10 messages2010-06-25 02:22 through 2010-06-26 01:36 UTC
Cal 29 rigging tension
hatikvah292010-06-25 02:22
I just bought all new standing rigging for my Cal29 and am wondering how people setup their rig. I know about the basics of using a tape measure to get the mast straight left and right and the uppers and lowers to keep the mast from bending in the middle or something screwy. I am wondering about forestay and backstay and how much tension should be on all the wires when it is tuned. I sail in san Francisco Bay so it gets windy.
Thanks in advance,
Scott
74 Cal29
Re: [Cal_Boats] Cal 29 rigging tension
Allen Edwards2010-06-25 02:44 UTC
This might help if you have not seen it.
http://l-36.com/lapworth_letter.pdf
<http://l-36.com/lapworth_letter.pdf>
> Thanks in advance,
> Scott
> 74 Cal29
Terry Spencer2010-06-25 03:14 UTC
There is a very nicely written section in Brion Toss' book The Riggers Apprentice.
Terry Spencer
Cal 2-29
> Thanks in advance,
> Scott
> 74 Cal29
RE: [Cal_Boats] Cal 29 rigging tension
Scott Cyphers2010-06-25 03:36 UTC
That is a great letter. What is the reference to the truck mean?
Scott
74 Cal29
Of Allen Edwards
Sent: Thursday, June 24, 2010 7:45 PM
Subject: Re: [Cal_Boats] Cal 29 rigging tension
Thanks in advance,
Scott
74 Cal29
mike farrell2010-06-25 08:00 UTC
Mr. Lapworth is referring to the top 6 inches of the mast,the mast head. Many of the sails that he makes reference to are not in popular use today, remember that this letter was written a long time ago. Many boats now use the backstay to curve(bend) the rig to pull draft out of the main and really tighten the forestay. On SF Bay perhaps more tension on the upper shrouds is called for, also more on the aft lowers. Remember most of the load is carried by the aft lowers. Your mast should not pump but some deflection sideways is ok. At the dock the uppers and lowers will be taunt but when going to weather there will be considerable slack in the leeward shrouds caused by the weather rigging allowing the mast to fall off. Contact Steve Seal at Seal's Spars 1327 Sherman st. Alameda 510 521 7730 www.sealsspars.com Steve built boats for Jensen Marine in Costa Mesa in the 1960's
Keep it FUN!!! My Best, Mike
Sent: Thu, June 24, 2010 8:36:54 PM
Subject: RE: [Cal_Boats] Cal 29 rigging tension
Scott
74 Cal29
From:Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Allen Edwards
Thanks in advance,
Scott
74 Cal29
ti… [at] ch2m.com2010-06-25 14:25 UTC
Truck is plate at top of mast
Cheers,
Timm Lessley
(Sent from Blackberry)
(503) 863-4019
Sent: Thu Jun 24 21:36:54 2010
Scott
74 Cal29
On Thu, Jun 24, 2010 at 7:22 PM, hatikvah29 <sc… [at] sbcglobal.net<mailto:sc… [at] sbcglobal.net>> wrote:
Thanks in advance,
Scott
74 Cal29
Allen Edwards2010-06-25 15:04 UTC
For the sake of completeness, I will point out that there seem to be two
theories on rig tightness. Lapworth was of the lose rig camp but there is a
tight rig camp. That camp points out that if you have the lowers and uppers
just tight when the rig is under load sailing, that the forces are no more
than they would be with a lose rig but the rig is snug so will not
experience as much shock load on waves. It is true that the rig will not be
under more stress when sailing but it will certainly be under more stress at
the dock unless you slack off on the turnbuckles after your sailing day. I
am of the lose camp as my boat has been made deeper over the years as it is
and I don't want it to change shape any more. Also, the main guy I race
against, who puts many thousands of pounds on his forestay when racing, has
the lowers and uppers sloppy lose at the dock, no tension at all. Of
course, they are under whatever tension is required to keep the mast up when
sailing. This points out that no matter what camp you are in, making sure
the mast stays in column or perhaps falls off a little is the most important
thing. A mast is only strong because it is straight. If you let it go into
a C or worse a S, it is much less strong.
Cheers,
> the 1960's
> *From:* Scott Cyphers <sc… [at] sbcglobal.net>
> *Sent:* Thu, June 24, 2010 8:36:54 PM
> *Subject:* RE: [Cal_Boats] Cal 29 rigging tension
> Scott
> 74 Cal29
> Behalf Of *Allen Edwards
> *Sent:* Thursday, June 24, 2010 7:45 PM
> *Subject:* Re: [Cal_Boats] Cal 29 rigging tension
> Thanks in advance,
> Scott
> 74 Cal29
chris1232010-06-25 16:54 UTC
A copy of the rigging data that came with BayBreeze.
Best regards
Rigging tension
Fin Beven2010-06-25 20:01 UTC
I replaced the mast on Radiant about 10 years ago.
The original plan was just to pull it and re-condition.
When they were taking things apart, the weld that held the port-side spreader on to the mast simply fell off. Total weld failure.
Back when these boats were launched, lose rigs were pretty common, and obviously lots of folks still like it that way.
However, unless your spreaders can easily swing fore-and-aft, with a lose rig, with every wave you hit the leeward spreader jerks forward. This puts a significant load on the spreader base. Time-after-time-after-time.
When the new mast was stepped, the rigger was very clear: set up the tension so that the leeward shrouds are taught when the windward shrouds are loaded in your typical wind conditions. This should prevent that jerking motion on the leeward spreaders.
That was his opinion. I've followed it, and our speed seems just fine.
Fin.
RE: [Cal_Boats] Rigging tension
Scott Cyphers2010-06-26 01:36 UTC
Very timely advice. When I took the mast down and was removing the rigging I
noticed that the weld in the port spreader bracket had a crack about halfway
down the weld. I had the yard bead blast it and grind it down and reweld it.
This from the advice of Steve Seal. I was so glad to find that almost
failure before it happwened. I think I agree to have the rig not slpooy. I
am not racing it in other than beer cans so I would rather not beat the
boat.
Scott
74 Cal29
Of Fin Beven
Sent: Friday, June 25, 2010 1:02 PM
Subject: [Cal_Boats] Rigging tension
Fin.
