28 messages2010-05-24 05:40 through 2010-07-15 20:17 UTC
Original Cal 28 mainsail size
James2010-05-24 05:40
Hi,
I'm wondering if anyone knows the original dimensions of the mainsail for a Cal 28 flat top. I looked at the sketch posted in the files section but couldn't make out the numbers.
The Cal 28 I bought has sails that look like they were made for a 29 footer. The main sail is around 4" too tall and the foot reaches almost to the end of the boom. When I use it, I normally have to reef it to make it so it's tight.
Thanks for any info...
--Jim
RE: [Cal_Boats] Original Cal 28 mainsail size
r good2010-05-24 14:38 UTC
Reef? or flattening reef and/or cunningham?
Date: Mon, 24 May 2010 05:40:06 +0000
Subject: [Cal_Boats] Original Cal 28 mainsail size
Hi,
--Jim
Re: [Cal_Boats] Original Cal 28 mainsail size
Allen Edwards2010-05-24 15:03 UTC
I would think a sailmaker could cut 4 inches off the foot and re-install the
rings without too much expense. You could even go to loose foot and
dispense with the slides/rope.
That said, getting new sails are a lot like getting a new boat.
> Reggie
> From: ji… [at] yahoo.com
> Hi,
> it's tight.
> --Jim
mike2010-05-24 15:09 UTC
Jim,
Do you have an adjustable gooseneck on a track? Can it come down
further? When I was learning to sail on my 25, I had to take the slack
out of the main with my cunningham until I figured out that the
gooseneck was 'locked' in position with a knob. The boom height was set
so the pop top could open without banging the rigid boom vang. I was
able to drop it about 3 more inches and didn't have to use the
cunningham anymore, except when racing to windward, but needed to fiddle
with the gooseneck to open the top. Everything is a compromise, it seems...
Mike M.
> Reggie
> Hi,
> --Jim
Re: Original Cal 28 mainsail size
James2010-05-25 17:07
Hi Mike,
Yes, it does have an adjustable gooseneck on a track. When fully deployed, the gooseneck is pulled down to the bottom position with the cunningham and the sail is still a little slack on the mast. I found that if I hook the cunningham hook to the lowest reef point, I can get the sail tight.
The sail has the number 29595 on it. I don't know how they number sails, but the numbers make me suspect that it was made for a 29 footer.
I could get the sail cut down, but it's kind of old and I was thinking of replacing it. But without the original dimensions, it's a little bit of a guess trying to give dimensions to a sail maker or to look for a good used one.
So if anyone has the original dimensions, that would be great.
Reggie, I'm not sure what you're asking as I am a little new to this... The sail has 2 main reef points which work great. Besides the tack, it has another grommet around 4 inches higher up on the sail, which I'm not sure of its function, except it works great to tighten the sail with the cunningham.
--Jim
--- In Ca… [at] yahoogroups.com, mike <mike@...> wrote:
> Jim,
> Mike M.
> > Reggie
> > From: jimskelton@...
> > Hi,
> > --Jim
RE: [Cal_Boats] Re: Original Cal 28 mainsail size
John Boyce2010-05-25 22:15 UTC
Go to Baconsails.com and you will find the dimensions for your sails. The
sail numbers you have have no relationship to the boat they are from. They
are racing sail numbers issued by US Sailing I believe they are issued as
they are requested.
John B.
CAL 227 #650
Of James
Sent: Tuesday, May 25, 2010 12:08 PM
Subject: [Cal_Boats] Re: Original Cal 28 mainsail size
Hi Mike,
one.
--Jim
--- In Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> , mike
<mike@...> wrote:
> Jim,
seems...
> Mike M.
> > Reggie
> > To: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
> > Hi,
> > --Jim
Bruce Stirling2010-05-26 00:30 UTC
http://www.stirlinglaw.com/cal28/cal28sails.htm
On 5/23/10, James <ji… [at] yahoo.com> wrote:
> Hi,
> it's tight.
> --Jim
Robert Bruce Stirling, II, Esq.
