29 messages2010-06-10 11:31 through 2010-07-01 00:32 UTC
stuffing box
gregreinhard2010-06-10 11:31
Hi all, When I motor my 1986 Cal 28-II (Westerbeke diesel 13 hp} I accumulate guite a bit water in the bilge. Since I do not have an automatic bilge pump (need to change this, I need to turn it on manually, a step I frequently forget when we are sailing and only get to when we get back to the slip. At that point I have to evacuate maybe a gal or two of water. Had the yard check the stuffing box and they tightend it but did not repack. It still accumlates what seems to me quite a bit of water, although my previous boats had much larger bilges than the Cal.
What do you think? Should I put more stuffing in the box or bite the bullet and install an automatic pump?
Thanks, Greg
Re: [Cal_Boats] stuffing box
Charles Strasburger2010-06-10 12:00 UTC
Might I suggest you do both? Sounds to me like the packing gland needs repacking anyway.....or, if you are going to keep the boat, install a pss-dripless. Used one for many years with no issues....
And, INSTALL THE AUTOMATIC BILGE PUMP!
Charles
S/V Boomerang!
1980 Cal 39, Mark II
St Michaels, MD
Sent: Thu, June 10, 2010 7:31:20 AM
Subject: [Cal_Boats] stuffing box
Thanks, Greg
mike2010-06-10 12:00 UTC
Greg,
Are you sure it is coming from your stuffing box? Since it only happens
when the motor is running, perhaps there is a leak from your raw water
pump system. If you have already eliminated that possibility, a stuffing
box should not leak while at rest and, if you have the standard stuffing
box with flax inside, it should optimally only drip once every 30
seconds or so for cooling. With the engine running and the transmission
engaged, let the prop turn and then tighten the stuffing box in
increments until you get the 1 drop roughly every 30 seconds rate. If
you can't achieve this, then it is time to replace the flax in the
packing gland. If you have to re-pack the stuffing box, be sure to
examine the shaft where the flax makes contact to ensure that a groove
hasn't formed in the shaft. A groove may be smooth, but will cause
problems with trying to stop excessive leaking since the minute
longitudinal changes in shaft position while going from forward to
reverse will change where the flax rides on the shaft.
Install an automatic bilge pump. It is cheap insurance and will give you
some peace of mind. Like everything on a boat it will need to be
inspected and tested periodically too.
Good luck.
Mike
> Thanks, Greg
Re: [Cal_Boats] stuffing box P.S.
mike2010-06-10 12:06 UTC
P.S. When adjusting your stuffing box with the engine in gear, be VERY
careful to not get any loose clothing, rags, hands etc. too close to the
spinning shaft! It WILL hurt you in a bad way! You know this already,
but I felt the need to emphasize...
Mike M.
> Thanks, Greg
RE: [Cal_Boats] stuffing box
Harleigh Ewell2010-06-10 12:11 UTC
X2. If you are leaking that much while you're motoring, it's likely it
is leaking while you are not motoring as well. Plus check to make sure
you don't have a leak in your cooling system. I can recommend the Water
Witch automatic bilge pump switch, or an equivalent that provides a
delay in turning on and off so that you don't cycle the bilge pump as
water sloshes back and forth in the bilge.
Harleigh
Behalf Of Charles Strasburger
Sent: Thursday, June 10, 2010 8:00 AM
Subject: Re: [Cal_Boats] stuffing box
Charles
S/V Boomerang!
St Michaels, MD
than the Cal.
Thanks, Greg
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 5186 (20100610) __________
http://www.eset.com
Joe DeMers2010-06-10 12:11 UTC
You can either fix the problem [ find the leak and make repairs ] or
treat the symptom [ pump out the excessive bilge water ] .
I suggest you fix the problem by first confirming the source of the
leak. If it is the stuffing box, repack it with Gore Tex packing, _AND
adjust it correctly._
Also check the raw water pump for a leaking condition, which indicates
repairs needed.
Other sources of leaks can be from cracked or loose exhaust hoses, leaky
c-cocks, cracked muffler, cracked heat exchanger, etc.
