14 messages2010-06-15 04:17 UTCthrough 2010-06-18 07:56 UTC
CAL 29 high wind sails
Randy Alcorn2010-06-15 04:17 UTC
Hey fellow CAL 29 owners,
what are you using as a number 3 sail? A couple of weeks ago we did a race with winds blowing 35 plus. My old #3 blew up. It was a short hoist 110ish. It attached to my genoa track and did not point very well. It would cause my boat to roll over on it's side and wallow around until the gusts were over.
I asked my sail maker for a full hoist blade, but the forward lowers create problems. I moved the forwards back. But when I pulled on the back stay it was reall mushy.
Finn mentioned that the CAL 40's removed theirs. How did they support the mast. I also think my chain plates are a little light to attach everything to.
How do the San Francisco CAL 29's deal with 25-35 knots of wind?
Thanks
Randy
Out Patient
CAL 2-29 #512
Channel Islands CA
Re: [Cal_Boats] CAL 29 high wind sails
David Wilkie Owen2010-06-15 14:08 UTC
Randy,
I removed my forward lowers. I moved the aft lowers to the same main
bulkhead as the main shrouds. This allowed me to buy a full hoist
blade. It sheets to a new track up against the house sides and right
up near the shrouds. It is not quite a lapper, probably about 90%.
In 25 knots and over I have to roll it up, which does not work. It is
not a very good #3 but works fairly well with the full main in 20
knots but not really much over. I need a #4 as well.
The single lower modification did not work out very well. I did all
the math with the help of a rigger and Skein's (sp?) rigging book.
The problem is the placement of the chain plates on the bulkhead,
which is maybe 3 or 4 inches too far forward for the mast to rake (and
shape) properly. I don't recommend doing it. Maybe I'll install a
baby-stay some day and see if that helps -- then it's in the way of
the pole though, so it would have to be rigged to slack for downwind.
OTOH, I do like being able to run my spinnaker pole back to the
shrouds without interference - helps DDW, but that's never a good
point of sale anyway.
Just my experiences.
Wilkie
> Thanks
> Randy
> Out Patient
> CAL 2-29 #512
> Channel Islands CA
Randall Alcorn2010-06-15 14:26 UTC
Thanks Dave, Kevin Miller is working with me. He recommended using the topping lift with spectra line for the weather legs. Then disconnecting it down wind for the pole.
Did you change your Chain plates to handle the loads?
Thanks again
-- Sent from my Palm Pixi
On Jun 15, 2010 7:08, David Wilkie Owen <dw… [at] cox.net> wrote:
Randy,
I removed my forward lowers. I moved the aft lowers to the same main bulkhead as the main shrouds. This allowed me to buy a full hoist blade. It sheets to a new track up against the house sides and right up near the shrouds. It is not quite a lapper, probably about 90%. In 25 knots and over I have to roll it up, which does not work. It is not a very good #3 but works fairly well with the full main in 20 knots but not really much over. I need a #4 as well.
The single lower modification did not work out very well. I did all the math with the help of a rigger and Skein's (sp?) rigging book. The problem is the placement of the chain plates on the bulkhead, which is maybe 3 or 4 inches too far forward for the mast to rake (and shape) properly. I don't recommend doing it. Maybe I'll install a baby-stay some day and see if that helps -- then it's in the way of the pole though, so it would have to be rigged to slack for downwind.
OTOH, I do like being able to run my spinnaker pole back to the shrouds without interference - helps DDW, but that's never a good point of sale anyway.
Wilkie
On Jun 14, 2010, at 9:17 PM, Randy Alcorn wrote:Hey fellow CAL 29 owners,what are you using as a number 3 sail? A couple of weeks ago we did a race with winds blowing 35 plus. My old #3 blew up. It was a short hoist 110ish. It attached to my genoa track and did not point very well. It would cause my boat to roll over on it's side and wallow around until the gusts were over. I asked my sail maker for a full hoist blade, but the forward lowers create problems. I moved the forwards back. But when I pulled on the back stay it was reall mushy. Finn mentioned that the CAL 40's removed theirs. How did they support the mast. I also think my chain plates are a little light to attach everything to. How do the San Francisco CAL 29's deal with 25-35 knots of wind? ThanksRandy Out PatientCAL 2-29 #512Channel Islands CA
Allen Edwards2010-06-15 14:31 UTC
I just put a #3 on my L-36 inside the rigging without moving the forward
lower just a few weeks ago. The clew is ab out 18 inches off the deck. The
lower the clew, the larger sail you can get and still clear the forward
lower. I installed track about 2 inches off the cabin side. The sail is a
Quantum cursing laminate with taffeta-mylar-Dacron threads-mylar-taffeta and
has 4 batons. Going from a Dacron sail to this higher tech batoned sail
added about 30% to the cost of the sail. I went with it because I was
worried about a skinny high aspect sail holding its shape. This sail holds
its shape under any wind up to the 30+ knots we have tried it in so far.