602.254.6638
602.460.5631 [Cell]
602-507-9445 [Fax]
520-302-5206 [Tucson]
br… [at] stirlinglaw.com
http://www.stirlinglaw.com/lawyers
The information in this e-mail communication is Privileged and
Confidential. If you are not the intended recipient, please contact the
undersigned sender immediately and then delete this e-mail.
Husar, Charlie [USA]2010-05-26 03:25 UTC
Jim, try this one.
http://www.baconsails.com/sailsearch
Annapolis
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of James
Sent: Monday, May 24, 2010 1:40 AM
Hi,
--Jim
Yahoo! Groups Links
Husar, Charlie [USA]2010-05-26 03:41 UTC
Jim, the 29595 is a PHRF number that has no connection to the boat type. Different regions are assigned different number blocks to try to prevent repetition of numbers.
Do your mast and boom have black bands on it that are supposed set the limits of sail size? We scrupulously observe the bands in our CAL 25 one design racing.
Sent: Tuesday, May 25, 2010 1:08 PM
Hi Mike,
--Jim
> Jim,
> set so the pop top could open without banging the rigid boom vang. I
> was able to drop it about 3 more inches and didn't have to use the
> fiddle with the gooseneck to open the top. Everything is a compromise, it seems...
> Mike M.
> > Reggie
> > Hi,
> > --Jim
Yahoo! Groups Links
Cal 2 27 Dodger and Bimini.. Save my Skin!!!!
Stephen Martin2010-06-01 14:07 UTC
Hello All.
Summer sailing, is here on LI Sound, and I am heartily fed up of sailing smelling like a Coconut and as greasy as a French Fry!
I have a 1976 Cal 2 27, tiller and unfortunately a very SUNNY cockpit. I have searched unsuccessfully for a Dodger and Bimini to fit my boat and save my toasting skin! So I figured I would reach out to the board an cross fingers.
Does anyone have a surplus, unused, older needs refurbing, or even a newer, either or both of the above that would fit my old girl?? I would prefer a Stainless frame(s) but Aluminium would be equally as desirable. Cloth colour is not an issue.
Boating on a budget, so something new & shiney is not quite in my budget. Drop me a line with price, location etc if anyone out there can help.
Thanks!
Steve M
Cal 2 27 'Ocean Brats'
Bridgeport (Black Rock) CT
RE: [Cal_Boats] Cal 2 27 Dodger and Bimini.. Save my Skin!!!!
Rogers, Christopher C.2010-06-01 14:30 UTC
I'd try Bacon's here in annap: www.baconsails.com
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Stephen Martin
Sent: Tuesday, June 01, 2010 10:07 AM
Subject: [Cal_Boats] Cal 2 27 Dodger and Bimini.. Save my Skin!!!!
Hello All.
Thanks!
Steve M
Husar, Charlie [USA]2010-06-01 14:50 UTC
Or maybe a different sun blocker? I feel your pain. Long races Sat and Sun under heat and sun conditions with a lot of light air. I hate putting on that goop, even when it does not small like coconuts. And even the "waterproof" ones run into your eyes when you sweat. There are some fast drying sunblocks I need to try. CAL 25 too small for a dodger or bimini.
Cheers, Anyway
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Rogers, Christopher C.
Sent: Tuesday, June 01, 2010 10:30 AM
Subject: RE: [Cal_Boats] Cal 2 27 Dodger and Bimini.. Save my Skin!!!!
Hello All.
Thanks!
Steve M
travel
Chris Campbell2010-06-01 19:50 UTC
Cal-list friends:
If anybody has burning questions about Cal 20 sailing in fresh water,
please note that I'm suspending my list participation for a couple weeks
while I head overseas for France. My diver put a new chain on my
mooring, which allows for peace of mind while I'm gone. I'll row the
dinghy out tonight, put an extra line on the tiller, check everything
out, and then trust that we won't be affected by any freak storms here
in the Great Lakes.
We Great Lakes folks generally hate to travel in the summer months, the
truly sweet season here in the midwest, but this is a good opportunity
so off we go.
Re: [Cal_Boats] Cal 2 27 Dodger and Bimini.. Save my Skin!!!!