*Joe DeMers - owner*
Sound Marine Diesel LLC
*phone & fax (860) 666-2184*
> Thanks, Greg
> Yahoo! Groups Links
> Version: 9.0.829 / Virus Database: 271.1.1/2929 - Release Date: 06/10/10 02:35:00
stuffing box
Mike Hofstetter2010-06-10 12:20 UTC
Hi Greg,
It seems to me that if you are still leaking after a stuffing box adjustment, it is most likely time to repack. I did this in the water last year on my '88 28-2 and it really wasn't bad with easy and open access to the stuffing box and shaft.
I don't know what it is like to not have an automatic bilge pump, but I can say that the peace of mind would make it worth adding a automatic pump.
I can let you know how I replaced my packing (and kept most water out) if you decide to do yours.
Mike Hofstetter
chris1232010-06-10 12:41 UTC
All good advice. Also you may consider installing a $2 flashing LED at the
helm somewhere and hardwired it to the bilge pump switch when in auto mode.
In this manner, should the bilge pump come on while at sea, you are alerted
to the situation
In theory it should not come on, so if it does start flashing you know
something is going on and decide if it warrants immediate or delayed action.
Best regards
Allen Edwards2010-06-10 15:15 UTC
If your stuffing box drips when you motor and does not drip in the slip,
leave it alone. My experience is that it is very difficult to get it in
this state. Mine either drips or not and I can move it 1 rch and it goes
from one state to the other without being able to get it to drip when
motoring yet not drip in the slip. My dockmate told me he has the same
problem. So, consider yourself lucky that it drips when you motor. It
should drip when you motor and you should have water in the bilge when you
An automatic pump might save you boat if something else fails so that would
be my vote.
> Thanks, Greg
mike2010-06-10 16:33 UTC
These are the same 'symptoms' I was getting on the boat with the groove
worn into the shaft. When the owner shut down the motor after shifting
from fwd-neut, there would be no leak as the packing gland was set on
the groove 'flange'. However, when he shut down the engine after
shifting from rev-neut, the shaft would set itself an rch off the flange
and leak like a sieve. At which point he would tighten the box causing
it to wear the groove deeper over time. This was on a Morgan 32 with a
very shallow bilge. The owner did not want to pay for a $450 shaft so I
advised the owner that there would be a weak spot on the shaft and
'fixed' it by replacing the shaft log hose connecting the stuffing box
to the log with one an inch longer. I replaced the flax in the box and
the whole thing was able to ride on a fresh piece of the shaft. No leaks
at rest and 1 drop/30 seconds under power. I made absolutely sure the
engine and the shaft were aligned properly and that there was no
appreciable vibration throughout its RPM range. (I did an engine swap on
that boat so had to do these things anyway).
Allen does have a point though. If it isn't leaking at rest, then there
is no need to be excessively concerned about it as long as you are able
to get the water out of the boat.
Mike M.
> slip, leave it alone. My experience is that it is very difficult to
> get it in this state. Mine either drips or not and I can move it 1
> rch and it goes from one state to the other without being able to get
> it to drip when motoring yet not drip in the slip. My dockmate told
> me he has the same problem. So, consider yourself lucky that it drips
> when you motor. It should drip when you motor and you should have
> water in the bilge when you get back to the slip.
> would be my vote.
> Allen
> Thanks, Greg
> _
Mark Alan Stahnke (MAS Consulting)2010-06-10 16:40 UTC
I had the same issue with my packing gland leaking too much when in use.. I simply shoved heavy grease into the gland to lubricate the packing and this solved my problem. It also makes it so you don't have to crank down on the gland nut to regulate the drip.
Mark
Cal 2-29
San Pedro
Sent: Thursday, June 10, 2010 8:15 AM
If your stuffing box drips when you motor and does not drip in the slip, leave it alone. My experience is that it is very difficult to get it in this state. Mine either drips or not and I can move it 1 rch and it goes from one state to the other without being able to get it to drip when motoring yet not drip in the slip. My dockmate told me he has the same problem. So, consider yourself lucky that it drips when you motor. It should drip when you motor and you should have water in the bilge when you get back to the slip.