As far as how we deal with the high winds, we let the main out until the
boat is healing less than 25 degrees. Last race was in over 30 knots and
the main was flogging on the beat but we were able to chase down the other
boats and finished 37 seconds behind the first boat to cross the line and
they owed us 2 1/2 minutes. Many boats that crossed behind us owed us even
more time. We are pointing about 29 degrees to the apparent wind. By the
way, we sail with the windward tell-tail pointing straight up when the wind
is strong, which it usually is around here (SF Bay).
One of the other L-36s around here raced once in 40 knots of wind with a 155
jib. He just let the main flog. It was an offshore race of several hours
in length and he beat the second place boat by 1/2 hour.
I have no idea how similar a Cal 29 is but thought this might be useful
information.
On Tue, Jun 15, 2010 at 7:08 AM, David Wilkie Owen <dw… [at] cox.net> wrote:
> Randy,
> need a #4 as well.
> anyway.
> Wilkie
> was reall mushy.
> to.**
> Thanks
> Randy
> Out Patient
> CAL 2-29 #512
> Channel Islands CA
David Wilkie Owen2010-06-15 17:23 UTC
Couldn't figure out the topping lift reference at first, but the light
has gone on now. So you mean the Pole topping lift -- switch it from
the deck to the pole as needed. Maybe it's mounted a little higher
than optimum on the mast? Can't visualize it in my mind until
Since I couldn't find off-the-rack chainplates to accommodate both
shrouds, I had them custom built by a guy here in SB. He's a great
older machinist who likes to work with sailors. Don't remember the
cost, but they are massive and will never ever die. I will try and
attach a photo
Wilkie
> Thanks again
> Randy,
> for downwind.
> Wilkie
>> Thanks
>> Randy
>> Out Patient
>> CAL 2-29 #512
>> Channel Islands CA
Randall Alcorn2010-06-17 21:20 UTC
Wilkie,
Did you have to be rerated after you moved your lowers? I am being told I have to reapply.
Randy
On Jun 15, 2010 10:25, David Wilkie Owen <dw… [at] cox.net> wrote:
Couldn't figure out the topping lift reference at first, but the light has gone on now. So you mean the Pole topping lift -- switch it from the deck to the pole as needed. Maybe it's mounted a little higher than optimum on the mast? Can't visualize it in my mind until
Since I couldn't find off-the-rack chainplates to accommodate both shrouds, I had them custom built by a guy here in SB. He's a great older machinist who likes to work with sailors. Don't remember the cost, but they are massive and will never ever die. I will try and attach a photo Wilkie
On Jun 15, 2010, at 7:26 AM, Randall Alcorn wrote:Thanks Dave, Kevin Miller is working with me. He recommended using the topping lift with spectra line for the weather legs. Then disconnecting it down wind for the pole.Did you change your Chain plates to handle the loads?Thanks again-- Sent from my Palm PixiOn Jun 15, 2010 7:08, David Wilkie Owen <dw… [at] cox.net> wrote: Randy,I removed my forward lowers. I moved the aft lowers to the same main bulkhead as the main shrouds. This allowed me to buy a full hoist blade. It sheets to a new track up against the house sides and right up near the shrouds. It is not quite a lapper, probably about 90%. In 25 knots and over I have to roll it up, which does not work. It is not a very good #3 but works fairly well with the full main in 20 knots but not really much over. I need a #4 as well.The single lower modification did not work out very well. I did all the math with the help of a rigger and Skein's (sp?) rigging book. The problem is the placement of the chain plates on the bulkhead, which is maybe 3 or 4 inches too far forward for the mast to rake (and shape) properly. I don't recommend doing it. Maybe I'll install a baby-stay some day and see if that helps -- then it's in the way of the pole though, so it would have to be rigged to slack for downwind. OTOH, I do like being able to run my spinnaker pole back to the shrouds without interference - helps DDW, but that's never a good point of sale anyway.Just my experiences.WilkieOn Jun 14, 2010, at 9:17 PM, Randy Alcorn wrote:Hey fellow CAL 29 owners,what are you using as a number 3 sail? A couple of weeks ago we did a race with winds blowing 35 plus. My old #3 blew up. It was a short hoist 110ish. It attached to my genoa track and did not point very well. It would cause my boat to roll over on it's side and wallow around until the gusts were over. I asked my sail maker for a full hoist blade, but the forward lowers create problems. I moved the forwards back. But when I pulled on the back stay it was reall mushy. Finn mentioned that the CAL 40's removed theirs. How did they support the mast. I also think my chain plates are a little light to attach everything to. How do the San Francisco CAL 29's deal with 25-35 knots of wind? ThanksRandy Out PatientCAL 2-29 #512Channel Islands CA
Re: [Cal_Boats] CAL 29 high wind sails [1 Attachment]
mike farrell2010-06-17 21:45 UTC
PHRF Rating does not consider shroud placement.