Chris Campbell2010-06-01 20:02 UTC
> dodger or bimini.
I was laughing at all this because I was sailing my other boat this past
weekend and observed that I had become my father (almost). He'd had a
little bout with skin cancer and was dutiful about covering up--long
pants, long sleeves, big hat, and cotton gloves (those inexpensive brown
work gloves). I was wearing some long pants over my shorts (old
surgical pants), a long-sleeved sunblocking shirt, and a bright yellow
sou'wester foul weather hat, because I had forgotten my brimmed sailing
hat. And I boldly went without gloves. I tried hard not to contemplate
what that combo looked like.
Luckily, the boat is old and pretty, so most folks are paying attention
to her and not to her peculiar-looking skipper. I even got a boat
compliment from a power boater.
I've put in 4 days teaching on the schoolship, doing science stuff with
grade school kids on the local tourist schooner under charter. This
spring has been full compensation for last year's mess--warm, sunny, and
just delightful. For that, I've put sunblock on the face but since it's
the season's first real sun exposure for me, I wear long pants, long
sleeves, and hat. But those would be necessary anyway, since the
surface water temp was still under 60º F. so the breeze on the Bay is cool.
Stephen Martin2010-06-01 20:22 UTC
I have tried all sorts, there is some stuff out there that as soon as a bead of sweat rolls from the brow into your eyes, you go instantly blind!! Agghgh the pain! I know that there are Dodgers and Bimi's out there to fit my old lady. Just gotta find one!
All that covering up while it works i guess must be something aking to a 1908 sweatbox. Thinking that I would HAPPILY jump into the ocean at that point, Ladder or not!
--- On Tue, 6/1/10, Chris Campbell <cl… [at] charterinternet.com> wrote:
Subject: Re: [Cal_Boats] Cal 2 27 Dodger and Bimini.. Save my Skin!!!!
Date: Tuesday, June 1, 2010, 4:02 PM
I was laughing at all this because I was sailing my other boat this past weekend and observed that I had become my father (almost). He'd had a little bout with skin cancer and was dutiful about covering up--long pants, long sleeves, big hat, and cotton gloves (those inexpensive brown work gloves). I was wearing some long pants over my shorts (old surgical pants), a long-sleeved sunblocking shirt, and a bright yellow sou'wester foul weather hat, because I had forgotten my brimmed sailing hat. And I boldly went without gloves. I tried hard not to contemplate what that combo looked like.
Luckily, the boat is old and pretty, so most folks are paying attention to her and not to her peculiar-looking skipper. I even got a boat compliment from a power boater.
I've put in 4 days teaching on the schoolship, doing science stuff with grade school kids on the local tourist schooner under charter. This spring has been full compensation for last year's mess--warm, sunny, and just delightful. For that, I've put sunblock on the face but since it's the season's first real sun exposure for me, I wear long pants, long sleeves, and hat. But those would be necessary anyway, since the surface water temp was still under 60º F. so the breeze on the Bay is cool.
Re: [Cal_Boats] travel
chris1232010-06-01 20:33 UTC
Happy Trails....:)
/chris h
On Tue, Jun 1, 2010 at 3:50 PM, Chris Campbell <
> Cal-list friends:
> in the Great Lakes.
> so off we go.
> Chris Campbell
Harleigh Ewell2010-06-01 22:45 UTC
For a fast-drying, nongreasy sunblock, I like BullFrog SPF 36 (NOT one
of their other SPF formulations). It goes on as a clear gel and dries
quickly because of its high alcohol content. For that reason, dont get
it in your eyes while applying it. No problem once it is dried.
Harleigh
Cal 31
Behalf Of Husar, Charlie [USA]
Sent: Tuesday, June 01, 2010 10:51 AM
or bimini.
Cheers, Anyway
Id try Bacons here in annap: www.baconsails.com
Hello All.
cross fingers.
help.
Thanks!
Steve M
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 5164 (20100601) __________
http://www.eset.com
mike farrell2010-06-01 23:17 UTC
Bon jour mon capitan,
Mike
Sent: Tue, June 1, 2010 12:50:02 PM
Subject: [Cal_Boats] travel
Cal-list friends:
in the Great Lakes.
so off we go.