An automatic pump might save you boat if something else fails so that would be my vote.
Thanks, Greg
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5187 (20100610) __________
http://www.eset.com
http://www.eset.com
scott cyphers2010-06-10 19:10 UTC
In regards to the bilge pump. I am needing to replace mine and am looking at the Rule 1500 or 2000gph fully automated pumps. Does anyone have an opinion on these? I have a Cal29 and it seems easier to not have an external switch because of the orientation of the deep bilge.
Thanks, Scott 74 Cal29
Date: Thursday, June 10, 2010, 5:11 AM
You can either fix the problem [ find the leak and make repairs ] or treat the symptom [ pump out the excessive bilge water ] .
I suggest you fix the problem by first confirming the source of the leak. If it is the stuffing box, repack it with Gore Tex packing, AND adjust it correctly.
Also check the raw water pump for a leaking condition, which indicates repairs needed.
Other sources of leaks can be from cracked or loose exhaust hoses, leaky c-cocks, cracked muffler, cracked heat exchanger, etc.
Joe DeMers - owner
Sound Marine Diesel LLCSoundMarineDiesel. com
Thanks, Greg
Yahoo! Groups Links
Joe DeMers - owner
Re: [Cal_Boats] Bilge Pump (was stuffing box)
mike2010-06-10 19:27 UTC
Scott,
I have used both pumps. I have replaced them as well. They seem to last
quite awhile. The only real 'bugaboo' that I have with them is that they
have plastic tabs holding on the screen base. You press in on the tabs
to release the pump so you can muck it out, but press a little to
aggressively and the tab breaks. Not a big deal, just another of those
"S&#$t!" moments.
Since you have such a deep bilge, may I interest you in a pump on a
stick? Originally, my pump was laying at the bottom of the bilge and the
only way to get it was by yanking the wires. I ran across someones idea
and incorporated it into our boat. Basically it is a pump attached to a
PVC pipe as long as the bilge is deep. I attached a float switch to it
also. Now, when I need access to the pump, I just pull up on the pipe
and it all comes up no problem. Hope this helps.
Mike M.
Frans Sell2010-06-10 19:58 UTC
Hello Mike,
How do you change the wax seal in the water? Wouldn't the water just start gushing in from around the shaft? Sounds like a brave undertaking while in the water.
Frans
Sent: Thu, June 10, 2010 5:20:09 AM
Hi Greg,
Mike Hofstetter
Re: [Cal_Boats] Bilge Pump (Scott)
Michael D2010-06-10 20:19 UTC
Scott,
I use a Groco switch (http://www.groco.net/SVC-MAN-07/Sec3/PDFS/AS-100.pdf) that controls a Jabso Diaphram Pump (http://www.jabsco.com/products/marine/bilge_pumping_systems/electric_diaphragm_pumps/37202_shower_and_bilge_pump_37202_series/iid_2517-item2517/index.htm) for my primary. For a secondary, I have a Johnson 500 GPH (http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=11151&catalogId=10001&partNumber=11006897)
Michael
s/v Magic, Cal 2-27
Pompano Beach, FL
Wyatt Hendricks2010-06-10 23:19 UTC
Greg,
There is a lot of great advice here on the list.
I would like to point out a major corollary to Murphy's Law, "angst
expended is inversely proportional to the level of risk" and secondly
that "angst mitigates risk".
When I repacked the stuffing box on our CAL 2-46 I had a diver pack the
outside of the cutlass bearing with plumber's putty to reduce the risk
of gushing water. That seemed quite effective since water only dribbled
out of the stuffing box when I removed the nut. I shortened the log tube
hose about 3/8" to get the nut off of a shaft groove. I excavated all of
the old packing and replaced it with the Teflon impregnated sort, hand
tightened the nut back onto the stuffing box until it stopped dripping.
The diver went below and removed the plumber's putty and the stuffing
box still did not drip. I cranked the engine and ran it in gear but it
did not drip so I loosened the nut some but no drip. I kept loosening
the nut but there was no drip until finally the nut was off the stuffing
box. The water dribbled in at about the same rate as when the plumber's
putty was on the outside of the cutlass bearing. (with the engine
running in gear)
My advice is to loosen the nut until the rate of water incursion is
unmanageable. If the nut is completely off prior to an unmanageable
incursion rate proceed with the replacement of the packing material.
