthrough 2010-06-07 15:31 UTC
Re: Rot
Alfred Poor2010-06-06 15:57 UTC
The original message is ambiguous to me, as the rot could be in the deck or
the bulkhead. On our Cal 29 Pentaquod, we had rot in both the vee-berth and
main bulkheads when we originally got the boat, and on both sides. I would
advise against trying to stabilize the compromised wood as this is a
structural component and you will probably lose your mast if a chainplate
pulls out. (A new mast probably costs more than the insured value of your
boat. I have first-hand experience on that score.)
Ultimately, replacing the bulkheads is the right thing to do. In the
meantime, you could try what we did on Pentaquod. We "sistered" plywood onto
the bulkheads. I'd recommend using plywood at least as thick as the
bulkhead, and then cut a section that is significantly larger than the
compromised area. Screw it to the bulkhead (use epoxy as well for extra
measure if you like) and then use longer bolts to attach the chainplates to
their original locations.
It's not a pretty solution, but it's a rugged fix that can buy you the time
you need until you are ready to tackle the larger job (which isn't as bad as
it might seem).
Alfred Poor
RE: [Cal_Boats] Re: Rot
Rick Lobb2010-06-07 15:31 UTC
Thanks to all for your replies. Looks like I will be replacing the
bulkheads. Is there a site with steps and pics and advise on how to go
about this?
I am sorry if my original message was ambiguous. The issue is with the
v-berth and main bulkheads, starboard side. My beam is in good condition,
so I don't plan on replacing at this time.
Rick Lobb
Cal 2-29 Rebecca Shea
Of Alfred Poor
Sent: Sunday, June 06, 2010 8:57 AM
Subject: [Cal_Boats] Re: Rot
it might seem).
Alfred Poor