Yahoo! Groups Links
mike farrell2010-06-01 23:23 UTC
God bless you Chris! I'm not so sure that whatever sunblock's chemistry is composed of is not toxic. My Grandmother Eva Flint was 1/2 Shawnee so even though I Iook like a paleface, I am not. I never use the stuff. My Mother looked like Geronimo when she aged, even tho he was an Apache and Mom was a Woods Indian.
My Best, Mike
Sent: Tue, June 1, 2010 1:02:09 PM
Randall Alcorn2010-06-02 00:58 UTC
I have been wearing a lot of the long sleeved dry shirts rated at SPF 50. My Irish heritage has caught up to me and my doctor just loves making new holes in my skin. He holds up a plain white sheet of paper and tells me that is what color I should be. I for some reason can't seem to get there. I worked on aflight line and have sailed for many years. I keep telling him I am stained.
-- Sent from my Palm Pixi
v\:* {
BEHAVIOR: url(#default#VML)
o\:* {
w\:* {
.shape {
cool.
Sun Block
Kevin O2010-06-02 17:52 UTC
I found this great web site that rates sunblock. We need it in Las Vegas. It will be 105 this weekend and hopefully I will be in Ventura!
There is more to it than I thought and some promote cancer growth!!
If the link does not work go to the main page www.ewg.org
http://www.ewg.org/2010sunscreen/finding-the-best-sunscreens/?search=&brand_id=&ptype=sunscreen&nooxybenzone=on&novitamina=on&nospray=on
Kevin O
"Kona"
Cal-31
Las Vegas
Re: [Cal_Boats] Sun Block
Stephen Martin2010-06-03 02:31 UTC
The Sun Block suggestions while helpful... Well Nuff said! Today was launch day, 87F and a scorcher on LI Sound I took to a greasy factor somewhere off the scale sunblock and my trusty Tilley hat!
My shady solution has to be out there somewhere!
So all afloat and ready for the season, just got to re-thread the new Transducer after my old one failed on the first day. 143ft of depth in a 20ft channel, I think that was a give dead away that something was not quite right!
While I a touching wood, I will mention that my ancient 1975 Atomic4 purred like a kitten. Now I've gone and put a hex on it, haven't I !!!
Steve M
--- On Wed, 6/2/10, Kevin O <fi… [at] yahoo.com> wrote:
Subject: [Cal_Boats] Sun Block
Date: Wednesday, June 2, 2010, 1:52 PM
http://www.ewg. org/2010sunscree n/finding- the-best- sunscreens/ ?search=&brand_id=&ptype=sunscreen&nooxybenzone= on&novitamina=on&nospray=on
Kevin O
"Kona"
Cal-31
Las Vegas
Atomic power, was..Re: [Cal_Boats] Sun Block(Martin)
Gerald Sobel2010-06-03 03:15 UTC
Martin,
If inferring that an ancient model T type L head 4 cylinder engine has anything to do with Atomic power wouldn't put a hex on an engine, nothing will ! So...not to worry... No more than a Grey Marine engine will make the day overcast.
Speaking of sunblock, one of the few lotions rated number one is Badger. I doubt Badgers use it, so how would it get that name, and, why don't the big Drug Store chains stock everything but it? I guess you'd have to buy it thru a Google research quest.
I'm using Banana Boat for Babes with pro cancer ingrediants except for the 2% titanium dioxide. At least the shhh...d doesn't sting me eyes. I tested the other Baby Sunblock, sponsored by the Drug Chain (Rite-Aide) by dabbing a spot of it on the side of my nose near my eye, and 'it' did.
Meanwhile I'm leaving my hair grow long so it shades me ears and neck, and ditto my full beard, tho it makes me look like a cast-away or a homeless person...or a die hard sailor of classic plastic.