Otherwise employ any of the various mitigating procedures until you are
comfortable with the incursion rate.
Oh yeah, don't forget, if you don't worry over this for weeks first,
nothing will work.
Wyatt
CAL 2-46 #75
"Blythe Spirit"
St. Pete
Behalf Of gregreinhard
Sent: Thursday, June 10, 2010 7:31 AM
than the Cal.
Thanks, Greg
Allen Edwards2010-06-10 23:22 UTC
I have one of these
http://www.defender.com/product.jsp?path=-1|51|299222|84462|315207&id=84716
which
keeps the bilge dry down to 1/2 inch. And one of these
http://www.defender.com/product.jsp?path=-1|51|299222|84462|315207&id=84572
that
sits next to it in my very small bilge. The small one goes on every few
minutes and keeps the bilge dry, the lager one goes on when the small one
fails (which it does just around when the warranty is up) or when there is
serious water. The float for the big one doesn't go off until there is a
lot of water way above the sump. I like the dry bilge and the large
capacity and the redundancy. Two pumps is perfect for this old wood boat.
Of course, the boat leaks so the pumps are very important to me. One is
off each battery, btw.
Just another idea to consider.
On Thu, Jun 10, 2010 at 12:10 PM, scott cyphers
> --- On *Thu, 6/10/10, Joe DeMers <je… [at] mindspring.com>* wrote:
> From: Joe DeMers <je… [at] mindspring.com>
> If it is the stuffing box, repack it with Gore Tex packing, *AND adjust it
> correctly.*
> repairs needed.
> SoundMarineDiesel. com <http://www.soundmarinediesel.com/>
> Thanks, Greg
> Yahoo! Groups Links
Allen Edwards2010-06-10 23:28 UTC
I need to repeat my strong advice that if the stuffing box is leaking under
power and not leaking in the slip, consider yourself blessed and don't touch
it.
On Thu, Jun 10, 2010 at 4:19 PM, Wyatt Hendricks
<wh… [at] avtechmed.com>wrote:
> Greg,
> I would like to point out a major corollary to Murphy’s Law, “angst
> expended is inversely proportional to the level of risk” and secondly that
> “angst mitigates risk”.
> outside of the cutlass bearing with plumber’s putty to reduce the risk of
> gushing water. That seemed quite effective since water only dribbled out of
> the stuffing box when I removed the nut. I shortened the log tube hose about
> 3/8” to get the nut off of a shaft groove. I excavated all of the old
> packing and replaced it with the Teflon impregnated sort, hand tightened the
> nut back onto the stuffing box until it stopped dripping. The diver went
> below and removed the plumber’s putty and the stuffing box still did not
> drip. I cranked the engine and ran it in gear but it did not drip so I
> loosened the nut some but no drip. I kept loosening the nut but there was no
> drip until finally the nut was off the stuffing box. The water dribbled in
> at about the same rate as when the plumber’s putty was on the outside of the
> cutlass bearing. (with the engine running in gear)
> Oh yeah, don’t forget, if you don’t worry over this for weeks first,
> nothing will work.
> Wyatt
> CAL 2-46 #75
> “Blythe Spirit”
> St. Pete
> Behalf Of *gregreinhard
> *Sent:* Thursday, June 10, 2010 7:31 AM
> *Subject:* [Cal_Boats] stuffing box
> Thanks, Greg
john raxter2010-06-11 11:45 UTC
One more thing to check not mentioned in any of the prior e-mails.
Check the thru hulls for the cockpit drains or exhaust flange. While
motoring the boat will 'squat' and put the normally above water thru hulls
in the water. A small crack will allow a steady trickle of water.
YMMV
john
Of Allen Edwards
Sent: Thursday, June 10, 2010 7:29 PM
it.