To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com>
Sent: Thu, June 17, 2010 2:20:39 PM
Subject: Re: [Cal_Boats] CAL 29 high wind sails [1 Attachment]
[Attachment(s) from Randall Alcorn included below]
Wilkie,
Randy
Wilkie
>Thanks again
>Randy,
>Wilkie
>>Thanks
>>Randy
>>Out Patient
>>CAL 2-29 #512
>>Channel Islands CA
1 of 1 Photo(s)
Unnamed_1276623042194
RE: [Cal_Boats] CAL 29 high wind sails
ti… [at] ch2m.com2010-06-17 22:04 UTC
Be careful... if it's moved you should state it... it is possible the committee will note and ignore,
or give you a 3 second hit, just because you changed it from stock...
there must have been a reason?
(faster) or better sheeting angle (sail higher)....
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of mike farrell
Sent: Thursday, June 17, 2010 2:46 PM
[Attachment(s)<http://us.mg3.mail.yahoo.com/dc/blank.html?bn=397.8&.intl=us&.lang=en-US#TopText> from Randall Alcorn included below]
Wilkie,
Randy
Wilkie
[cid:EB… [at] sd.cox.net]
Thanks again
On Jun 15, 2010 7:08, David Wilkie Owen <dw… [at] cox.net<mailto:dw… [at] cox.net>> wrote:
Randy,
Wilkie
Thanks
Randy
Out Patient
CAL 2-29 #512
Channel Islands CA
1 of 1 Photo(s)
[http://xa.yimg.com/kq/groups/16485695/tn/1167706688]<http://groups.yahoo.com/group/Cal_Boats/attachments/folder/220248802/item/1167706688/view>
Unnamed_1276623042194<http://groups.yahoo.com/group/Cal_Boats/attachments/folder/220248802/item/1167706688/view>
Randy Alcorn2010-06-18 00:42 UTC
Thanks Timm,
I was afraid of that, the biggest gain would to be able tack easier and sheet in faster. Then to add a blade would be able to add more power to weather without backwinding the main.
I found the sail locker for a CAL 29. I just might have to stay original designs and see what happens. The sail that blew up was not the same measurement and LP for a working jib.
I was hoping someone from San Fransico would respond, San Fran had the biggest CAL 29 one design fleet at one time, now it is all Catalina 30s.
Randy
Sent: Thu, June 17, 2010 3:04:26 PM
Subject: RE: [Cal_Boats] CAL 29 high wind sails
Be careful… if it’s moved you should state it… it is possible the committee will note and ignore,
or give you a 3 second hit, just because you changed it from stock…
(faster) or better sheeting angle (sail higher)….
From:Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of mike farrell
To: "Cal_Boats@yahoogrou ps.com" <cal_boats@yahoogrou ps.com>
Wilkie,
Randy
Wilkie
Thanks again
Randy,
Wilkie
Thanks
Randy
Out Patient
CAL 2-29 #512
Channel Islands CA
1 of 1 Photo(s)
Unnamed_12766230421 94
David Wilkie Owen2010-06-18 01:15 UTC
Randy,
I no longer race PHRF but I would certainly expect to be re-rated if I
did. My local sailing buddies find my rating out of date and have
urged that I apply for a more favorable rating, but doubt that will
happen at this point in my sailing life. Others might think that I
just suck, but I actually have an extremely winning record helming,
more modern boats.
Wilkie
> Wilkie,
> Randy
> attach a photo
> Wilkie
>> Thanks again
>> Randy,
>> Wilkie
>>> Thanks
>>> Randy
>>> Out Patient
>>> CAL 2-29 #512
>>> Channel Islands CA
David Wilkie Owen2010-06-18 01:33 UTC
More of my .02 cents worth.... I don't find the boat much easier to
tack and the blade / full main combo doesn't point significantly
higher than my #2 sheeted on an inside track (or barber-hauled.) I
love the idea, but the reality is I rarely get to run that combo.
I think I'm also ready to pronounce that making a Cal 29 point higher
(even just 3 or 4 degrees) carries the penalty that she just don't
wanna roll that way and is so less-efficient at it that you are better
off giving her what she wants and meeting the other boats as you cross
tacks. I don't know... make any sense? I seem do do better running
for speed and timing my crosses for maximum clean air and minimum
ducking. If I slog along in the gas of a boat that is designed to
point higher than Mariposa, they just sail away from me.
What I do like is that I can run my spinnaker pole back to the main
shrouds and really wing that sucker out DDW, which might save me a
gybe to the leeward mark, but the spin and main are both just sort of
blocking the wind instead of drawing and I've yet to catch anyone
running hotter and gybing as required so WTF?
