3 messages2010-08-28 15:09 through 2010-08-29 07:21 UTC
Atomic 4 ring gear
Pierre2010-08-28 15:09
Hi, the starter on my atomic 4 stuck on the on position grinding the side of my ring gear, does anyone know if I can remove the ring gear by heating it up or another method, take it off and turn it around so that I end up with fresh teeth???
Thanks
Pierre
Re: [Cal_Boats] Atomic 4 ring gear
Randy Alcorn2010-08-28 16:34 UTC
The ring gear can be removed, However, it also slides away from the starter
creating the grinding sounds you may hear. I pulled mine and peened it in place
so it would quit sliding away from the starter.
Sent: Sat, August 28, 2010 8:09:48 AM
Subject: [Cal_Boats] Atomic 4 ring gear
teeth???
Thanks
Pierre
Tom Vandiver2010-08-29 07:21 UTC
Hi Pierre,
I have several good flywheels with undamged ring gears. $50 plus shipping from
32507.
Let me know if you have an early or late model A4 as the flywheels are
different.
Tom
Sent: Sat, August 28, 2010 10:09:48 AM
teeth???
Thanks
Pierre