On Thu, Jun 10, 2010 at 4:19 PM, Wyatt Hendricks <wh… [at] avtechmed.com>
wrote:
Greg,
I would like to point out a major corollary to Murphy's Law, "angst expended
is inversely proportional to the level of risk" and secondly that "angst
mitigates risk".
outside of the cutlass bearing with plumber's putty to reduce the risk of
3/8" to get the nut off of a shaft groove. I excavated all of the old
below and removed the plumber's putty and the stuffing box still did not
at about the same rate as when the plumber's putty was on the outside of the
Oh yeah, don't forget, if you don't worry over this for weeks first, nothing
will work.
Wyatt
CAL 2-46 #75
"Blythe Spirit"
St. Pete
Of gregreinhard
Thanks, Greg
Greg Reinhard2010-06-27 15:37 UTC
Thanks to all for the advice. I think John's suggestion is the key, I am rebedding my thru hulls and installing (soon) an automatic bilge pump.
Greg
Sent: Fri, June 11, 2010 7:45:58 AM
Subject: RE: [Cal_Boats] stuffing box
Check the thru hulls for the cockpit drains or exhaust flange. While motoring the boat will ‘squat’ and put the normally above water thru hulls in the water. A small crack will allow a steady trickle of water.
YMMV
john
From:Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Allen Edwards
I need to repeat my strong advice that if the stuffing box is leaking under power and not leaking in the slip, consider yourself blessed and don't touch it.
On Thu, Jun 10, 2010 at 4:19 PM, Wyatt Hendricks <whendricks@avtechme d.com> wrote:
Greg,
I would like to point out a major corollary to Murphy’s Law, “angst expended is inversely proportional to the level of risk” and secondly that “angst mitigates risk”.
When I repacked the stuffing box on our CAL 2-46 I had a diver pack the outside of the cutlass bearing with plumber’s putty to reduce the risk of gushing water. That seemed quite effective since water only dribbled out of the stuffing box when I removed the nut. I shortened the log tube hose about 3/8” to get the nut off of a shaft groove. I excavated all of the old packing and replaced it with the Teflon impregnated sort, hand tightened the nut back onto the stuffing box until it stopped dripping. The diver went below and removed the plumber’s putty and the stuffing box still did not drip. I cranked the engine and ran it in gear but it did not drip so I loosened the nut some but no drip. I kept loosening the nut but there was no drip until finally the nut was off the stuffing box. The water dribbled in at about the same rate as when the plumber’s putty was on the outside of the cutlass bearing. (with the engine running in gear)
My advice is to loosen the nut until the rate of water incursion is unmanageable. If the nut is completely off prior to an unmanageable incursion rate proceed with the replacement of the packing material. Otherwise employ any of the various mitigating procedures until you are comfortable with the incursion rate.
Oh yeah, don’t forget, if you don’t worry over this for weeks first, nothing will work.
Wyatt
CAL 2-46 #75
“Blythe Spirit”
St. Pete
From:Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com] On Behalf Of gregreinhard
Thanks, Greg
Husar, Charlie [USA]2010-06-27 18:54 UTC
I was going to mention this earlier, but slipped my mind, Greg. I once had a crack in the engine exhaust hose near the stern. Only time water leaked into the bilge was when the engine was running. Took a little while to find the cause.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Greg Reinhard
Sent: Sunday, June 27, 2010 11:37 AM
Greg
Check the thru hulls for the cockpit drains or exhaust flange. While motoring the boat will 'squat' and put the normally above water thru hulls in the water. A small crack will allow a steady trickle of water.
YMMV
john
From: Cal_Boats@yahoogrou ps.com<http://ps.com/> [mailto:Cal_ Boats@yahoogroup s.com<http://s.com/>] On Behalf Of Allen Edwards
On Thu, Jun 10, 2010 at 4:19 PM, Wyatt Hendricks <whendricks@avtechme d.com<mailto:wh… [at] avtechmed.com>> wrote:
Greg,
I would like to point out a major corollary to Murphy's Law, "angst expended is inversely proportional to the level of risk" and secondly that "angst mitigates risk".