Bottom line is that I spent a lot of cash for not much net. Maybe
Bill Lapworth knew what he was doing and I shouldn't be trying to race
modern boats using their tactics. So between that and the lack of
local participation of other comparable boats, I am happy sailing
under the SBYC's CHRF rating system, which attempts to compensate for
wind and boat size factors on a weekly basis.
Wilkie
On Jun 17, 2010, at 5:42 PM, Randy Alcorn wrote:
> Thanks Timm,
> Catalina 30s.
> Randy
> From: "ti… [at] ch2m.com" <ti… [at] ch2m.com>
> From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup
> From: Randall Alcorn <saylorran@yahoo. com>
> Wilkie,
> Randy
> attach a photo
> Wilkie
> Thanks again
> Randy,
> for downwind.
> Wilkie
> Thanks
> Randy
> Out Patient
> CAL 2-29 #512
> Channel Islands CA
> 1 of 1 Photo(s)
Randy Alcorn2010-06-18 03:21 UTC
Wilkie,
You are the inspiration to all of us CAL 29 ers. I am only trying to keep the 29 in the hunt.
Randy
Sent: Thu, June 17, 2010 6:15:29 PM
Randy,
I no longer race PHRF but I would certainly expect to be re-rated if I did. My local sailing buddies find my rating out of date and have urged that I apply for a more favorable rating, but doubt that will happen at this point in my sailing life. Others might think that I just suck, but I actually have an extremely winning record helming, more modern boats.
Wilkie
>Wilkie,
>Randy
>Wilkie
>>Thanks again
>>Randy,
>>Wilkie
>>>Thanks
>>>Randy
>>>Out Patient
>>>CAL 2-29 #512
>>>Channel Islands CA
Randy Alcorn2010-06-18 03:50 UTC
Down here in Oxnard, the waters have a little more wind than up in Santa Barbra. Our wet Wednesdays are normally 15-25. Once in a while we get the 35 plus. I just need something to handle the winds up to 35. We don't cancel many races.
I read somewhere that Bill Lapworth said that a CAL rides over the waves and was not designed to bust thru them. Maybe that is why the sail plan is designed low and not made to point so high.
Ok, I think I am staying stock again. We hardly ever get 25-35 flat seas. They are normally 10-12 with 14-16ers thrown in.
Thanks
Sent: Thu, June 17, 2010 6:33:47 PM
More of my .02 cents worth.... I don't find the boat much easier to tack and the blade / full main combo doesn't point significantly higher than my #2 sheeted on an inside track (or barber-hauled. ) I love the idea, but the reality is I rarely get to run that combo.
I think I'm also ready to pronounce that making a Cal 29 point higher (even just 3 or 4 degrees) carries the penalty that she just don't wanna roll that way and is so less-efficient at it that you are better off giving her what she wants and meeting the other boats as you cross tacks. I don't know... make any sense? I seem do do better running for speed and timing my crosses for maximum clean air and minimum ducking. If I slog along in the gas of a boat that is designed to point higher than Mariposa, they just sail away from me.
What I do like is that I can run my spinnaker pole back to the main shrouds and really wing that sucker out DDW, which might save me a gybe to the leeward mark, but the spin and main are both just sort of blocking the wind instead of drawing and I've yet to catch anyone running hotter and gybing as required so WTF?
Bottom line is that I spent a lot of cash for not much net. Maybe Bill Lapworth knew what he was doing and I shouldn't be trying to race modern boats using their tactics. So between that and the lack of local participation of other comparable boats, I am happy sailing under the SBYC's CHRF rating system, which attempts to compensate for wind and boat size factors on a weekly basis.
Wilkie
>Thanks Timm,
>Randy
From: "timmothy.lessley@ ch2m.com" <timmothy.lessley@ ch2m.com>
>From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of mike farrell
>To: "Cal_Boats@yahoogro u ps.com" <cal_boats@yahoogrou ps.com>
>Wilkie,
>Randy
>Wilkie
>Thanks again
>Randy,
>Wilkie
>Thanks
>Randy
>Out Patient
>CAL 2-29 #512
>Channel Islands CA
>1 of 1 Photo(s)
David Wilkie Owen2010-06-18 07:56 UTC
Still would like to come down and crew for you some time. It would be
fun to experience another 29 -- one that actually wins some races.
Wilkie
> Thanks
> From: David Wilkie Owen <dw… [at] cox.net>
> Wilkie
>> Thanks Timm,
>> Catalina 30s.
>> Randy
>> Wilkie,
>> Randy
>> mind until
>> attach a photo
>> Wilkie
>> Thanks again
>> Randy,
>> Wilkie
>> Thanks
>> Randy
>> Out Patient
>> CAL 2-29 #512
>> Channel Islands CA
>> 1 of 1 Photo(s)
