BOAT CLEAN PLUS and Rub Rails?
Hi, All. No marketing here. I just noticed the first item related to rub rails. Have not tried the stuff on anything.
From: Aurora Marine Club [mailto:am… [at] auroramarineclub.com]
Sent: Thursday, August 05, 2010 3:18 PM
To: ch… [at] cal25.com
Subject: BOAT CLEAN PLUS Cleans Everything
Boat Clean Plus Cleans Everything on Your Boat
View promotion on-line if you do not see the images below.<http://www.auroramarine.com/aurora/catalog/special.html>
Save
25% Off
Manufacturer
Recommended
BOAT CLEAN PLUS
Cleans Everything
[http://www.auroramarine.com/aurora/emails/boat_clean/images/bcp_ani.gif]
What Others Say...
Why You'll Love It!
[http://www.auroramarine.com/aurora/emails/odor_free/images/table_01.png]
"In the past, I've cleaned my rub rails with acetone, but was warned that this would make the vinyl sticky. In the interests of being safer than sorry (I do *not* want to have to replace that rub rail that's embedded in the deck/hull joint,) last year did the 'boat-clean/boat-scrub' thing & found it to actually be faster & easier than wiping with solvents. " - Wally B
[http://www.auroramarine.com/aurora/emails/odor_free/images/table_05.png]
"I just tried Aurora Boat Clean for the1st time to clean the topsides. It worked very well, much better than my expectations. There was no running water at the yard at the time, so I just sprayed the Boat Clean on & wiped it clean with a spare cloth. I had the topsides clean in about 3 hours." - Beth
"I used Aurora Boat Clean on my Trojan, it did a great job, even cleaned the teak. It's hard to give up tilex, but I'm now a believer." - Brenda B
"Yesterday I used 'Aurora Boat Clean' & 'Aurora Boat Scrub' on
1)... my filthy vinyl rub rail
2)... scuff marks on the hull &
3)... an ugly streak of rust down my topsides where something had gone into my deck drain, rusted away inside the hose & caused rust to dribble out, leaving an ugly stain.
This stuff is incredible. My vinyl rub rail had serious black scuff marks from the boatyard scaffolding I used during my last haul. It had two layers of masking tape gunk from leaving the tape on too long in the sun when varnishing my toe rails. It was yellowed by UV. Your stuff cleaned it up in less time than it took me to adjust my dock lines to pull the next section within reach. The rust streak down my topsides took about twice as long to erase. That would be less than a minute." - Wal
[http://www.auroramarine.com/aurora/catalog/01110/eco-friendly-logo.gif]
Environment Safe & Biodegradable
Safe for Sensitive Waterways
Used by Professional Repair Shops and Dealers
[http://www.auroramarine.com/aurora/emails/shared_images/star_red_onyellow.gif] 1 CLEANER / 100 USES
Saves space on your boat by replacing more than 25 different cleaners. For fresh & salt water.
Easy to Use: Spray & Wipe or Dilute & Wash.
[http://www.auroramarine.com/aurora/emails/shared_images/star_red_onyellow.gif] Cleans Your Whole Boat
Tough on dirt - Safe for all surfaces: Plastic, Fiberglass, Aluminum, Stainless Steel, Chrome, Rubber, Vinyl, Paint, Nylon, Cotton, Polyester, Dacron, Kevlar & More.