When I repacked the stuffing box on our CAL 2-46 I had a diver pack the outside of the cutlass bearing with plumber's putty to reduce the risk of gushing water. That seemed quite effective since water only dribbled out of the stuffing box when I removed the nut. I shortened the log tube hose about 3/8" to get the nut off of a shaft groove. I excavated all of the old packing and replaced it with the Teflon impregnated sort, hand tightened the nut back onto the stuffing box until it stopped dripping. The diver went below and removed the plumber's putty and the stuffing box still did not drip. I cranked the engine and ran it in gear but it did not drip so I loosened the nut some but no drip. I kept loosening the nut but there was no drip until finally the nut was off the stuffing box. The water dribbled in at about the same rate as when the plumber's putty was on the outside of the cutlass bearing. (with the engine running in gear)
Oh yeah, don't forget, if you don't worry over this for weeks first, nothing will work.
Wyatt
CAL 2-46 #75
"Blythe Spirit"
St. Pete
From: Cal_Boats@yahoogrou ps.com<mailto:Ca… [at] yahoogroups.com> [mailto:Cal_Boats@yahoogrou ps.com<mailto:Ca… [at] yahoogroups.com>] On Behalf Of gregreinhard
To: Cal_Boats@yahoogrou ps.com<mailto:Ca… [at] yahoogroups.com>
Thanks, Greg
Michael Kennedy2010-06-27 19:03 UTC
I had a small leak in the steel water-lift exhaust tank that almost
sank the Yankee 38. I was powering up from San Diego and went below
for a drink and water was above the cabin sole. It scared the hell out
of me. It was the first trip on the boat after I bought it. Most of
them now are plastic for that reason. Corrosion.
Mike Kennedy
> Cheers
> Charlie
> Greg
> From: john raxter <jr… [at] triad.rr.com>
> trickle of water.
> YMMV
> john
> From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup
> Allen
> Greg,
> running in gear)
> nothing will work.
> Wyatt
> CAL 2-46 #75
> “Blythe Spirit”
> St. Pete
> From: Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com]
> Thanks, Greg
gene ulmer2010-06-27 19:11 UTC
good method of finding a leak is to, sprinkle baby powder all over your clean bilge and follow the water trail
gu
Sent: Sun, June 27, 2010 3:03:26 PM
Mike Kennedy
> Cheers
> Charlie
> Greg
> trickle of water.
> YMMV
> john
> Allen
> Greg,
> running in gear)
> nothing will work.
> Wyatt
> CAL 2-46 #75
> “Blythe Spirit”
> St. Pete
> Thanks, Greg
Yahoo! Groups Links
Husar, Charlie [USA]2010-06-27 19:15 UTC
That only that, but it cures bilge rash. Good idea, Gene.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of gene ulmer
Sent: Sunday, June 27, 2010 3:11 PM
good method of finding a leak is to, sprinkle baby powder all over your clean bilge and follow the water trail gu
I had a small leak in the steel water-lift exhaust tank that almost sank the Yankee 38. I was powering up from San Diego and went below for a drink and water was above the cabin sole. It scared the hell out of me. It was the first trip on the boat after I bought it. Most of them now are plastic for that reason. Corrosion.
Mike Kennedy
> Cheers
> Charlie
> pump.
> Greg
> water.
> YMMV
> john
> Allen
> Greg,
> running in gear)
> nothing will work.
> Wyatt
> CAL 2-46 #75
> "Blythe Spirit"
> St. Pete
> Thanks, Greg
Yahoo! Groups Links
Yahoo! Groups Links
ti… [at] ch2m.com2010-06-27 19:22 UTC
If you do install automatic also install an hour meter.
I do not have automatic as I check the boat very regular. (It is parked at my floating home. )
I want to know if I have a leak so I can chase it before it gets big or critical.
An automatic may hide a problem. And if a big event occurs the boat sinks with dead batteries unless you have shore power.