--- On Wed, 6/2/10, Stephen Martin <st… [at] yahoo.com> wrote:
Subject: Re: [Cal_Boats] Sun Block
Date: Wednesday, June 2, 2010, 7:31 PM
Steve M
Kevin O
"Kona"
Cal-31
Las Vegas
Re: Atomic power, was..Re: [Cal_Boats] Sun Block(Martin)
Stephen Martin2010-06-03 13:39 UTC
Hello all,
In my haste to post, I dont think that I introduced myself sufficiently. My name is Steve, and I sail my 1975 CAL 2 27, Atomic 4, on LI Sound in Connecticut. I purchased the boat about 4 years ago and she has been good to me so far.
I started out at New Haven Yacht club. This was a great club and one of the oldest, good people sailing good boats. It was just to far for me to get too. I then set off across the bay to a dock at Oyster Point in New Haven, when they sold up and we were forced off by the buyers, I moved yet again, and now sailing out of Captains Cove (Black Rock) Harbour in Bridgeport CT.
I hold US Sailing Certifications for Keelboats and would love to go on an 'Offshore' trip, maybe one day.
This CAL is my first 'Cruiser' and cruising is my mainstay of sailing, after freshwater dinghy sailing. She, my personal hole in the water, is like all boats; requiring more work than I ever anticipated, and likely more cash than I can ever earn. My stolid and long suffering wife, like many others; claims to be a sailing widow, she deems, that the boat is my other woman.
Anyway, thats me in a nutshell, So I will say hello to all!
Back to my original post
I wish that I had enough hair to cover whats not covered already!! I think the description is 'Follically Challenged' especially on the top .
As for the beard, I dont think 'she who must be obeyed' will go for it. So in consideration of the lack of my canvass nirvana, I will go Badger hunting! I personally dont know how these folks that go sailing in designer suits do it, I ALWAYS come back looking like a street urchin. Dishevelled, Red as a berry, in need of a shower, and as greasy as a recently fried cod fish!
My canvass hunt continues !
--- On Wed, 6/2/10, Gerald Sobel <so… [at] yahoo.com> wrote:
Subject: Atomic power, was..Re: [Cal_Boats] Sun Block(Martin)
Date: Wednesday, June 2, 2010, 11:15 PM
Martin,
Steve M
Kevin O
"Kona"
Cal-31
Las Vegas
LI Sound Cals
Wayne Gillikin2010-06-03 13:56 UTC
Out of curiosity, how many LI Sound Cals participate in this group? It seems, sensibly, that most of the Cals are in Cal. There also seems to be a large Chesapeake contingent. I am on the Western sound and would be interested to know how many others are out there. Please speak up if you are on the sound.
Regards,
Wayne
s/v Elusive
Cal 39 Mk 3
NYACYC Travers Is, NY
RE: [Cal_Boats] LI Sound Cals
Husar, Charlie [USA]2010-06-03 14:11 UTC
Hear, Hear for the LI Sound. And for the Chesapeake Fleet. I also believe we have a number of Florida and Texas boats. And who could forget the Flathead Lake contingent or the Portland collection.
Annapolis
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Wayne Gillikin
Sent: Thursday, June 03, 2010 9:57 AM
Subject: [Cal_Boats] LI Sound Cals
Regards,
Wayne
s/v Elusive
Cal 39 Mk 3
mike farrell2010-06-03 15:27 UTC
Welcome Sailor from San Francisco Bay.
Mike Farrell Cal 20 hull# 1114 Rambler & Cal 20 hull# 61 Coyote
Sent: Thu, June 3, 2010 6:39:52 AM
Subject: Re: Atomic power, was..Re: [Cal_Boats] Sun Block(Martin)
Hello all,
>From: Gerald Sobel <so… [at] yahoo.com>
>Martin,
>Jerry
>>From: Stephen Martin <stephen_w_martin@ yahoo.com>
>>Steve M
>>>From: Kevin O <first4banger@ yahoo.com>
>>>Kevin O
>>>"Kona"
>>>Cal-31
>>>Las Vegas
Webcam - Pompano Beach
Michael D2010-07-15 20:17 UTC
Hi All,
If you are ever wondering what the Atlantic looks like, http://174.141.93.194/
is a link to a camera that updates about every 3 seconds. The lighthouse in the
upper left is at the inlet where we go out.
Michael