Cheers,
Timm Lessley
(Sent from Blackberry)
(503) 863-4019
Sent: Sun Jun 27 09:37:07 2010
Greg
YMMV
john
Greg,
Wyatt
CAL 2-46 #75
“Blythe Spirit”
St. Pete
Thanks, Greg
Re: [Cal_Boats] stuffing box(dEmO)
david dobbs2010-06-28 04:16 UTC
dEmO,
You are on target. I went to my boat today, after some serious rain over the last 3 days. I spent some time pumping my manual bilge pump, which was to be expected. The rainwater gets in the bilge, and I know that, so I pump it out. If it's dry, the bilge is dry. I don't have an automatic bilge pump, I guess my boat doesn't leak from below, so I'll deal with the rain.
Regards,
David Dobbs, Cal29 411
Date: Sunday, June 27, 2010, 2:22 PM
Cheers,
Timm Lessley
(503) 863-4019
From: Cal_Boats@yahoogrou ps.com <Cal_Boats@yahoogrou ps.com>
To: Cal_Boats@yahoogrou ps.com <Cal_Boats@yahoogrou ps.com>
Greg
YMMV
john
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Allen Edwards
Greg,
Wyatt
CAL 2-46 #75
“Blythe Spirit”
St. Pete
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com] On Behalf Of gregreinhard
Thanks, Greg
RE: [Cal_Boats] stuffing box (dEmO Too)
Husar, Charlie [USA]2010-06-28 05:03 UTC
It is in our lore that 80-90 percent of men found drowned after falling overboard have their zippers down. It makes me wonder what percentage of boats that sink at their moorings have dead batteries. Inquiring minds and all that.
Cheers, Anyway
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of david dobbs
Sent: Monday, June 28, 2010 12:17 AM
Subject: Re: [Cal_Boats] stuffing box(dEmO)
dEmO,
Regards,
Cheers,
Timm Lessley
(503) 863-4019
Greg
YMMV
john
On Thu, Jun 10, 2010 at 4:19 PM, Wyatt Hendricks <whendricks@avtechme d.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=wh… [at] avtechmed.com>> wrote:
Greg,
Wyatt
CAL 2-46 #75
"Blythe Spirit"
St. Pete
From: Cal_Boats@yahoogrou ps.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=Ca… [at] yahoogroups.com> [mailto:Cal_Boats@yahoogrou ps.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=Ca… [at] yahoogroups.com>] On Behalf Of gregreinhard
To: Cal_Boats@yahoogrou ps.com<http://us.mc1113.mail.yahoo.com/mc/compose?to=Ca… [at] yahoogroups.com>
Thanks, Greg
Re: [Cal_Boats] stuffing box (dEmO Too)
roline2010-06-28 23:09 UTC
We leave our boats in the water all yr. Last winter I received a call
that a friends boat was a low rider and needed help. I went down and
it had 2 ft of water in her. We believe that the bilge pump had been
working untill it frooze in the hose where it had a dip in it. The ice
plug allowed the pump to run until the battery was shot the next time it
cycled. The shore power was off so the battery could not charge. It took
5 hrs to pump her out. Dont know the condition of the 2GM20.
> Cheers, Anyway
> Charlie
> dEmO,
> Regards,
> From: ti… [at] ch2m.com <ti… [at] ch2m.com>
> big or critical.
> Cheers,
> Timm Lessley
> (503) 863-4019
> Greg
> From: john raxter <jraxter@triad. rr.com>
> trickle of water.
> YMMV
> john
> From: Cal_Boats@yahoogrou ps.com <http://ps.com/> [mailto:Cal_
> Boats@yahoogroup s.com <http://s.com/>] On Behalf Of Allen Edwards
> Allen
> wrote:
> Greg,
> Wyatt
> CAL 2-46 #75
> "Blythe Spirit"
> St. Pete
> Thanks, Greg
Greg Reinhard2010-07-01 00:32 UTC
Today I rebeded two thru hulls that evacuate through the stern above the water
line when not motoring. I think this may solve the problem. The drips from
the stuffing box seem to be as desired. None the less I will install a
automatic bilge pump soon. Thanks for all the good advice.
Greg
Belladue Ca28 II
Kent Island Md.
Sent: Thu, June 10, 2010 11:15:31 AM
my vote.
On Thu, Jun 10, 2010 at 4:31 AM, gregreinhard <gregreinhard@ yahoo.com> wrote:
>the Cal.
>Thanks, Greg
